Michel Neutral Newbie May 26, 2002 Share May 26, 2002 can still feel the bumpyness....sometimes, can absorb...sometimes, feels like i hit rock bottom (eg. going across metal covers). is it normal? ↡ Advertisement Link to post Share on other sites More sharing options...
Guyver 1st Gear May 26, 2002 Share May 26, 2002 Hmmm.... ok.... think got to seat inside then know.... but as long as it's not too bad... and since it's for the good... then bochap lor..... Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 28, 2002 Share May 28, 2002 Think what u feel should be that your steering is lighter.... as for bumpy-ness.. that'll depend on what road u travelling on and your tyres.... think your turning would become more responsive too..... and you should get better fuel economy too.... tested and proven... Link to post Share on other sites More sharing options...
Zolidlim Neutral Newbie May 28, 2002 Share May 28, 2002 Wat pressure u guys suggest for a 16" rims with ST115 Falken low profile tyres? Everytime i went for balancing, blah blah blah, the mechanic will change my pressure. So, therefore, then my pressure will be different again. My car swerve to one side though i've just balanced my car. Why isit so? Headache........ Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 28, 2002 Share May 28, 2002 Hi! there, Mitlover, No matter how many times you send your tyres for balancing, it won't fix the way your car move to one side. That can only be fixed by doing wheel-alignment. Balancing of the tyres only stop your steering wheel from shaking, caused by the lack of uniform weight during the rotation of the tyre on the wheel. Car not going straight can be caused by the angle of the road, used for drainage to prevent puddles on road surface. To determine if your car is going straight, move along a concrete surface that's flat, try the multi-storey carparks. Wheel-alignment is a waste of money if your tyres are not properly maintained, tyre pressure not same for each axle, ball-joints & bushings are worn and not replaced. Rgds Paul Yong Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 29, 2002 Share May 29, 2002 Wat pressure u guys suggest for a 16" rims with ST115 Falken low profile tyres?Everytime i went for balancing, blah blah blah, the mechanic will change my pressure. So, therefore, then my pressure will be different again. My car swerve to one side though i've just balanced my car. Why isit so? Headache........ Seems like Paul already gave a detail explanation about your problem. Regarding the tyre pressure, I am not sure about 16" rims. I am using 36psi (cold) for my front tyres and 34psi for the rear tyres. I am using 215/45/ZR17 tyres. Link to post Share on other sites More sharing options...
Zolidlim Neutral Newbie May 29, 2002 Share May 29, 2002 WAH, that means i gana cheat lah??!!?? Done so many times, oso can be confused by all these terms. Always get mixed up by balancing and wheel alignment.....*sigh* Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 29, 2002 Share May 29, 2002 Hi! there, Mitlover, If it's any consolation, you're not the first, and definitely not the last. [[[ WAH, that means i gana cheat lah??!!?? Done so many times, oso can be confused by all these terms. Always get mixed up by balancing and wheel alignment.....*sigh* ]]] Rgds Paul Yong Link to post Share on other sites More sharing options...
Spaceman Neutral Newbie May 30, 2002 Share May 30, 2002 hi guys, need some help here, me just chnaged from a stock 185/65/15 to 205/45/17 tyres but me dunno how much air to pump leh, used to pum 32psi all around on m stock tyres, so , can anyone aadvise me on these? thanx! Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 30, 2002 Share May 30, 2002 hi guys, need some help here, me just chnaged from a stock 185/65/15 to 205/45/17 tyres but me dunno how much air to pump leh, used to pum 32psi all around on m stock tyres, so , can anyone aadvise me on these? thanx! Hi! I pump 36psi for my front tyres and 34psi for the rear tyres. The dimension is 215/45/17. You may need to do some trial-and-error to get the suitable pressure. Link to post Share on other sites More sharing options...
Magfocus 5th Gear May 30, 2002 Share May 30, 2002 hi guys, need some help here, me just chnaged from a stock 185/65/15 to 205/45/17 tyres but me dunno how much air to pump leh, used to pum 32psi all around on m stock tyres, so , can anyone aadvise me on these? thanx! Hi! I pump 36psi for my front tyres and 34psi for the rear tyres. The dimension is 215/45/17. You may need to do some trial-and-error to get the suitable pressure. I have pumped 36 for the front and 35 for the rear for my 195/60/15, feels so much better and surprisingly, even my ride has improved! Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 30, 2002 Share May 30, 2002 I have pumped 36 for the front and 35 for the rear for my 195/60/15, feels so much better and surprisingly, even my ride has improved! Maybe I will try that once Violet is back with those new shoes.... Link to post Share on other sites More sharing options...
Magfocus 5th Gear May 30, 2002 Share May 30, 2002 I have pumped 36 for the front and 35 for the rear for my 195/60/15, feels so much better and surprisingly, even my ride has improved! Maybe I will try that once Violet is back with those new shoes.... Lets hope Violet would be as good as new! [angelic] Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 30, 2002 Share May 30, 2002 Lets hope Violet would be as good as new! [angelic] It better be or else I am going to burn down the workshop... Link to post Share on other sites More sharing options...
Magfocus 5th Gear May 30, 2002 Share May 30, 2002 Lets hope Violet would be as good as new! [angelic] It better be or else I am going to burn down the workshop... Which workshop is it by the way? Link to post Share on other sites More sharing options...
Sparetyre Neutral Newbie May 30, 2002 Share May 30, 2002 Which workshop is it by the way? Dun feel like advertising for them now. Can share with you the next time we meet. Link to post Share on other sites More sharing options...
Magfocus 5th Gear May 30, 2002 Share May 30, 2002 Which workshop is it by the way? Dun feel like advertising for them now. Can share with you the next time we meet. Ok better make sure they have done a good job first! Link to post Share on other sites More sharing options...
Guyver 1st Gear May 30, 2002 Share May 30, 2002 hi guys, need some help here, me just chnaged from a stock 185/65/15 to 205/45/17 tyres but me dunno how much air to pump leh, used to pum 32psi all around on m stock tyres, so , can anyone aadvise me on these? thanx! Wah!! what car are u driving?.... 17" ah.... is it very draggy? ↡ Advertisement Link to post Share on other sites More sharing options...
Inflation coming to hit us hard.
Households to pay more for waste disposal from July 1
New money inflows to Singapore jump 59% to a record S$448b in 2021
Legendary aunties and uncles?
Household incomes in S’pore rose in 2022 but inflation has chipped away at growth
BudgetMealGoWhere Portal
