Turbonetics 2nd Gear January 20, 2006 Share January 20, 2006 (edited) having some urge yesterday to try my car for 100 metre... the timing i guess was bad....ard 7.5sec and speed was 70km/hr... any of u tried timing before... care to share ur result.... iam using the RSM to test.... Edited January 20, 2006 by Turbonetics ↡ Advertisement Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie January 20, 2006 Share January 20, 2006 With or without G sensor ? Link to post Share on other sites More sharing options...
Hmanxx 2nd Gear January 20, 2006 Share January 20, 2006 what car are you driving ? the final speed seems low, , Link to post Share on other sites More sharing options...
Tyreboy Neutral Newbie January 20, 2006 Share January 20, 2006 interesting...however i would like to know did you test your car braking response from 100km to 0km??? how long does it take?? Remember: 0-100km is to die sooner 100-0km is to live longer Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 20, 2006 Author Share January 20, 2006 with the G-sensor... without G-sensor can test meh??? Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 20, 2006 Author Share January 20, 2006 honda civic esi.... yah...i think so... Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 20, 2006 Author Share January 20, 2006 i din test that leh.... btw,i think RSM cannot test that... anyway its 0-100 metre not 100km/hr... Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 20, 2006 Author Share January 20, 2006 anyway,i will try the test again... cos when i tried,when i almost reach 100metre,there is a slope.... so when iam halfway,i realease my acc.... but i duno when i release that time,i already reach 100 metre or not... if already reached,then the timing shd be quite accurate... if not,i will try again...see if can achieve better top speed and shave off 1-2 sec... Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie January 20, 2006 Share January 20, 2006 (edited) Why not ?? Only thing is that its inaccurate. By the way I wouldn't advice you rely on the readings given by RSM. After all, your variables changes daily. My $0.02 cents Edited January 20, 2006 by BMW320i Link to post Share on other sites More sharing options...
BlueSi Neutral Newbie January 20, 2006 Share January 20, 2006 You gotta make sure the road is flat all the way till the end of your test, no ups or downs. Its very important to calibrate the G-sensor right before starting. How accurate it is, thats debatable, but if you're trying to improve from yourself, test it in the same place and try to test in same temp. conditions too. By the way, 7.5sec for 0-60 sounds abt right for an NA civic. Mine does around high 6s to low 7s as well. Its the car man! low torque and F-up traction ...... Link to post Share on other sites More sharing options...
Blitzza Neutral Newbie January 21, 2006 Share January 21, 2006 Try 0-100km. Link to post Share on other sites More sharing options...
Koren Clutched January 21, 2006 Share January 21, 2006 no need test ar.. mine takes foreva to reach 100 Link to post Share on other sites More sharing options...
BMW320i Neutral Newbie January 21, 2006 Share January 21, 2006 (edited) Can beat mine or not ? 0-100kph in 30 secs. Edited January 21, 2006 by BMW320i Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 21, 2006 Author Share January 21, 2006 u mean 0-60km/hr or mph??? anyway,the calibration for my G-sensor might not be accurate... but i compare the speed with my speedo is abt the same.. iam using a 15" 50 profile tyre... i think standard shd be 55 profile for 15" right??? Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 21, 2006 Author Share January 21, 2006 tried before liao... its takes abt 11 sec... Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 21, 2006 Author Share January 21, 2006 lol....forever.... anyway 100 metre is not long mah.... i think 7 sec can lah.... the record breaker for athelete for 100m sprint is between 9-10sec.... my car is only 2 sec faster than him.... Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear January 21, 2006 Author Share January 21, 2006 i can break ur record.... u want faster or slower record,i also can break.... Link to post Share on other sites More sharing options...
Potheader Clutched January 21, 2006 Share January 21, 2006 usually i tot its 0-100kmh? and not 0-100m. ↡ Advertisement Link to post Share on other sites More sharing options...
Class 4 Driving License
testing again
testing again
test
test
Crash test results
Crash test results
You must be notified, again!
embed tests
embed tests
Test forum upg
Test forum upg
