User12343 Clutched April 22, 2002 Share April 22, 2002 hi brudders, typically if the tires are designed by the manufacturer to be inflated with XX PSI, what is the max PSI in excess of XX that can be pumped in w/o bursting? is there any guideline that one cannot exceed by, say 5% of the inflation pressure? cos always chua chua when it comes to topping up the air even wif preset pressures. thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie April 22, 2002 Share April 22, 2002 Hi! there, User12343, At the side wall of the tyre, it's stated the max. load, max. pressure, for the tyre, if there isn't, then the tyre is not meant for the road. Rgds Paul Yong Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 20, 2002 Share May 20, 2002 Hi fellow drivers.. if the stickers on the car indicates the cold tire pressure to be 21 kgf/cm2, does it also means 21psi? If so, what would be the pressure be in Kpa?? Thanks... cheers.. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 20, 2002 Share May 20, 2002 U sure it's 21kgf/cm2? That's only 4.3psi! Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 20, 2002 Share May 20, 2002 Oops....it's 2.1 kgf/cm2.....i believe i managed to covert it to about 29.87 Psi... Please enlighten me, what does Kpa stands for? Link to post Share on other sites More sharing options...
Magfocus 5th Gear May 20, 2002 Share May 20, 2002 Kpa? Kilo Pascal?? Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 20, 2002 Share May 20, 2002 Kpa? Kilo Pascal?? Correct! U've won a life sized Barney doll!!! Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 20, 2002 Share May 20, 2002 Thanks a million, maties.. Hmm....would i be able to pump moi tires using Psi with the new Mobil digi pumps then? Sorry to bother...cos i've been pumping estimated Kpa throughout my driving stint. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie May 20, 2002 Share May 20, 2002 Go ahead and load 30psi into your tires based on the digi-pump reading....should get close enough. Best if U could invest in a Stetho Gauge to confirm your tire pressures after pumping. Remeber to pump when the tires are cold (at least try to get to the nearest petrol kiosk from your home in the morning) Link to post Share on other sites More sharing options...
Guyver 1st Gear May 20, 2002 Share May 20, 2002 Is it a new car u driving? btw.. what car are u driving? Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 21, 2002 Share May 21, 2002 (edited) Moi driving an old '99 1.3L stock lancer Edited May 21, 2002 by Michel Link to post Share on other sites More sharing options...
Guyver 1st Gear May 21, 2002 Share May 21, 2002 Oic.... ok... so u working as sales or what? Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 21, 2002 Share May 21, 2002 part of a management team for a private estate. Link to post Share on other sites More sharing options...
Guyver 1st Gear May 21, 2002 Share May 21, 2002 Hmmm.... some company like Bonvest that kind? Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 23, 2002 Share May 23, 2002 some company like Jones Lang Lasalle, DTZ, Knight Frank etc..... Link to post Share on other sites More sharing options...
Michel Neutral Newbie May 23, 2002 Share May 23, 2002 Go ahead and load 30psi into your tires based on the digi-pump reading....should get close enough. Best if U could invest in a Stetho Gauge to confirm your tire pressures after pumping. Remeber to pump when the tires are cold (at least try to get to the nearest petrol kiosk from your home in the morning) Pumped my under-inflated tyres this morning....hmm, seems to be quieter and less bumpy on the road, or is it just a psychological effect?! Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 24, 2002 Share May 24, 2002 Hi! there, Michel, Usually, I'd pump my tyres the night before to stated 36psi, then in the morning, check the tyre press., set it to 32psi. Invest in a good tyre press. gauge, like doc, I use the Bluepoint gauge which has a bleed button, very convenient, bleed till the press. is reached. I think I'd use 34psi after I monitor my tyres, as one of them seems to have a tiny leak. Rgds Paul Yong Link to post Share on other sites More sharing options...
Guyver 1st Gear May 26, 2002 Share May 26, 2002 Pumped my under-inflated tyres this morning....hmm, seems to be quieter and less bumpy on the road, or is it just a psychological effect?! [/reply] Think what u feel should be that your steering is lighter.... as for bumpy-ness.. that'll depend on what road u travelling on and your tyres.... think your turning would become more responsive too..... ↡ Advertisement Link to post Share on other sites More sharing options...
Inflation coming to hit us hard.
Households to pay more for waste disposal from July 1
New money inflows to Singapore jump 59% to a record S$448b in 2021
Legendary aunties and uncles?
Household incomes in S’pore rose in 2022 but inflation has chipped away at growth
BudgetMealGoWhere Portal
