Carq Neutral Newbie February 12, 2006 Share February 12, 2006 can my current tyres nitrogen gas mix with normal air pump gas?? Pls advice.. ↡ Advertisement Link to post Share on other sites More sharing options...
Picantorianhub Neutral Newbie February 12, 2006 Share February 12, 2006 Sorry ah bro ask u where can pump nitorgen into the tyres ah? Can last 4 how long? Sorry curious Link to post Share on other sites More sharing options...
Furrynadz 5th Gear February 12, 2006 Share February 12, 2006 air is 78% nitro, why not? just that u change the % Link to post Share on other sites More sharing options...
Furrynadz 5th Gear February 12, 2006 Share February 12, 2006 autobacs/stamford tyres/most of the shops in ubi/the more famous shops eg SE tyres.. topup every 2month or so enough at most drop 1 or 2 psi Link to post Share on other sites More sharing options...
Carq Neutral Newbie February 12, 2006 Author Share February 12, 2006 i pump in JB. RM5 each tyre. U can also go Auto saver at kakit bukit. The price not sure but they give u free during servicing[cool] Link to post Share on other sites More sharing options...
Picantorianhub Neutral Newbie February 12, 2006 Share February 12, 2006 hmmm will go check out thanks.. But besides saving fuel what else does it do? Link to post Share on other sites More sharing options...
Picantorianhub Neutral Newbie February 12, 2006 Share February 12, 2006 Really ah but worth anot? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear February 12, 2006 Share February 12, 2006 free topup after that worth it for me Link to post Share on other sites More sharing options...
Picantorianhub Neutral Newbie February 12, 2006 Share February 12, 2006 Ok thanks... Link to post Share on other sites More sharing options...
Apollo 1st Gear February 12, 2006 Share February 12, 2006 Stamford, cos i got the nitrogen sticker on the rim fr them, permanently free. Link to post Share on other sites More sharing options...
Sturtles 6th Gear February 13, 2006 Share February 13, 2006 Nitrogen tires are good to have, but too much hassle of going down stamford just to pump or change tire pressures.. but should not have any problems if pumped from normal pump station, just that there will be slightly less nitrogen in the tire tube mix Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear February 13, 2006 Share February 13, 2006 can my current tyres nitrogen gas mix with normal air pump gas?? Pls advice.. no problem in mixing. Used to pump nitrogen, but find it a hassle when I need to pump.. in the end, changed back to normal air. Link to post Share on other sites More sharing options...
Apollo 1st Gear February 13, 2006 Share February 13, 2006 no hassle actually, cos near my place, i just drive over, they pump i drive off. beri easy. better then some shop promise to deliver the moon but no action. talk alot. Link to post Share on other sites More sharing options...
Evildoer Neutral Newbie February 13, 2006 Share February 13, 2006 anyone tried pumping helium, hydrogen or light gas/air, quite flamable i think but i believe at certain speed, ur car may start to fly....then ur spoiler can be put into use liao.... Link to post Share on other sites More sharing options...
Lancerddt Neutral Newbie February 13, 2006 Share February 13, 2006 Why inert tire gas filling? Formula 1, aviation and hazardous transport trucks use already for a long time inert fillings of tires. Most of civil drivers do not take care on their tire pressure. Because the pressure loss is reduced and the fire risk is avoided this filling of tires contributes substantially to security, comfort and economy . What is an inert filling of tires with nitrogen? The compressed air normally existing in the tire is replaced by an inert filling with tire gas. This gas is cleaned from particles, oil vapour and humidity. Above all especially this air is oxygen-poor, i.e. inert (= low reactive). What causes inert filling of tires? Inert tire gas avoids oxidation at the rim and valve seat. Also the tire rubber is protected inside against oxidation by the low oxygen share. Inflammations in the tire inside are not possible any longer, since without oxygen in air no process of combustion can take place. The loss of the molecules by the rubber wall of the tire (pressure loss by diffusion) is reduced. What are the advantages of a more constant tire pressure ? More driving safety by better handling characteristics Higher durability of tire caused by optimized rolling resistance More comfort by better taking up of impacts Less fuel consumption caused by lower rolling resistance Better handling & road holding Reduces tread wear and increases tyre life by up to 25% Correct inflation pressures reduce puncture risk by up to 33% Reduced rolling resistance improves miles per gallon by 2% Improved pressure retention Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 13, 2006 Share February 13, 2006 First used in aeroplane tyres to prevent rust formation and change in air prssure at high altitude. Do not see any advantage in car tyres that operated at sea-level. Link to post Share on other sites More sharing options...
Vit4wd 1st Gear February 13, 2006 Share February 13, 2006 Since my tyre was changed in Dec 2004 & topped with with nitrogen gas, there has been no loss of pressure. I notice that the tyres are not so hot as before. Link to post Share on other sites More sharing options...
Picantorianhub Neutral Newbie February 13, 2006 Share February 13, 2006 wow really? Thanks bro for the info ↡ Advertisement Link to post Share on other sites More sharing options...
Portable Tyre Pump
Portable Tyre Pump
Encounters with tyre shop
