Showtime Neutral Newbie August 9, 2005 Share August 9, 2005 if the side wall is puctured (small hole), can it be patched up using the commonly used $7 ish tyre plug? ↡ Advertisement Link to post Share on other sites More sharing options...
Jchuacl Clutched August 9, 2005 Share August 9, 2005 No, don't take the risk. Better go to tyre shops to double check as sidewall puncture is more serious. You can go to South East at Kaki Bukit for Ah Hoe to take a look. Link to post Share on other sites More sharing options...
Sky8807 1st Gear August 9, 2005 Share August 9, 2005 Sidewall puncture patch is unsafe. Tyres flexes during operation and rotating all the time. Definately not a wise decision to patch. Link to post Share on other sites More sharing options...
Showtime Neutral Newbie August 9, 2005 Author Share August 9, 2005 so should change tyre? Link to post Share on other sites More sharing options...
Sky8807 1st Gear August 9, 2005 Share August 9, 2005 If u want to do a patch, it shd be temporary until u get a new tyre. If your driving is fast and lot of corners, then changed it. If your driving is slow and steady, then the risk is a lot lower, but keep in mind that the hole may open up and crack, so daily check for deterioration is necessary. Personal Safety is more important then the cost of tyre. Link to post Share on other sites More sharing options...
Showtime Neutral Newbie August 9, 2005 Author Share August 9, 2005 yep... so i guess i have made up my mind already.. definitely safety first. Link to post Share on other sites More sharing options...
Sky8807 1st Gear August 9, 2005 Share August 9, 2005 Link to post Share on other sites More sharing options...
Safetyfirst Clutched August 9, 2005 Share August 9, 2005 Suggest U change the damage tyre IMMEDIATELY. Be Safe Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 14, 2005 Share August 14, 2005 Depends on the type of tyres - if it is low profile type with soft sidewall then you may have to do cold patch from inside. Make sure the tyreman use a correct sidewall patch. If the sidewall injuire is a long cut, then suggest you get retire the tyre. Link to post Share on other sites More sharing options...
Jchuacl Clutched August 15, 2005 Share August 15, 2005 Dangerous advice!!!! I suggest that people don't take his word(on cold patching) for it if you value your life. Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 16, 2005 Share August 16, 2005 (edited) I don't know who you are and your technical background in tyre repair and service. Why cry "wolf" when you maybe not sure of the technology behind radial tyre cold patches.Why not give your explaination as why the repair is technically not sound. I use to have thick folders on tyre repairs , tools and equipment on my desk besides sample of special auto tools and testers when I was very active in selling and marketing in the auto service industry. I have make a search for the files just an hour ago but apparent due to space contraint in my pigeon hole, they were sold off many years ago to the garan guni man. Anyway, with the keyboard, I managed to locate a site selling side wall patches which may interest you http://www.jackssmallengines.com/ch_tire_patchkits.cfm Edited August 16, 2005 by Yeobh Link to post Share on other sites More sharing options...
Remygenn Neutral Newbie August 16, 2005 Share August 16, 2005 u definitely nailed him to the coffin. the one who post is a newbie ... often they will cries out wolf wolf wolf .. Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 16, 2005 Share August 16, 2005 Only one nail, still got few more in hand.Hope he return to learn more Link to post Share on other sites More sharing options...
Roberttan 5th Gear August 16, 2005 Share August 16, 2005 I appreciate your effort in searching the info to share here. just MHO,looking at the introduction about the repair kit I have questions here who is competence to carry out the repair job properly? espeacially removing the tyre out from rim for those very low profile tyre? that is why many shops are still going by easier way just plug repair from outside without removing out. almost all tyre maker had always advice no sideway repair is recommended even is from internal patch beacuse you will not know the repaired tyre can withstand how fast speed you travel and how heaving load you carry? so you have to judge your own view here. If we think the repair just only to stop the leak I am tell you we could be wrong. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged August 16, 2005 Share August 16, 2005 (edited) "...who is competence to carry out the repair job properly? espeacially removing the tyre out from rim for those very low profile tyre? that is why many shops are still going by easier way just plug repair from outside without removing out..." Actually most good tyres shop (eg. SE tyre, Stamford, etc) can do such repair. The likely reasons I can think of why this method is not the norm is a combination of ignorant consumers and incompetent tyres mech. Patching the sidewall is not always possible, a lot depend on the condition of the tyre...but it can be done safely. Edited August 16, 2005 by Silver_blade Link to post Share on other sites More sharing options...
Jchuacl Clutched August 16, 2005 Share August 16, 2005 U sound like you have an axe to grind with me and is challenging me? Have I offended you? Anyway, I'm not interested to pick fights with people in the forum and have nothing to prove. Link to post Share on other sites More sharing options...
Roberttan 5th Gear August 16, 2005 Share August 16, 2005 my friend last time went ST they just did the pulg mathod. not sure now may be they changed? combination of ignorant consumer incompetent tyre mech also $,so sometime could be more cost effective to change your tyre if the repair cost is to high or tyre is not in good condition if you travelling long distance better don't repair side wall is MHO Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 16, 2005 Share August 16, 2005 Hold your horse, we are here to help each other to understand more about cars, we are here to meet people of the same interests. We are not in the boxing ring neither we are here to show off our ability and knowledge. Hope you will kindly allow this matter to rest. ↡ Advertisement Link to post Share on other sites More sharing options...
Tyre puncture
Tyre puncture
Would you help to change another car's tyre in another country?
Large screw punctures man's motorcycle tyre along TPE -- a month after he paid $650 to change it
Car Tyre Puncture Repair
Puncture Proof Sealant
Anyone tried tire coating to prevent puncture?
What a way to start the long wkend...
