Andrewkb Neutral Newbie June 30, 2005 Author Share June 30, 2005 Hi, This is from the Honda workshop manual .. funny that it recommend to run it dry then pour in PSF !?! ↡ Advertisement Link to post Share on other sites More sharing options...
Genie47 1st Gear June 30, 2005 Share June 30, 2005 (edited) Wah! I can't stand the whining sound when the PSP sucks in air! Honda wants to reallly evacuate the system I think plus minimal waste. FYI, it is this WhRrrrrrr WhRrrrrr kind of noise. Very disconcerting and uncomfortable to hear. They run the car on fast idle to make the pump go faster and hopefully push out the air. Edited June 30, 2005 by Genie47 Link to post Share on other sites More sharing options...
Jkl78 Neutral Newbie June 30, 2005 Share June 30, 2005 oic. ok, thks. Mayb can try out tis method some day... Link to post Share on other sites More sharing options...
Jkl78 Neutral Newbie June 30, 2005 Share June 30, 2005 ya lor. run dry??? will it damage the power steering system like the pump??? Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 30, 2005 Share June 30, 2005 Not many professional mech in Singapore, we have many part changers and head choppers. You can use this simple hand operated brake bleeder to get the air bubbles out in seconds. The other device is a air lifter ( normally use for cooling system but can be adapted ) that will creat negative pressure in the sytem and use the vacuum to pull in the fluid. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie June 30, 2005 Author Share June 30, 2005 Can be a 6-week job if you DIY. The guys in the US do what they call the "Turkey baster" method. Take turkey baster and suck out as much PSF as possible. Top up with new PSF. Drive for 1 week, repeat. Do for 6 weeks and you will have virtually new PSF. I had did this in the past, but the fluid in the system is dark in color while fresh fluid is bright clear color. Pouring in, drive one week, suck out and pour in new one. But I noticed, that little reservior doesn't hold much fresh fluid and easily get "contaminated" once mixed with old fluid ..... Probably portion of fresh:old of 1:100 ! Link to post Share on other sites More sharing options...
Octopus 3rd Gear June 30, 2005 Share June 30, 2005 They are not self-bleed systems. So to prevent air bubbles, the turkey baster method is a sure win but you do have 0.0000x% of the old fluid left. The other method is to raise your car with jack stands (front only), turn on (not start engine), unplug the inlet tubing and turn the steering wheel left and right to pump the PSF out (draining from the inlet). To prevent bubbles, you continuously fill the PSF reservoir and not let it drain. A 2-man op much like the old way of bleeding brake fluid. You got to hand it to those USA DIYers. Damn tokong! Are Power steering system air-lock sensitive? I remember that when I had my power steering pump replaced, there isn't any issue with air-lock in the system.... The mechanic just 'unplug' the suction and discharge hoses of the power steering pump and hook-up a re-con pump. This will loose some power steering fluid so need to replenish the fluid in the reservoir chamber. After that just start the engine and the power steering pump will rotate (driven by belt) and can see the power steering fluid circulating (there are movement in the reservoir chamber). I don't remember the mechanic did any air-purging after this repair. Link to post Share on other sites More sharing options...
Genie47 1st Gear June 30, 2005 Share June 30, 2005 I wouldn't say they are sensitive but it makes this awful whirring noise when air is in the system. very uncomfortable, loud and irritating. When you replenish the fluid, it means the air has been released. The pump has primed the air out. Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 2, 2005 Share July 2, 2005 But seriously lah! For no mess, use turkey baster method. Cheaper, cleaner and not so kanchiong. For "No Mess", method I used was very successful. My PS system was leaking slightly (as I think the rubber seals were hardned), so had to keep topping up every month or so. I used my RP fully synthetic ATF (which contains alot of esters) to top up. By the time I used about 2 qts, the leak stopped. So I actually killed 2 birds with one stone. Stopped the leak & changed my PS fluid. This is a true story. Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 3, 2005 Share July 3, 2005 Humm.... ATF in power steering fluid? Will that cause any bad effect? Can ATF totally replace the power steering fluid or it just act as an additive? Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 5, 2005 Share July 5, 2005 My car uses Dexron ATF as PS fluid. Check your handbook for what is required for your car. Link to post Share on other sites More sharing options...
Genie47 1st Gear July 5, 2005 Share July 5, 2005 Most of the US guys in cars requiring traditional PSF swapped it out and used ATF with good results. They say the steering so much better. Link to post Share on other sites More sharing options...
Andrewkb Neutral Newbie July 5, 2005 Author Share July 5, 2005 Flushed my ATF last weekend. Surprisingly very little spill ! Took out the return hose, plug a clear water hose to it and cover the exposed pipe. Turn the steering (car jacked up) and keep topping up, what came out is dark brown while what goes in is clear. Repeat till clear fluid seen/run out of new fluid. Sounds easy, but the cramped engine bay gave a few more cuts on my hand, and the mouth of the reservior is soooo small, end up spilling more from topping up :-( Result: The steering seems to feel a lot lighter for a start, and recovers to normal later. Better steerign feel? Dunno ... but at least I know I've new PSF in there :-) Peace of mind ... Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 6, 2005 Share July 6, 2005 [reply] My car uses Dexron ATF as PS fluid. Check your handbook for what is required for your car I don't have the car's handbook/instruction manual ......anyway, I think should be same specification as yours since you're also driving a Toyota? The last time I had my power steering pump replaced the mechanic top-up the power steering fluid with Toyota brand steering fluid. I wonder if that's equivalent to "Dexron ATF"? Link to post Share on other sites More sharing options...
Octopus 3rd Gear July 6, 2005 Share July 6, 2005 [reply] Most of the US guys in cars requiring traditional PSF swapped it out and used ATF with good results. They say the steering so much better. I see......so basically PSF can be replaced with ATF? Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 6, 2005 Share July 6, 2005 Just to b safe, check if any bros has the handbook for your model. It sud b stated in there. I don't know what is inside Toyota PSF. Maybe u cud also check with BM or your mech if yours is Dexron. I don't know if there is an "equivalent" for Dexron as it is a type of ATF like diaqueen & mercon. It says in my handbook that my PSF is Dexron, so I use it. I always try to stick to what the MANUFACTURER states NOT what the AGENT says. Agents either don't know or advise what they can make the most $$$ from u. Link to post Share on other sites More sharing options...
Jonbummer Neutral Newbie December 2, 2006 Share December 2, 2006 But seriously lah! For no mess, use turkey baster method. Cheaper, cleaner and not so kanchiong. For "No Mess", method I used was very successful. My PS system was leaking slightly (as I think the rubber seals were hardned), so had to keep topping up every month or so. I used my RP fully synthetic ATF (which contains alot of esters) to top up. By the time I used about 2 qts, the leak stopped. So I actually killed 2 birds with one stone. Stopped the leak & changed my PS fluid. This is a true story. hi bro sorry to dig up this old thread but having the same problem with the PS leaking somewhat so need to ask u where to get 'RP fully synthetic ATF' so i may try to rectify the prob myself thanks in advance! Link to post Share on other sites More sharing options...
Upguy1 Clutched December 4, 2006 Share December 4, 2006 Most of the US guys in cars requiring traditional PSF swapped it out and used ATF with good results. They say the steering so much better. any experience in the local setting ??? intend to use toyota type IV ATF as my PSF next servicing ..as i still got about 3L left in the wardrobe ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Carbonics Cold Air Intake System - Full Handmake CF
Changing halogen to LED
Steering leather wrapping
Porsche’s First Steer-By-Wire System Is Designed For Less Feedback, Not More
