Sash7 Neutral Newbie June 18, 2005 Share June 18, 2005 hi all bros and sis do anyone have this effect after u change to coilover? mine do have this problem when car is stock(but kind of minor vibrate).. recently i change to coilover it become quite bad to the extend that i can't really c wat car is behind me do u guys knw how to minimize this problem???? ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear June 18, 2005 Share June 18, 2005 could b ur engine mounting giving way soon.. Link to post Share on other sites More sharing options...
Sash7 Neutral Newbie June 18, 2005 Author Share June 18, 2005 wat? how to check the mounting bro? or have to sent it to wrk shop to check... always have to spend $$$ bro u knw the price if have to change? Link to post Share on other sites More sharing options...
Crv2004 Clutched June 18, 2005 Share June 18, 2005 hi all bros and sis do anyone have this effect after u change to coilover? mine do have this problem when car is stock(but kind of minor vibrate).. recently i change to coilover it become quite bad to the extend that i can't really c wat car is behind me do u guys knw how to minimize this problem???? My car also vibrate but with the same pace with my ICE Link to post Share on other sites More sharing options...
Sash7 Neutral Newbie June 18, 2005 Author Share June 18, 2005 huh?.. thats means is normal?? or maybe have to check wrkshop? really vibrate till can't c the car behind... bad situation cos especially must be wary of TP.. Link to post Share on other sites More sharing options...
Crv2004 Clutched June 18, 2005 Share June 18, 2005 huh?.. thats means is normal?? or maybe have to check wrkshop? really vibrate till can't c the car behind... bad situation cos especially must be wary of TP.. My one only minor only so not so bad man Link to post Share on other sites More sharing options...
Sash7 Neutral Newbie June 18, 2005 Author Share June 18, 2005 one and only me also one rear view mirror..... Link to post Share on other sites More sharing options...
Octopus 3rd Gear June 19, 2005 Share June 19, 2005 hi all bros and sis do anyone have this effect after u change to coilover? mine do have this problem when car is stock(but kind of minor vibrate).. recently i change to coilover it become quite bad to the extend that i can't really c wat car is behind me do u guys knw how to minimize this problem???? My rear view mirror is OK, doesn't vibrate so much that it affects vision. But parking under the sun will cause my rear view mirror (clip-on type) to distort the vision, and everything behind when looking thru the mirror will seems bigger and nearer. After driving a while and air-con cools the surrounding, vision will be restored to normal again. Link to post Share on other sites More sharing options...
Sash7 Neutral Newbie June 19, 2005 Author Share June 19, 2005 mine is also the clip on type... but is affecting my vision quite abit... so wondering any thing to make the situation better... Link to post Share on other sites More sharing options...
Octopus 3rd Gear June 20, 2005 Share June 20, 2005 If you remove the clip-on mirror and use the stock rear view mirror instead, is the vibration still affecting your vision? If your stock rear view mirror is OK, then probably the clip-on mounting is not good or not suitable. Link to post Share on other sites More sharing options...
Sash7 Neutral Newbie June 20, 2005 Author Share June 20, 2005 will try to do that... i thought was the clip on mirror problem... so replaced it... better but still vibrating... then i posted this topic.... sigh.. waste$$$$ again Link to post Share on other sites More sharing options...
Spango Clutched June 23, 2005 Share June 23, 2005 You kidding? Will the engine drop on the road when the mountings give way?!?! Link to post Share on other sites More sharing options...
Genie47 1st Gear June 23, 2005 Share June 23, 2005 When you change to coilovers, your engine mounts will suffer. Change the mounts every year or you will encounter the "engine suddenly dropped" as Steam has encountered on his Starlet. Yes, the engine suddenly dropped off. CLUNK! and the car stopped moving. With coilovers, the suspension is stiffer so much of the bumps from the road will transfer their energy upwards to your chassis and onto the mounts. The mounts will wear and so does the chassis. Link to post Share on other sites More sharing options...
Sash7 Neutral Newbie June 24, 2005 Author Share June 24, 2005 think next oil change better must ask the wrkshop to check those mounting man.... if engine drop off... sure gone case.... Link to post Share on other sites More sharing options...
Sotong_kia Neutral Newbie June 26, 2005 Share June 26, 2005 I had similar problems, but it is the vibration sound that I don't like.. Vision not too impaired. I did this and it reduced a lot : (1) Get a thick double-sided tape. (2) Stick onto the clip-on mirror at positions where it touches the stock mirror (the edge, and the clip, etc) (3) Do not use the other side.. I use it as a kind of "shock absorber sponge" for the clip on mirror.. That is why I only use one side of the double-sided tape. Link to post Share on other sites More sharing options...
Kongbabao Neutral Newbie June 30, 2005 Share June 30, 2005 alternatively blue tack can be used.. its reversible.. much more convenient.. =) Link to post Share on other sites More sharing options...
Sash7 Neutral Newbie July 4, 2005 Author Share July 4, 2005 i have check my clip on mirror... there is all round gap between the rear miror and the clip on mirror... so juz put some double side tape or blue tack there? hmmmm... or the clip should actually touch the rear mirror?? will try it out first... thanks for the advice guys.. ↡ Advertisement Link to post Share on other sites More sharing options...
Rear seat passenger : Do they belt up?
Blind spot mirror?
Blind spot mirror?
Come Share Your View on "Car-Lite City"
Is it illegal to fetch passengers at the back of a Suzuki Every?
Need Advice On Honda Fit 2008 (GE) Side Mirror Repair
Coaxial or Component for Rear speakers
Car side mirror films
Side mirror back cover replacement. where and how much?
