Ah_veo Neutral Newbie July 22, 2005 Share July 22, 2005 anyone can verify? assuming on a stock car..... mine abt 1yr 4mths liao.....milege juz above 20k. battery still seems ok leh.... but i remember someone here who need to change juz b4 1 yr old. average.....can last how long har??? ↡ Advertisement Link to post Share on other sites More sharing options...
Vit4wd 1st Gear July 22, 2005 Share July 22, 2005 I'm not exactly sure how long maintainence free batteries can last, but they do not last as long as the conventional batteries where you need to top up battery water. My conventional battery is already 37 mth old, still working strong. Can anyone also explain how the inside of a maintenance battery is different from a conventional battery, such that it does not need battery water top up. Link to post Share on other sites More sharing options...
Brock 1st Gear July 22, 2005 Share July 22, 2005 Ah_Veo, If I remember correctly, my SE told me the stock batt that came with our Aveo can last 18 months. Maybe some1 here can provide more info? Link to post Share on other sites More sharing options...
Jkl78 Neutral Newbie July 22, 2005 Share July 22, 2005 read tis... http://www.repairfaq.org/ELE/F_Car_Battery.html Link to post Share on other sites More sharing options...
Crv2004 Clutched July 22, 2005 Share July 22, 2005 i just change the battery too. The ols one lasted me 40K and about 1 year plus Link to post Share on other sites More sharing options...
Takanori Neutral Newbie July 26, 2005 Share July 26, 2005 Heard from my technician frenz say tat normal maintainence free batt can last 4 ard 2 yrs. Link to post Share on other sites More sharing options...
Botak Neutral Newbie July 31, 2005 Share July 31, 2005 Hi, it depends on how u use it! With ICE, I think it will have shorter lifespan. Normally around 2yrs /40 K. My 30K servicing at 18 mths old already recommended to change but I tell SA that I will change it at 24 mths, they said no problems but remember to top up the battery water. Link to post Share on other sites More sharing options...
Ahmadjbs Neutral Newbie August 12, 2005 Share August 12, 2005 Mine last for 1yr 1 month.Battery supposed to last at least 2 yrs.And what the chevy told me?Its manufacturer problem. Link to post Share on other sites More sharing options...
Tien Neutral Newbie August 14, 2005 Share August 14, 2005 (edited) durability depends on how one uses the car and the battery. an easy way to check is to monitor the time required to start your car in the morning. as the battery gets weaker, the cracking takes longer. seldom battery will just die out of sudden so you should have enough "warning"/signs & time to replace. also check the exterior walls of the battery. you will notice swelling (outwards) if a battery is old... best method is to visit a workshop and ask them check your battery for you with a volt meter Edited August 14, 2005 by Tien Link to post Share on other sites More sharing options...
Chevro Neutral Newbie August 15, 2005 Share August 15, 2005 What voltage is normal? low warning? and dead? for a battery. Link to post Share on other sites More sharing options...
Lukie102 Clutched August 15, 2005 Share August 15, 2005 not old also got swelling leh Link to post Share on other sites More sharing options...
Xavier Neutral Newbie August 15, 2005 Share August 15, 2005 Heng 2yrs, suay 1yr. Very suay, anytime. Link to post Share on other sites More sharing options...
Genie47 1st Gear August 16, 2005 Share August 16, 2005 Change your batter at the 2nd anniversary of getting your car just to be safe. Link to post Share on other sites More sharing options...
Genie47 1st Gear August 16, 2005 Share August 16, 2005 You can never tell from the voltage but if you got one of those that check for charging that the mechanics use, it is better. Then again you can check the hydrometer. More water or lower specific gravity means battery going to die soon. This only applies to the wet maintenance types. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear August 16, 2005 Share August 16, 2005 changed mine after 1 year 9 months. Link to post Share on other sites More sharing options...
Genie47 1st Gear August 16, 2005 Share August 16, 2005 Aiming for every 2 years. Like someone has said, sway 1 yr. Heng 2yrs. Link to post Share on other sites More sharing options...
Tploh Clutched August 16, 2005 Share August 16, 2005 and very heng, 3 yrs. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear August 16, 2005 Share August 16, 2005 I'm quite heng then... consider the fact that I have so much stuff draining the batt.. ↡ Advertisement Link to post Share on other sites More sharing options...
My EV journey to the i4
MALAYSIA TIPS - Long Distance Driving Trips
Battery for Honda Vezel
