Trex101 3rd Gear November 5, 2008 Share November 5, 2008 The 100% series are ASM 0w20, ASL 5w30, ATM 10w30 and AFL 5w40. You can find all the product data sheet here: http://www.amsoil.com/products/cars/index.aspx SSO can last 28k km/1yr change interval. ↡ Advertisement Link to post Share on other sites More sharing options...
Peqasus 1st Gear November 5, 2008 Share November 5, 2008 thx for advise. so the 1 yr written on the XL brochure not applicable? was hoping to tahan til 20,000 km servicing haha. Link to post Share on other sites More sharing options...
Trex101 3rd Gear November 5, 2008 Share November 5, 2008 What do you mean? XL series only can last 12k max, for 20k km usage, you should choose the 100% series ASL 5w30. XL 5w30 http://www.amsoil.com/storefront/xlf.aspx Link to post Share on other sites More sharing options...
Limck007 Neutral Newbie November 5, 2008 Share November 5, 2008 hmm the 100%series and the Signature series can last almost the same duration , though 100% series is cheaper.. then in this case, which is better or value for money? which one give better perfomance base on your experience Link to post Share on other sites More sharing options...
Peqasus 1st Gear November 5, 2008 Share November 5, 2008 alamak. my bad. I remember my bottle is silver with red label. Saw from mxxxxxxxg tat's the XL. Then got confused cos i remember seeing the 1 yr oil change guarantee. just confirmed mine's the 100% syn Motor oil. haha. So it's one yr :) Link to post Share on other sites More sharing options...
Trex101 3rd Gear November 5, 2008 Share November 5, 2008 Depends on your application. For normal usage the ASL 5w30 is more than sufficient but if got go track than SSO will be better as it's advance additives package will provide better anti-wear protection. Link to post Share on other sites More sharing options...
Limck007 Neutral Newbie November 5, 2008 Share November 5, 2008 (edited) Oh.,............ then i think for myself>>ASL is good enough liao... just normal driving =D not cheonging haha Another question>> fastflo EO is lousy.. but for my 1st 10K servicing, i feel like giving fastflo a try, to see how synthetic EO feels like & how lousy fastflo is.. Then my next 24K servicing (not 10k right?) , i was thinking of upgrading to amsoil... Do u think this is advisable?? or just wack amsoil during my 1st 10k servicing? Edited November 5, 2008 by Limck007 Link to post Share on other sites More sharing options...
Trex101 3rd Gear November 6, 2008 Share November 6, 2008 Try Fastflo first and compare with Amsoil later(your 20k km servicing). See which oil performs better in terms of FC and smoothness. Link to post Share on other sites More sharing options...
Limck007 Neutral Newbie November 7, 2008 Share November 7, 2008 thks alot =D Double check (in case i understand wrongly) >>For normal driving, different EO can last different duration rite? Fastflo can last 10K, Amsoil can last 12K to 24K , etc etc SO it is not neccessary to change EO every 10k... am i correct?? Link to post Share on other sites More sharing options...
Trex101 3rd Gear November 8, 2008 Share November 8, 2008 Yes you are right but if you are under warranty, you will have to follow their recommendation of 10k servicing. Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear January 2, 2009 Share January 2, 2009 (edited) I got questions 1. I guess the best place to get AMSOIL is mxxxxxxxg? 2. For turbo charged engine, which AMSOIL OIL is reccomended? The oil temperature in my car can hit 110 degree C when driven on our roads, if wag hard on NSH can temporary hit 120 degree celsius. Is a 40wt OIL needed or a 30wt oil will do. I intend to change oil every 8k km. Edited January 4, 2009 by Ahbengdriver Link to post Share on other sites More sharing options...
Davidcks 1st Gear January 3, 2009 Share January 3, 2009 The 100% series are ASM 0w20, ASL 5w30, ATM 10w30 and AFL 5w40. You can find all the product data sheet here: http://www.amsoil.com/products/cars/index.aspx SSO can last 28k km/1yr change interval. Hee, 2nd oci using the SSO which I got from your place. draining it at every 10K just to maintain the car warranty really sounds dump. [shakehead] Link to post Share on other sites More sharing options...
Samwng 1st Gear January 9, 2009 Share January 9, 2009 I got questions 1. I guess the best place to get AMSOIL is mxxxxxxxg? 2. For turbo charged engine, which AMSOIL OIL is reccomended? The oil temperature in my car can hit 110 degree C when driven on our roads, if wag hard on NSH can temporary hit 120 degree celsius. Is a 40wt OIL needed or a 30wt oil will do. I intend to change oil every 8k km. I was a 2 times repeat customer for AFL 5w40 on a turbo engine.. So far I have not found any better oil for $15 per quart. Bang for buck I must said :) My Average Oil Temp: 85-95C for normal driving 95 -110 C for NSH. (Wack all the way for 30mins) After all depend on your engine and snail setup too.. Fyi, I ever stretch this oil to 15k, oil temp hold well and never lost any oil after NSH. Wanted to go further but worry too much.. Link to post Share on other sites More sharing options...
Route88 2nd Gear January 10, 2009 Share January 10, 2009 Anyone tried Dominator Link to post Share on other sites More sharing options...
Adamvios Neutral Newbie May 8, 2009 Share May 8, 2009 Thanks Trex101,helping me to order amsoil (SAE 10W-40 Synthetic Premium Protection Motor Oil ). Today just get my 20 cantons. . Link to post Share on other sites More sharing options...
Ahgongwolve Clutched May 8, 2009 Share May 8, 2009 Amsoil? ARE YOU SURE? Link to post Share on other sites More sharing options...
Adamvios Neutral Newbie May 8, 2009 Share May 8, 2009 Yes , the shipement just came in. Link to post Share on other sites More sharing options...
Rncw 5th Gear May 8, 2009 Share May 8, 2009 i used to use amsoil, but after i changed to redline, i find amsoil not that good....maybe next change i switch to others like motul..then maybe redline will not be as good??? ↡ Advertisement Link to post Share on other sites More sharing options...
Any amsoil alternatives?
Where to get cheap AMSOIL EO?
Explosion rocks central Bangkok, casualties seen
Assistance needed!
Assistance needed!
Amsoil VS Redline
Amsoil VS Redline
CSC3 Rocks!
CSC3 Rocks!
Amsoil oil distributor
