Yeobh 4th Gear June 9, 2005 Share June 9, 2005 Right looks for shop that has off car wheel balancer that can measure below 5gm. Most of the old machine may just show "00" reading even the wheel is still 5gm dynamically off balance. ↡ Advertisement Link to post Share on other sites More sharing options...
Syshi Neutral Newbie June 9, 2005 Share June 9, 2005 In Reply To $12 for both very reasonable... got more detailed info? Hmm.. this shop is located in Bukit batok. I dun rem the name of the building or shopname BUT its just next to the STAMFORD Tyre in Bukit batok. d; ) anyways. i done my at stamford tyre (changi) today... got a better deal. 30 bucks for high speed and rotation! all i can say is money well spent. d: )[/reply] Wah... $30 cheap??? Thought the one you mentioned $12 much cheaper? What is the difference with both??? Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 9, 2005 Share June 9, 2005 How to see if balancer can measure <5gm.??? Link to post Share on other sites More sharing options...
Sei_fei_loh 1st Gear June 10, 2005 Author Share June 10, 2005 okay. let me further explain.d: > i first posted 12 bucks. only tyre rotation + normal balancing of 4 tyres. 30 bucks = tyre rotation + normal balancing of 4 tryes + high speed balancing of 2 front tyres Link to post Share on other sites More sharing options...
Syshi Neutral Newbie June 10, 2005 Share June 10, 2005 Thanks... All Stamford Tyres have the high speed balancing? Why only the front 2 tyres for the high speed balancing? Rear not required? Sorry... stupid question... Link to post Share on other sites More sharing options...
Sei_fei_loh 1st Gear June 10, 2005 Author Share June 10, 2005 hmm.. not sure of the logic, but was told unecessary. He said, if u wan to haf it balanced, do i during the next rotation where the rear will come to front. I think probably u could call up stamford and enquire. i suppose all their workshops do taht Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 11, 2005 Share June 11, 2005 (edited) The front tires have a greater effect on the steering if slightly un-balanced. The rear sud b enough to do the off-wheel type as very slight vibrations will not b felt. Anyway, when u do the next balancing, the back tires will get the on-wheel type as they wud have been rotated to the front by then. Edited June 11, 2005 by Pisces69 Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 12, 2005 Share June 12, 2005 Most of the balancers have a button on the panel. Once the wheel is balanced , the tyreman can spin the wheel again and press the below 5gm buttton to detect the remaining out of balance weight for weigh and location.Most the time by just shifting the exsiting weigh will rectify the problem Link to post Share on other sites More sharing options...
Chinkeong Neutral Newbie July 13, 2005 Share July 13, 2005 did it for $7 per wheel at the tyre shop opposite Singapore casket..... very reasonable Link to post Share on other sites More sharing options...
Wind 1st Gear July 16, 2005 Share July 16, 2005 so in short, can anyone recommend a good workshop for doing off wheel balance? as in detecting below 5gm of off-balance? Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 16, 2005 Share July 16, 2005 (edited) When the first wheel balancer from Australia was introduced to Singapore in the late 1970s, the tyre shop that own the first unit charge almost s$15.00 per wheel. s$7.00 is dirt cheap with the amount of labour put to jack up the car , remove the tyre, mount the tyre to machine,remove balancing weight, balance the tyre, place place weigh, check tyre for balance again,remove the tyre from machine, fix tyre back to the wheel hub, and release and remove floor jack. Edited July 16, 2005 by Yeobh Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 16, 2005 Share July 16, 2005 Sorry, have loss touch with this market. Suggest you call Newera Tyre equipment tel : 62410411 may they can direct you to tyre shops that have the lastest balancing machine. ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre Rotation and balancing
Are You A Big Spender For A High End Bed Mattress?
ACS boy dies during high adventure course
How problematic is VW's 7 speed DSG?
High-rise littering
High-rise littering
HSA recalls 3 brands of high blood pressure drugs
