Need help with my touchup.
Hammy
I just got a tiny chip off on my bonnet courtesy from a small stone at PIE [furious] . Yesterday I just got time to touch up the exposed metal with my touchup paint, however I did not do a good job, some of the touchup over lap to the existing paint. Is there anyway to remove the overlapped paint? Now a bit of regret, should have just cover the exposed part with soft99 Fusso 12 month coat, now the bonnet look like it got a mole. Another question is how long must I wait for the paint to cure before I cover it up with the fusso coat?
all touch up jobs will end up like that one. there is no way you can cover up the chip totally.
[thumbsup] Good idea. Find some interesting and unique sticker, cheap and good and no headache.
I heard that a rubbing compound can do the job, is it true?
Anyway, is Meguiar ScratchX a rubbing compound?
If it is not, then how do we apply and buff it off for both of them as I know that these two types of products are not wipe on & off type. I intend to use it to remove/beautified the job I have done on the mole that I have created on my bonnet. Just dun want to worsen the suitation.
According to Autopia site: http://www.autopia-carcare.com/paintclinic.html
1. use a very fine sandpaper (else micro rubbing compund will do too) to sand the part down till it's even.
2. Then use Scratch-X or Kizz-R to remove the fine scratches created by the sanding....
3. Finish off with your sealant and wax....
For (1), do with delicate care.
Southpark
The Dude
Edited by Southpark2000
The pros really make it look / sound too easy [rolleyes]
Paint repair like this can be daunting to do by hand, although not impossible.
Might want to read up on wet-sanding and paint repair/polishing and
even practice before doing on the actual thing [dizzy]
Scratch-X contains diminishing abrasives, meaning it will
work like a rubbing compound initially and gradually break down
into a fine polish coating. This makes it very difficult to create new
scratches while removing the existing ones.
It is so mild that I practically have to apply and rub till it disappears
for 5-10 times to remove light hairline scratches [sweatdrop]
Soft-99 Kizz-Clear on the other hand, is a filler,
which hides the scratches by filling-in with a transparent material
rather than removing the surrounding material via abrasives.
This is much easier to do especiallly without machine but the scratches
will show up once the filler wears off or gets washed away.
Good Luck! [thumbsup]
Thanks, will find sometime to do the touchup. Maybe try it on my bumper first, hehehe.
errr Dude, I wouldn't recommend wet sending to anyone without experience. It might caused more damage at the end bigcry.gif
Agree, my touch was by AHA autoimage... they oso use wet sanding. But end result, I'm satisfied! [thumbsup] Or rather good enuff.
