Tey13 Neutral Newbie February 17, 2003 Share February 17, 2003 any advice?? recently i went for servicing and the person told me that the front tyre is worn off. (by checking the safety point of the tyre is align with the threads) He also says that when the front change twice, the rear tyres only change once.....is it the correct assumptions??? ↡ Advertisement Link to post Share on other sites More sharing options...
Blueice Neutral Newbie February 17, 2003 Share February 17, 2003 well roughly there abouts, it depends on how you drive too. generally fronts wear out faster than rears, due to steering, braking, etc. Link to post Share on other sites More sharing options...
Wintersonata Clutched February 17, 2003 Share February 17, 2003 That's why we should go for regular tyre rotation.... in order to lengthen the lifespan of the tyres by allowing them to wear off evenly... Link to post Share on other sites More sharing options...
Smiley Neutral Newbie February 17, 2003 Share February 17, 2003 think is about there, that's why we need to rotate the tyres. Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 17, 2003 Share February 17, 2003 Do it every 10K......... Link to post Share on other sites More sharing options...
Tey13 Neutral Newbie February 17, 2003 Author Share February 17, 2003 but some recommend every 5k to rotate it??? which is better?? Link to post Share on other sites More sharing options...
Edwyn Neutral Newbie February 17, 2003 Share February 17, 2003 Follow ur service interval... u will not go wrong Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 17, 2003 Share February 17, 2003 TO save some $, I do it every 10k....if not every 5k would be good.... Link to post Share on other sites More sharing options...
Virus 2nd Gear February 17, 2003 Share February 17, 2003 (edited) Just curios, what is the best rotating method you guys do? 1) Front to back and vi versa, or 2) diagonally (front with back opposite side). I know that method 1 is required for directional tires. Cheers Edited February 17, 2003 by Raptor Link to post Share on other sites More sharing options...
Saaber Neutral Newbie February 17, 2003 Share February 17, 2003 Method 2 if the tyres are bi-directional..... You can check www.tirerack.com for more info........... ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Washing machine front loading
Tyre puncture
Tyre puncture
Rear seat passenger : Do they belt up?
