Arythan Neutral Newbie March 21, 2005 Share March 21, 2005 (edited) jz found out mi engine light was led on... driving a G9 n jz recently did mi servicing... hmm... checked engine oil which is almost full.... radiator water is still full..... timing chain is still ok... so need sum advice here .... i lost mi manual oreadi... kekekee many thkz in advance... Edited March 21, 2005 by Arythan ↡ Advertisement Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 21, 2005 Share March 21, 2005 if i'm not wrong, there shd be a sensor to check level of engine oil. try wipe dipstick and try again. the oil level shd be bet. max and min. if still full, maybe sensor spoil. best check with mech liao if so. Link to post Share on other sites More sharing options...
Arythan Neutral Newbie March 21, 2005 Author Share March 21, 2005 thkz for ur prompt reply... i did check mi engine oil.... n it was almost full... wiped d dip n insert in n check again.. .still almost full... so i'm not sure wat happened... any reliable mech 2 recommend? Link to post Share on other sites More sharing options...
Apollo 1st Gear March 21, 2005 Share March 21, 2005 it means an engine related problem. cud b faulty sensor, dirty air filter, etc. only by doing a ODB diagnostic den u will know exact problem Link to post Share on other sites More sharing options...
Arythan Neutral Newbie March 21, 2005 Author Share March 21, 2005 wat's a OBD diagnostic? how much izit usually? i jz did servicing so dun think it's dirty air filter leh... well, i can give it a try... Link to post Share on other sites More sharing options...
Apollo 1st Gear March 21, 2005 Share March 21, 2005 on board diagnostic... computer to check. better go back agent to check. some outside workshop may hv it, in the mean time, pen down some nos of tow services. if u hv credit cards, some of them offer free tow as well. Link to post Share on other sites More sharing options...
Mivec9 1st Gear March 21, 2005 Share March 21, 2005 a skillful mech i kw, recommended by another bro here.. Eng Hup Auto Parts Accessories Co. Blk 1 No.387J Woodlands Road Yew Tee Industrial Estate Singapore 677954 Tel: 67690452, 67607059 Fax: 67690688 Contact Person: Simo Link to post Share on other sites More sharing options...
Zrun Neutral Newbie March 21, 2005 Share March 21, 2005 (edited) 1 way is to bring to mechanic to get it inspected. Another way is to unplug your battery for 1 min to reset the check engine light. If it happens again, then it is something major that you need to let mechanic check out. On newer cars it maybe fuel cap that is not closed tightly, causing drop in fuel fume pressure. Edited March 21, 2005 by Zrun Link to post Share on other sites More sharing options...
Arythan Neutral Newbie March 21, 2005 Author Share March 21, 2005 thkz for all d tips.... anyway in d west side o not? as i'm working in d west... wouldn't wanna drive all d way 2 d north~! i'll check again.. thkz... Link to post Share on other sites More sharing options...
Apollo 1st Gear March 21, 2005 Share March 21, 2005 just go back agent lah, let them check n quote to u. den u decide if let them do repair. could be minor but at least surer way to find the source and tackle it, rather than blind man touch elephant. if too exp, den u go outside workshop find reliable one to repair lor. always ask for warranty period. Link to post Share on other sites More sharing options...
Arythan Neutral Newbie March 21, 2005 Author Share March 21, 2005 thkz again... but i think they will quote me a ridculous price... anyway, have 2 call in n confirm tmr.... Link to post Share on other sites More sharing options...
Apollo 1st Gear March 21, 2005 Share March 21, 2005 huh? which firm? u can try STAR... STAutomotive, they should hv ODB sensors as well. Link to post Share on other sites More sharing options...
Zrun Neutral Newbie March 21, 2005 Share March 21, 2005 I'd suggest reset ECU first to see if it is false alarm. If you reset the ECU, turn on the engine, and the light comes on again, then it is a real problem. Reset ECU by unplug the ECM fuse for few min, or disconnect battery for few mins. Alot of times, the fuel gets low, and cannot maintain pressure, triggering CEL. When you top up and clear the ECU, it will not happen again. Link to post Share on other sites More sharing options...
Arythan Neutral Newbie March 21, 2005 Author Share March 21, 2005 it may be due to the low petrol level... but it was not triggerred previously n hence a bit strange... ok... i will try 2 disconnect d battery n clear d ecu after topping up petrol... Link to post Share on other sites More sharing options...
Arythan Neutral Newbie March 23, 2005 Author Share March 23, 2005 jz an update... went to BM 2 get mi car checked... reset ECU, replaced mi car battery n reseal mi coolant (as it's leaking). FOC as it's under warranty. on top of it, they even washed mi car for mi... good job.... kekekeke... Link to post Share on other sites More sharing options...
Keltai Neutral Newbie April 21, 2007 Share April 21, 2007 hi, my new honda stream encounter engine light on too, bt been few days liao, stil cant find any OBD II to dignosis e fault code, even try 2 disconnect d battery n clear d ecu cant make it! any1 here gt idea wat going on? 90085459. thks Link to post Share on other sites More sharing options...
Kelpie 2nd Gear April 22, 2007 Share April 22, 2007 For Honda, go and visit Jeep Cheep at Ubi. Look up the contact at www.yellowpages.com.sg They have the equipment to do it. Regards, Link to post Share on other sites More sharing options...
Keltai Neutral Newbie April 22, 2007 Share April 22, 2007 oh, ok! cos had try afew type of scantool in e market liao, none can login even those meant for civic FD.... thks. wil go dwn jeep chee hav a check den ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
