Alyc Neutral Newbie June 1, 2005 Share June 1, 2005 Hi guys, recently when i'am driving, i hear a knocking sound from the engine. i can hear it thru the aircon duct from the driver's side. Seems a bit louder when i release my clutch, from neutral to half clutch position. It's a 1 month old optra sedan Anyone experience this before? ↡ Advertisement Link to post Share on other sites More sharing options...
Spango Clutched June 1, 2005 Share June 1, 2005 What are you pumping into your baby? Link to post Share on other sites More sharing options...
Alyc Neutral Newbie June 1, 2005 Author Share June 1, 2005 Mobil 98 So it can't be the fuel i guess.... Link to post Share on other sites More sharing options...
York Clutched June 1, 2005 Share June 1, 2005 need to go for tunning liao... likely ur ignition timing is out of spec Link to post Share on other sites More sharing options...
Alyc Neutral Newbie June 1, 2005 Author Share June 1, 2005 Wow.... can enlighten me, i'm a moron in engine mechanics.... So far i only fitted a fuel magnet, a voltmeter and a vacuum gauge in my ride.... ignition timing out in a one month ride? where can i go for tuning? Link to post Share on other sites More sharing options...
Spango Clutched June 1, 2005 Share June 1, 2005 Those things void your warranty? Link to post Share on other sites More sharing options...
Alyc Neutral Newbie June 1, 2005 Author Share June 1, 2005 What??!!! what voids my warranty ??? Link to post Share on other sites More sharing options...
York Clutched June 1, 2005 Share June 1, 2005 urs new ride...go bk to ur agent..... u nvr noe...could be EC unit not properly set... Link to post Share on other sites More sharing options...
Alyc Neutral Newbie June 1, 2005 Author Share June 1, 2005 Okie... will do just that... but hope i dun get those excuses like the other chevy owners get from SA.... or else Thanks bro! Link to post Share on other sites More sharing options...
York Clutched June 1, 2005 Share June 1, 2005 (edited) fuel magnet...'fuel saving device'....some of tis device can damage the fuel-pump.. BTW is ur fuel device certified for used on ur ride... B4 u proceed to ur distributer for backup service....due to the current prob...best u take out the fuel saving device 1st. Otherwise the technical pple there may claim it's due to the device that coses the prob... Edited June 1, 2005 by York Link to post Share on other sites More sharing options...
Alyc Neutral Newbie June 1, 2005 Author Share June 1, 2005 It's the Maxpower 2 red magnet. Pretty common i guess... Link to post Share on other sites More sharing options...
Spango Clutched June 1, 2005 Share June 1, 2005 These stuff void your warranty?? Wow.... can enlighten me, i'm a moron in engine mechanics.... So far i only fitted a fuel magnet, a voltmeter and a vacuum gauge in my ride.... ignition timing out in a one month ride? where can i go for tuning? Link to post Share on other sites More sharing options...
York Clutched June 1, 2005 Share June 1, 2005 yah...u r rite...these devices..some can interfer the fuel line/supply....pressure in some cases it coses hairline cracks on the fuel pump which is quite difficult to trace.. Link to post Share on other sites More sharing options...
Cbx750p 1st Gear June 1, 2005 Share June 1, 2005 That is kind of far stretch, don't you think ? How can a piece of magnet mounted out the rubber fuel line crack the fuel pump which is right behind the car under the rear passenger seat and interfer with the fuel line supply pressure ? Please !!!!!!!!!!! EDUCATE me Link to post Share on other sites More sharing options...
Cbx750p 1st Gear June 1, 2005 Share June 1, 2005 Hi guys, recently when i'am driving, i hear a knocking sound from the engine. i can hear it thru the aircon duct from the driver's side. Seems a bit louder when i release my clutch, from neutral to half clutch position. It's a 1 month old optra sedan Anyone experience this before? Questions : a. How many time the sound appear ? Once or repeatedly ? b. What sound ? Tapping, Kocking, etc. Try to describe sound ! c. When do sound appear ? Driving, stationary, in carpark, during turn, driving over hump or anytime ? d. Does the sound coincide with any particular movement, like de-clutching, accelerating, etc ? CBX Link to post Share on other sites More sharing options...
York Clutched June 1, 2005 Share June 1, 2005 (edited) bro....it's true...just happen,.... if u need more info, can PM me...will be glad to share wif u... My bro-in-law had a big arguement on 2 ocassions, wif the technical officer of the service ctr, even consider legal proceeding as they wanna void his warranty.. Edited June 1, 2005 by York Link to post Share on other sites More sharing options...
Sky8807 1st Gear June 1, 2005 Share June 1, 2005 Might be those items u installed to the engine. Not properly secured or fitted. Vacumn line is one main suspect. Why installed such items when u are not familiar with the engine in the first place? Link to post Share on other sites More sharing options...
Room430 Neutral Newbie June 2, 2005 Share June 2, 2005 Best is if you can PROPERLY uninstall all those gadgets and then see if the problems persist. If it still does, go back to SA to have them look at the problem...... without all those gadgets in of course. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
Is Singapore Safe From Earthquakes ?
