De-cat
Kiwi
think the terms high-flow and free-flow are used loosely... better to ask the workshop whether the inside got any cat converter stuff to confirm.
high flow cat usually mean there are still catalytic converter stuff inside but less and insides are designed for better flow rate. from wat i know, high flow cats are still pretty effective at getting rid of nasty stuff but their life span is significantly shorter (bcos of less cat converter stuff i suppose)
free-flow cat are those without any cat con stuff inside them. just an empty shell which offers no obstruction to exhaust. obviously, this is much cheaper than a high-flow cat.
erm...oh...ya, what i mean is free flow...smile.gif a dummy cat is around that price...
ok...
my ride is lancer very sluggish .. tinking of extractor & muffler too but will coz noisy
[thumbsdown] i wan not noisy n got power best is gd fc oso [laugh]
tried to read up a bit about auto cars needing backpressure but i didn't quite understand the technical bits.
what's the difference between auto and manual needing backpressure? it's the same engine, the same exhaust setup. the only difference between auto and manual is in the transmission. so logically speaking, the exhaust has no relevance to the transmission. exhaust only affects the engine.
so if a manual car engine improves with exhaust mod, the auto should also improve.
can any1 explain the reason?
auto changes the gear for you, so you'll free a bit of lost in low end but manual you can choose which RPM you want to upshift, normally it still looses some low end to manual cars but that can be equalise by up shifting at a higher RPM sly.gifsly.gifsly.gif
Hi bros, decat my ride and now it's straight thru, find the exhaust smell really terrible, cannot tahan the smell when I warm uP and cool down my engine. Is it a must to de cat it?
If not performance cars, it wasting time & $ de cating.
Shouldn't have done it, all this for little performance gain.
Decat alone is useless. You need a good set of extractors and exhaust to match.
Also. decat also benefits for high RPM and turbo/SC where the cat becomes a restriction in airflow. At low RPM, there are no benefits.
not really, if you have seen what its in the cat, you should know what kind of restriction we r talking abt... the cat is the bottleneck of the whole exhaust system. removing the cat will bring quite significant performance in high-end.
this is true, in fact, u will suffer if on your low end if your whole exhaust system is 100% straight thru.
dun think its that bad, if you can smell it in your car while warming up the engine, something its wrong. i believe your exhaust its leak..
by the way, what do u mean by u can still smell the exhaust when cooling down your engine? if you are trying to cool down your engine, you shld have switch off your engine rite? and u still can smell the exhaust fume?? u sure its not your engine thats caught fire? LOL
Edited by Tigershark1976
