Lanceteo Neutral Newbie September 15, 2005 Share September 15, 2005 sitting down is worst la.. haha but whn u de cat it its standing up or sittign down standing? haha ↡ Advertisement Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie September 15, 2005 Share September 15, 2005 (edited) Got use lah...... But do note that it's Environmentally Irresponsible to do that ....because the emission will pollute the air we breathe and causes the Greenhouse effect ...this will Possibly cause human destruction in about 30000000000 zillion years down the road ...your children's, grandchildren's, grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's,grandchildren's, might suffer because of this....THINK! Edited September 15, 2005 by Wolverine Link to post Share on other sites More sharing options...
Beachboys Clutched September 15, 2005 Share September 15, 2005 do NOT decat for auto cars.. u lose your low-end immeditately... auto cars need some back-pressure no matter what Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie September 15, 2005 Share September 15, 2005 Dun think Cat does anything to your back pressure.... Link to post Share on other sites More sharing options...
Kiwi Neutral Newbie September 15, 2005 Author Share September 15, 2005 So jia lat ar? Problem is dat I just went for my 80k servicing. Was told my cat is due for replacement. Will set me back by $3k+. So I thought maybe I'll do the Remus ($600+) and remove the cat as it is broken and making a lot of noise. Any suggestions from you guys? Link to post Share on other sites More sharing options...
Kiwi Neutral Newbie September 15, 2005 Author Share September 15, 2005 BTW I'm driving a manual car..how will the back pressure affect performance? Link to post Share on other sites More sharing options...
Beachboys Clutched September 15, 2005 Share September 15, 2005 oh yah.. backpressure is affected by semi/stright thru muffler~ nutin to do wif Cat? Link to post Share on other sites More sharing options...
Beachboys Clutched September 15, 2005 Share September 15, 2005 if manual n u want to maximise performance, decat + change to free-flow stright thru~ Link to post Share on other sites More sharing options...
Contax 1st Gear September 15, 2005 Share September 15, 2005 LTA 101% CONFIRM DOUBLE CONFIRM PASS untill dunno where and back and pass again upsidedown inside out turn one round still pass untill the juice come out...I just passed ....Dont replace with dummy ....do a "KNOCK" and retain the original cat ..... I do a decat on the same week as my inspection hahaha Hmm...can pass ahh?What do you mean by "dont replace with dummy...do a "KNOCK" and retain the oroginal cat..." - lieh-bo-quee-leh Link to post Share on other sites More sharing options...
Sliderzhil Clutched September 15, 2005 Share September 15, 2005 Beachboys u r confusing the auto drivers out there... so does it affect or not? anyway de-cating aka "knocking" cost as low as $40?? Link to post Share on other sites More sharing options...
Hyun Neutral Newbie September 15, 2005 Share September 15, 2005 tried to read up a bit about auto cars needing backpressure but i didn't quite understand the technical bits. what's the difference between auto and manual needing backpressure? it's the same engine, the same exhaust setup. the only difference between auto and manual is in the transmission. so logically speaking, the exhaust has no relevance to the transmission. exhaust only affects the engine. so if a manual car engine improves with exhaust mod, the auto should also improve. can any1 explain the reason? Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie September 15, 2005 Share September 15, 2005 Basically u want to REMOVE the bloody restrictive CAT...one way is to pluck out the original and replace with a free flow....that looks really obvious...but cool ....then the other way is to Knock the damn catalyst out of your original CAT box.....Do the latter...pass inspection Link to post Share on other sites More sharing options...
Contax 1st Gear September 16, 2005 Share September 16, 2005 (edited) Thank you. Scarli they use a mallet to knock knock the cat and discover that it's hollow inside.... then chia-luck-liao "sir , your cat just pass out with a hollow heart , please come back some day when your cat is healthy again.Thank you , we will retain the consultation fees.See you again,bye!" Edited September 16, 2005 by Contax Link to post Share on other sites More sharing options...
Dtoh Neutral Newbie September 16, 2005 Share September 16, 2005 Hi... How abt tis.... Do it like hoe flow thru is done. De-cat, do a flow thru welded from manifold to exhaust with the De-Cated and fill the empty space in the Cat wif the same type of mat'l as in the exhuast. Wat you guys tik??? Link to post Share on other sites More sharing options...
Yeobh 4th Gear September 16, 2005 Share September 16, 2005 No need to knock , they just use a infra-red non contact thermometer to check exhaust temp at pre-cat and post cat. If there is no differenct in temp chances it is a dummy or the cat is faulty. If the cat is faulty normally it will indicated by high CO & HC emission readings. Link to post Share on other sites More sharing options...
Jchuacl Clutched September 16, 2005 Share September 16, 2005 When I went to Vicom for inspection after installing aftermarket exhaust, the guy at the inspection did do some tapping when he went under the car to look at the entire setup from the engine bay till the exhaust tip. Link to post Share on other sites More sharing options...
Bcyn Neutral Newbie September 16, 2005 Share September 16, 2005 i'm still a little lost. after i de-cat, wat kinda positive/negative effects do i expect to see in an auto car? u also said inspection pass. i always thought those pple juz knock ur exhust a couple of times can hear its hollow, den stick something into the exhust pipe to measure dunno wat... at man, de-cat cost 40, how abt the welding of tips? roughly? sorry ah... a bit confused as i havent ventured into the exhuast area before. Link to post Share on other sites More sharing options...
Wolverine Neutral Newbie September 16, 2005 Share September 16, 2005 I think u just choose the tips ...include welding ..there is a big basket of tips for you to choose on the racks at the back of the wrkshop...i did one about 50 bucks....nice chrome one....If you did inspection B4 u will know that those ah beng ah seng doing inspection is like lazy untill dunno where...anyhow put the probe in...if your car is not 200 years old ..without a CAT will still pass ....i did ...3 weeks ago ..i have a 3yr old car w/o cat....Dont hope they will use any SUPER DUPER INFRA RED X-MEN SUPER GAMMA POWER RAY to shine on your exhaust hahahahah ↡ Advertisement Link to post Share on other sites More sharing options...
