Genie47 1st Gear September 2, 2005 Share September 2, 2005 You got the amount from your user's manual? 2-7/8 qts is very little! Incredible! It puts your car to the same league as Mazda Protoge which also uses around 3qt of oil as well. ↡ Advertisement Link to post Share on other sites More sharing options...
Lukie102 Clutched September 3, 2005 Share September 3, 2005 giant selling $10.90. Link to post Share on other sites More sharing options...
Valjean Neutral Newbie September 3, 2005 Share September 3, 2005 Yup just double-checked the technical specs. It says 2 7/8 qts with oil filter change and 2 3/4 without. But I kiasu so bought 4 quarts at IMM Giant just now. Link to post Share on other sites More sharing options...
Kanr 1st Gear September 3, 2005 Share September 3, 2005 basically, most of the new car can use all types of engine oil in the market.Just remember to services yr car promptly so tats it can help to reduce wears and tears ,thks!!Cheers!!! Link to post Share on other sites More sharing options...
Genie47 1st Gear September 3, 2005 Share September 3, 2005 Funny. Neither here nor there for the oil volume. OK use loh! Link to post Share on other sites More sharing options...
Kanr 1st Gear September 3, 2005 Share September 3, 2005 if u can afford a better grade of engine oil e.g Mobil One Gold,of course it will be good for yr vehicle!!!Otherwise , try the next best type available,Cheers!!!! Link to post Share on other sites More sharing options...
Genie47 1st Gear September 3, 2005 Share September 3, 2005 Actually it should be next best grade or API service category if you can. Synthetic or not does not make a difference. Only difference is lighter pocket. If you race and speed revving and burning petrol, synthetic will indeed make a difference but for daily driving, hardly so. Link to post Share on other sites More sharing options...
Lotus4712 Neutral Newbie September 16, 2005 Share September 16, 2005 I got Mobil 1 engine oil 0W-40 to spare (SM). Production batch 2005. Anyone interested ? Purchase at $11 per quartz. This formulation is smooth and fuel saving for new engines. IMO, W-30 oil may be quite thin when engine operating at high temp. As a guide at ard 100 degree C, viscosity level drops from 20 down to 10 from a W-50 to W-20 oil. Have to worry about the protection the oil provides. So to be safe I wld not go below W-40. 0W-40 i think is a safer and better choice. I have used it and is fully convinced. Link to post Share on other sites More sharing options...
Genie47 1st Gear September 16, 2005 Share September 16, 2005 From Darklord, his oil temp gauge shows 70 deg C when using 10W30 around town for normal driving. You will see higher operating temperatures for a 0W40 due to the frictional heat generated from the oil shear. Always choose an oil that gives your engine lower oil temperature. The 100C viscosity is the ideal but most engines never hit 100C on street conditions. Link to post Share on other sites More sharing options...
BoneStock 5th Gear September 16, 2005 Share September 16, 2005 You got the amount from your user's manual? 2-7/8 qts is very little! Incredible! It puts your car to the same league as Mazda Protoge which also uses around 3qt of oil as well. Sunny also uses ~3quarts(~2.8L) only. Link to post Share on other sites More sharing options...
Genie47 1st Gear September 16, 2005 Share September 16, 2005 I think all these small sump cars better use syn oil. Not much oil to buffer against the oil that is already whacked until all the juice come out. Link to post Share on other sites More sharing options...
Defelio Neutral Newbie September 23, 2005 Share September 23, 2005 Genie47, need yur advise. My oil temp reaching 98C on street conditions liao leh.. How? I'm using cxxxxxe 5W30 bought from suntec.. I just bought the M10W30 from Giant, should i change asap? Thanks Def Link to post Share on other sites More sharing options...
Genie47 1st Gear September 24, 2005 Share September 24, 2005 cxxxxxe is 5W40. Could be because it is thick. It will not kill the engine. Just use to your car's specified oil change interval. No hurry. Change to M1 10W30 or any 10W30 and see if there is any improvement. Link to post Share on other sites More sharing options...
Defelio Neutral Newbie September 24, 2005 Share September 24, 2005 Oh Yeah, it's 5W40. Thanks! Link to post Share on other sites More sharing options...
Mach Clutched September 28, 2005 Share September 28, 2005 I just bought 1 bottle M1 10W30 (green cap) SL grade as needed 1 more bottle for servicing. Found out later that the 4 bottles I have are M1 5W30 (blue cap) Anyone want to swap with me ? Either 1 bottle of Mobil 1 5W30 with my 1 bottle Mobil 10W30 Or Swap 4 bottles 10W30 with my 4 bottles 5W30.... Link to post Share on other sites More sharing options...
Anakin Clutched September 28, 2005 Share September 28, 2005 any problem to just go ahead & use them together?? Link to post Share on other sites More sharing options...
Genie47 1st Gear September 28, 2005 Share September 28, 2005 No problem. Just mix and use. Link to post Share on other sites More sharing options...
Mach Clutched September 28, 2005 Share September 28, 2005 I think so also, but since I'm bringing own oil to my car agent for servicing (which they frown upon already), didn't want them to make any issues over the type of oil used. Thanks for the advice. ↡ Advertisement Link to post Share on other sites More sharing options...
Shell? Esso? Mobil? Caltex? SPC
Mileage 110k, Should use 5W30 or 5W40
5W30 or 5W40 Engine Oil Is Better For Your Car?
Now Giant's turn to offer Mobil 1 engine oil!
5w30 vs 5w40
5w30 vs 5w40
Cara daftar uber motor dan mobil online langsung approved
Engine oil for 2008 Kia Rio
Caltex vs Essomobil vs Shell vs SPC
