Extractor mod... Mod or not mod??
Sei_fei_loh
Hi all..
went to JB today and understand its cheap to change the extractor.
the guy says it better to use a 4-1 extractor. but it seems most of u are using 4-2-1. which is better?
by changing the extractor, is there a significant increase in noise? he said after changing the extractor, still can pass inspection. hw true?
thanks
From what I've read 4-2-1 extractors will give betta low end torque and 4-1 gives more high end power. Think most cars wud come stock with a 4-1 exhaust manifold. The stock ones are usually optimised for economy as well while after market ones are usually tuned for more power. The length and bore of the extractor has to match the power characteristics of your car else you might end up losing power in the end.
After mkt mufflers usually provide better flow for the exhaust gases. On the downside, they are usually noisier due to the better flow. LTA approved mufflers cost many times more than non-approved ones.
It's more of a slight hissing noise rather than a rattling sound. If there's a rattling sound, the installation was most probably not done correctly.
The hissing noise is due to the fact that the after market extractor has thinner side walls for the piping than the stock exhaust manifold. The high velocity at which the exhaust gases travel hit the walls on exit from the combustion chamber causing the noise.
I'm not too sure if those 'branded' after mkt extractors made of stainless steel has the same issue but they usually manufacture for high performance NA or Turbo cars only.
if u usually drive in the low-mid end range and wants improvement in this region, go for 4-2-1 extractors with high-flow cat. [thumbsup]
4-1 is definitely for high end gains. high-flow cat will still remove the toxic stuff from the exhaust gases and more importantly, preserve some back pressure for good low-mid end
hi there.. do u haf any idea how much it'l cost to do a 4-2-1 extractor in jb? I juz checked w foongkim that it'l be ard S$400++ .. wonder if it's cheaper over there?
yAs
bro...Man Exhaust doesnt haf a webbie. If u wan, here's their contact:64587053. If u are looking at extractor, they costs u abt $180. however if u have uncommon ride like my primera, they can custom-make one for u for $280.
