EventH 1st Gear June 15, 2005 Share June 15, 2005 How to read these figures? (looks a Campbell's Alphanumeric soup to me ) API Service SL/CF ILSAC GF-3 CCMC-G5, PD2 ACEA A1-98 SAE Grade 0W30 <<< this one I know :) Viscosity, Kinematic at 40 deg C, cSt 53.56 at 100 deg C, cSt 9.90 Viscosity, Apparent at -30 deg C, cP 5000 Viscosity Index 174 Base Number (mgKoH/g) 8.0 Sulphated Ash, (% wt) 0.73 Specific Gravity, 15/15 deg C 0.868 ↡ Advertisement Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 15, 2005 Share June 15, 2005 looks lousy to me Link to post Share on other sites More sharing options...
Freemen 2nd Gear June 15, 2005 Share June 15, 2005 Think our Guru Genie47 can answer that !! Peace Bro Link to post Share on other sites More sharing options...
EventH 1st Gear June 15, 2005 Author Share June 15, 2005 ommmmmm.... waiting for the Guru of Oil Link to post Share on other sites More sharing options...
Genie47 1st Gear June 15, 2005 Share June 15, 2005 API SL/CF: means can use in todays modern cars though the standard has just been superceded by SM. ILSAC GF3: Fuel economy oil but superceded by GF4 recently. ACEA A1-98: This oil is not going to last past 10k when traveling 70% highway. Less than 70% highway, change at 5k intervals. Viscosity at 100 deg C @9.9cSt: A solid SAE30 oil at 100 deg C. Now the problem is will it keep at 9.9cSt after 5k? Viscosity Index: or VI looks OK but if you can show me the HTHS, it is a much better indicator of how long the oil can last. Base Number: or TBN at 8.0 which shows this oil to be a normal PCMO. The question now is what is the TBN after 10k? Most oils will have 3.0 if they cover at least 70% highway. The rest not important. Link to post Share on other sites More sharing options...
EventH 1st Gear June 16, 2005 Author Share June 16, 2005 thanks ... I guess Mobil 1 is still better than SPC SYNACE Max. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 17, 2005 Share June 17, 2005 for spc only good one are the SL and SM rated synace oils and one or two of the diesel ones Link to post Share on other sites More sharing options...
Garlic 1st Gear June 17, 2005 Share June 17, 2005 Went tru' some threads in BITOG and some of the gurus there says SL has a better addictive package as compared to SM? Link to post Share on other sites More sharing options...
Genie47 1st Gear June 17, 2005 Share June 17, 2005 Yes it is true. SL has better additives. SM has better base oil. Most manufacturers' SM oil are blended. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear June 17, 2005 Share June 17, 2005 so u rather take SM or SL SM sounds kinky Link to post Share on other sites More sharing options...
Genie47 1st Gear June 17, 2005 Share June 17, 2005 I would still like SL. Some BITOGers think SM is suicidal. Link to post Share on other sites More sharing options...
D8jx Neutral Newbie June 30, 2005 Share June 30, 2005 So, what is the min HTHS number requirement for the best engine protection in our climate..?? Link to post Share on other sites More sharing options...
Seanboi 1st Gear November 28, 2006 Share November 28, 2006 API SL/CF: means can use in todays modern cars though the standard has just been superceded by SM. ILSAC GF3: Fuel economy oil but superceded by GF4 recently. ACEA A1-98: This oil is not going to last past 10k when traveling 70% highway. Less than 70% highway, change at 5k intervals. Viscosity at 100 deg C @9.9cSt: A solid SAE30 oil at 100 deg C. Now the problem is will it keep at 9.9cSt after 5k? Viscosity Index: or VI looks OK but if you can show me the HTHS, it is a much better indicator of how long the oil can last. Base Number: or TBN at 8.0 which shows this oil to be a normal PCMO. The question now is what is the TBN after 10k? Most oils will have 3.0 if they cover at least 70% highway. The rest not important. Bro sorrie to dig up such a old thread. Would like to ask u an oil with higher Vis @ 100 deg C value signifies wad? And is higher e VI e better or vice versa? Me looking @ Redline 5w30 and 10w30. http://www.redlineoil.com/pdf/4.pdf ↡ Advertisement Link to post Share on other sites More sharing options...
2019 Honda Accord PHEV Specs
Traffic light infrastructure
Understanding privilege
Replacing front tyres with different specs
Specs of the World CHEAPEST Car
Seeking help on understanding weird vacuum gauge
How to throw get rid of old specs
Lexus LFA N
Lexus LFA N
