Ben123 Neutral Newbie December 11, 2004 Share December 11, 2004 Hi, I am using 175/70 R13 tires. Saw 175/60 R14 specs. Suppose this is a wider tire width. What is the difference other than it is costier? ↡ Advertisement Link to post Share on other sites More sharing options...
Johnchong Neutral Newbie December 11, 2004 Share December 11, 2004 (edited) Wider meh? 175mm vs 175mm wat. Just that the 14inch one is lower profile, meaning the sidewalls are shorter. Supposedly, you get better handling with larger rims and lower profile lor. But very often, when u increase rim size, the width also increases. But not in ur case lah. Edited December 11, 2004 by Johnchong Link to post Share on other sites More sharing options...
Sky8807 1st Gear December 11, 2004 Share December 11, 2004 175/70 R13 vs 175/60 R14 specs. Wheel size bigger in diameter. tyre thickness is lesser width the same overall the wheel circumference slightly more. I think Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 11, 2004 Share December 11, 2004 (edited) The tyre width is the same, the different is in rim size and tyre series. Edited December 11, 2004 by Yeobh Link to post Share on other sites More sharing options...
Bigpicture Neutral Newbie December 17, 2004 Share December 17, 2004 If you are currently using 175/70 R13, your RIM size is 13 inches and tire diameter is about 575.20mm. You can replaced it with a wider 185/60 R14 which uses a RIM size of 14 inches and the diameter is about 577.60mm which is very close to your original diameter. 175/60 R14 is a bit too small (diameter of about 565.60mm) -Cheers Link to post Share on other sites More sharing options...
Ben123 Neutral Newbie December 18, 2004 Author Share December 18, 2004 Thanks. You mean I can replace to 185/60 R14 without changing my existing rim? Would the mileage meter be affected by the change? Thinking of this switch but not sure what are the advantages...maybe better grip, looks nicer but at the expense of higher fuel consumption. Right? ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Valve stem washer?
Valve stem washer?
Changing halogen to LED
Do I need to change tire ?
Tire patching types and prices
