Darth_mel 1st Gear April 7, 2005 Share April 7, 2005 The subject heading says it all. Anyone can share their experience ? Cheers. ↡ Advertisement Link to post Share on other sites More sharing options...
Garis Clutched April 13, 2005 Share April 13, 2005 fixed it in my old elantra and improved throttle response instantly Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 13, 2005 Share April 13, 2005 yup, oso in my old tarzanboyz 323, but no so with Protege. prob due to ECU lean out by reducing the fuel-injectors' duty-cycle and result not much effect.... Link to post Share on other sites More sharing options...
Darth_mel 1st Gear April 13, 2005 Author Share April 13, 2005 My Mondeo cannot install becos no return fuel line by the mechanic. Anyone can confirm ? Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 13, 2005 Share April 13, 2005 (edited) no return fuel line and pressure relieve valve.......siao liao. cannot put PBV anymore. Want more fuel pressure, get a bigger fuel pump motor with exponential electronic control that simulate like PBV. But no guarantee will work as fuel pressure sensor signal will be sent to ECU to be leaned out...........oso siao liao. Edited April 13, 2005 by Normal_aspirated Link to post Share on other sites More sharing options...
Mhb9 Neutral Newbie April 17, 2005 Share April 17, 2005 improved on the throttle response. Correct setting is important Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 17, 2005 Share April 17, 2005 wat's yer normal idling setting? Link to post Share on other sites More sharing options...
Darth_mel 1st Gear April 17, 2005 Author Share April 17, 2005 What car are u folks driving ? Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 17, 2005 Share April 17, 2005 mine protege CMI, but he's the older tarzanboyz 323 hatchback.......can chiak civics and mivecs. Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie April 17, 2005 Share April 17, 2005 but does FBV increase the FC?? have u seen the simota cold air intake for MZ323?? saw it at mcwells yesterday...looks cool...claim will improve low to mid end torque...worth the try?? cost $228 include installation,carbon fiber resonator, cone filter, piping and 9mthly free filter cleaning for lifetime(who owes the car for lifetime) Link to post Share on other sites More sharing options...
Mhb9 Neutral Newbie April 18, 2005 Share April 18, 2005 i set at 3. Anything below 2.5, car will transform to Ninja Turtle 2.8 seems to give the best FC. Diff cars got diff spects Link to post Share on other sites More sharing options...
Mhb9 Neutral Newbie April 18, 2005 Share April 18, 2005 yours can lah..... mine Link to post Share on other sites More sharing options...
Imuya Clutched April 18, 2005 Share April 18, 2005 is this a fuel pressure regulator thingie? cos i have one in my car and turned it all the way down cos of rising petrol costs sial... Link to post Share on other sites More sharing options...
Mhb9 Neutral Newbie April 18, 2005 Share April 18, 2005 (edited) Personally, simota cold air intake for 323 is not so good. Look carefully on how it takes in cold air. The passage is blocked when u closed your bonnet, very similar to the stock setup. Cone filter is located at the hot zone too An article for your reading. ******************************************************************************** ** HOW DOES THE POWER BOOST VALVE WORK? The Power Boost Valve is a high performance tuning part which replaces the original equipment valve (fitted to the vehicle). A range of models are available to suit a wide variety of European cars, which almost certainly includes yours. We are continually developing new designs to expand the number of applications. We outline the benefits of the Power Boost Valve by drawing a comparison evaluation: Ref: Original Equipment Fuel Pressure Control Valve The electric fuel pump supplies fuel at a high pressure to the fuel rail and injectors, which is then regulated by a fuel pressure control valve. Typically, the regulator is not adjustable and is pre-set to a 3 bar maximum pressure. At idle the fuel pressure valve reduces it by 0.5 bar approximately to 2.5 bar. When accelerating quickly from standstill the fuel pressure increases at a proportional rate retaining a lean fuel mixture strength as required by the E.E.C. for new vehicles. However, the resultant effects of the standard valve produce: lethargic throttle response occasional drivability problems at slow traffic speeds intermediate performance 'flat spots' when accelerating By comparison: Ref: Power Boost Valve (replacement) Firstly, this valve has an adjustable fuel pressure, effected by the movement of an adjustment screw on the crown of the unit. New Power Boost Valves are pre-set with a maximum fuel pressure of 2.5, 3.0 or 3.5 bar, depending on the vehicle in question, and similarly (to the original valve) the fuel pressure is reduced by 0.5 bar approximately at idle. There the similarities end. On acceleration from standstill the Power Boost Valve fuel pressure will increase at 1.7 times the standard rate. This will produce a healthy, strong fuel mixture strength which will instantly improve the drivability of your vehicle, providing:- instant throttle response removal of performance flat spots faster acceleration extra engine performance The regulator enhances engine performance on acceleration by enriching the mixture strength. On constant throttle and cruise conditions the valve returns to a normal regulator function. http://www.fuelsystem.co.uk/pbv.htm ******************************************************************************** ****** Edited April 18, 2005 by Mhb9 Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie April 18, 2005 Share April 18, 2005 Thks for the info....so to say the FSE will not affect FC but onli enrich the mixture strength?? for the current setup...the filter is also at the hotzone too...but more restricted flow....arent carbon fibre supposed to provide better heat shield than stock plastic?? blockage at front can be easily done...believe it was discussed before on the removing the rubber lining at the front for better suction... Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 18, 2005 Share April 18, 2005 with PBV, and a HRF........got used to the power......sure use more fuel, mah. Link to post Share on other sites More sharing options...
Mhb9 Neutral Newbie April 19, 2005 Share April 19, 2005 so far FC still the same..... It is just my personal comment on simota, u may ask those bros who have installed from mazdaclubsingapore. My open pod is situated behind front right headlamp. U may want to take a look at my setup in "Car Showroom" folder. Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie April 19, 2005 Share April 19, 2005 (edited) k...tks ..u drove protege too?? wat the title under my car showroom Edited April 19, 2005 by Law_ong ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
IKEA shopping experience
S’pore Airshow - Worst transport experience’
Home power back up
Home power back up
