Rabt7 Neutral Newbie March 30, 2005 Share March 30, 2005 I'm driving a vintage 99'Atos GLSA The fan-Belt always squeal - especially when the weather is cold/wet or when the engine is cold. My mechanic - Rayspeed at Pioneer Circus - had adjusted the belt tension numerous times, but the problem still recurr. Now the mechanic says, " ↡ Advertisement Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear March 30, 2005 Share March 30, 2005 Had you tried applying some belt dressing ( Gease for belting) onto it? Link to post Share on other sites More sharing options...
Looneytune Neutral Newbie March 30, 2005 Share March 30, 2005 its pretty normal due to the moisture. after the engine runs for a while, the noise will be gone. no need to specially change the fan belt. its the same for my lancer too. mech says dun waste money to change now. change when it has reach end of shelf life, say ard 100-120k mileage. Link to post Share on other sites More sharing options...
Rabt7 Neutral Newbie April 3, 2005 Author Share April 3, 2005 Good Day, Belt Dressing works - only for a short while, and the sound comes back after a couple of days. What exactly causes the Belt to squeal ? Issit because, 1. Belt too tight, or 2, Belt not tight enough ? Or issit the bearings (but Mechanic says Bearings OK) Where can I go to buy cheapest Atos spares ? The rear Left Door - outside handle broke, this evening. I suspect that the plastics fot this model does turn brittle - after a couple of years Any workshop in the West / Alexandra - specialising in the Atos ? Thanks again for Your Advice, Cheers Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 7, 2005 Share April 7, 2005 Remove the v-belt,throw them away, clean up the pulley v-grove with emery cloth. Get OEM replacement v belt. Do not over tension the belt ( need working exprience to get the feel )and apply some silicon grease onto the v-grove. Happy driving !! Link to post Share on other sites More sharing options...
Mivec9 1st Gear April 28, 2005 Share April 28, 2005 does it mean his current v-belt worn out liao..that's why got sound? thks bro. Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 29, 2005 Share April 29, 2005 Precisely, the surafce of the v-belt is already "shining" Link to post Share on other sites More sharing options...
Mivec9 1st Gear April 29, 2005 Share April 29, 2005 oh thks...then i better changed mine soon. Link to post Share on other sites More sharing options...
Firstcall Clutched July 13, 2005 Share July 13, 2005 (edited) I'm driving a vintage 99'Atos GLSAThe fan-Belt always squeal - especially when the weather is cold/wet or when the engine is cold. My mechanic - Rayspeed at Pioneer Circus - had adjusted the belt tension numerous times, but the problem still recurr. Now the mechanic says, " Edited July 13, 2005 by Firstcall Link to post Share on other sites More sharing options...
Dennistan80 Neutral Newbie October 18, 2005 Share October 18, 2005 Bro apply some rubber grease. Hope it helps Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 18, 2005 Share October 18, 2005 I'm driving a vintage 99'Atos GLSA The fan-Belt always squeal - especially when the weather is cold/wet or when the engine is cold. My mechanic - Rayspeed at Pioneer Circus - had adjusted the belt tension numerous times, but the problem still recurr. Now the mechanic says, " Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 19, 2005 Share October 19, 2005 MC ever told me after putting some reddish cream and my belts then still sqeaked..mentioned need to change the belts.. indeed after recent timing belt package change, no more sound liao Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 19, 2005 Share October 19, 2005 Probably your previous belts got so worn and harden that the belt dressing cannot safe it. If you maintain the belt regulary, the belt life would last longer. I understand that belt dressing or silicon can be absorbed by rubber so as to keep the rubber 'moisturise' and maintain its tension longer. But if the rubber surface (the belt internal, touching the pulley) had harden or glazed from improper tension, then cannot absorb the belt dressing and silicon anymore. Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 21, 2005 Share October 21, 2005 probably the previous owners didnt bother to change the belts after xxx xxx km! Link to post Share on other sites More sharing options...
Koren Clutched October 21, 2005 Share October 21, 2005 my old accent also has this sound.. applying grease will help a little.. but it'll still sqeak. had to live with that problem until it got scrapped.. you can try changing the belt though.. it might work.. Link to post Share on other sites More sharing options...
Rabt7 Neutral Newbie October 21, 2005 Author Share October 21, 2005 Good Day, Thanks for the advice. On a related subject, what would the service intervals be for 70,000km odo ? Timing Belt change intervals? ATF Change intervals? etc,..? Are there any Atos (vintage 99' )Owners out there in this forum - ever tried going up to Malaysia to use the Inokom Atos Parts (issit really much cheaper??) ? I am considering using this Atos for another 10 years' after the COE expires in 2009. Inspite of the belt noise, and the slightly inferior plastics, I am very happy with the car, cos it is easy to drive/park/squeeze/has a high seating position,... and I am looking to re-establish a good relationship with a mechanic - who can service this car well, for the long term. thanks Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie October 21, 2005 Share October 21, 2005 not sure does it apply for your car for my 323, timing belt is changed every 90-100k km atf change every 40k km Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 21, 2005 Share October 21, 2005 the normal belts are quite cheap...hence changing it would be wise ↡ Advertisement Link to post Share on other sites More sharing options...
Singapore tourist causes fatal crash in New Zealand
Rear seat passenger : Do they belt up?
Clean car seat belt
Clean car seat belt
Changing of water pump and timing belt.
Squealing/Squeaking brakes
Hernia - Causes, Treatment and Prevention.
Remember to wear seat belt
Rear seat belt stuck
