Mhb9 Neutral Newbie April 19, 2005 Share April 19, 2005 me drive 323 Title is "My old Mazda 323 Sport HB" (page 2) picture in #9 of 50 ↡ Advertisement Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie April 19, 2005 Share April 19, 2005 oh...saw that b4..nice ride!!...any lost in low end?? and got problem changing lamps?? have thght of having E68 at that location (a hole behind the coolant reservoir)...ya hor..if ur coolant overflow..wont it be suck in by the filter? Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 19, 2005 Share April 19, 2005 if use open pod, dun use air-injector as they reduce the vacuun needed, speaking from my experience. E68 effective with stock filter box setup..... Link to post Share on other sites More sharing options...
EventH 1st Gear April 19, 2005 Share April 19, 2005 Is the FSE PBV generic for all cars or have a specific model for each application? Link to post Share on other sites More sharing options...
Mhb9 Neutral Newbie April 20, 2005 Share April 20, 2005 yes.. accept setting a bit diff among cars Link to post Share on other sites More sharing options...
Mhb9 Neutral Newbie April 20, 2005 Share April 20, 2005 agree wif normal_aspirated.. u need vacuum to store air if u used an open pod. I believe capsule is able to do that. I placed an oil catch tank, low end still affected. . Currenly looking for a used one to test out the effect. That hole behind the coolant reservoir is best for CAI, diverting the tubing to that hole to grasp cold air. I dun think u will have a issue with coolant overflow. btw, i have relocated my coolant reservoir Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie April 20, 2005 Share April 20, 2005 tks...but i never install E68...coz my mechanic told me its useless for EFI..onli good for carb...coz the ecu will sense the increase of airflow and compensate..so is like LL..u can escape the intake sensor..but when the exhaust sensor senses differeces..ecu will compensate..so no use at all... Link to post Share on other sites More sharing options...
Mhb9 Neutral Newbie April 20, 2005 Share April 20, 2005 did u mechanic tell u tht u can manually increase the airflow without ecu resetting back itself Ask him again... Link to post Share on other sites More sharing options...
Law_ong Neutral Newbie April 20, 2005 Share April 20, 2005 never ask...so wat is the trick?? share share leh... Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 20, 2005 Share April 20, 2005 Is the FSE PBV generic for all cars or have a specific model for each application? is generic to all cars, have to find the best idling setting, 2.2 to 3.0 bar i think. hv to find it to suit your car. Link to post Share on other sites More sharing options...
Darth_mel 1st Gear April 20, 2005 Author Share April 20, 2005 Can install one even if car has no return fuel line or not ? Very gian leh. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched April 20, 2005 Share April 20, 2005 (edited) Can install one even if car has no return fuel line or not ? siao liao.......cannot, lah. How to? Get a bigger & stronger fuel pump if you want to........but may not work as ECU may lean out after sensing higher fuel pressure. End up u may need to use a piggybagy to fool the ECU. Then again, can consider forced induction after tat...... Edited April 20, 2005 by Normal_aspirated Link to post Share on other sites More sharing options...
Darth_mel 1st Gear April 20, 2005 Author Share April 20, 2005 Like that then Bo Wan Bo Liao lor. Link to post Share on other sites More sharing options...
EventH 1st Gear April 22, 2005 Share April 22, 2005 amen ... FL N16 got no return fuel line ... save monie again hahahha Link to post Share on other sites More sharing options...
Dennisk Clutched July 6, 2005 Share July 6, 2005 how much diff in FC after PBV installed? Link to post Share on other sites More sharing options...
Normal_aspirated Clutched July 6, 2005 Share July 6, 2005 how much diff in FC after PBV installed? Nope, increase FC instead BUT effect of smoothen flat spot of acceleration response from 2000 to 3000rpm and and even better beyond that. In the old days, PBV were famous for use in racing cars. Our 323 still can use becuz it has fuel return line. Newer cars w/o fuel return line cannot use the PBV. Link to post Share on other sites More sharing options...
Fortress Clutched July 6, 2005 Share July 6, 2005 Pardon my ignorance, "can I buy a vowel" on your short forms. What's FC, BUT PBV.. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched July 6, 2005 Share July 6, 2005 FC= fuel consumption PBV= Power Boost Valve (actually is the racing type fuel pressure relieve valve). ↡ Advertisement Link to post Share on other sites More sharing options...
Valve stem washer?
Valve stem washer?
Carbonics Cold Air Intake System - Full Handmake CF
IKEA shopping experience
S’pore Airshow - Worst transport experience’
Home power back up
Home power back up
