Evan015 Neutral Newbie March 5, 2006 Share March 5, 2006 was wondering if any seniors here can explain wats the main diff between a Class D and a A/B amp? ↡ Advertisement Link to post Share on other sites More sharing options...
Erwinseow Neutral Newbie March 5, 2006 Share March 5, 2006 (edited) Hope this helps! :) http://www.bcae1.com/ampclass.htm Edited March 5, 2006 by Lukie102 Link to post Share on other sites More sharing options...
Romanc88x Clutched March 5, 2006 Share March 5, 2006 Good info. Link to post Share on other sites More sharing options...
Bosebani Neutral Newbie March 5, 2006 Share March 5, 2006 Interesting Topic here ..... Is it of importance if our amp is a Class A, Class A/B, or Class D or even Hybrid Tube??? Can anyone here "hear" the difference??? Link to post Share on other sites More sharing options...
Headshok 1st Gear March 5, 2006 Share March 5, 2006 class A= expensive class A/B=normal prices hybrid tube= even more expensive tube=out of this world pricing class D= best used to woofers as they are more efficient and will not heat up that much, thus not losing power to heat. Link to post Share on other sites More sharing options...
X_confuse Neutral Newbie March 5, 2006 Share March 5, 2006 Think totally disagree what you said. Quality is base on the circuit design not measure it by CLASS. If you mind set said Tube is expensive. Then you may easily core by sellers. Class A, when the RMS power at 5w or 15w. it may sound like Class A. But when it boost up to 75w or... it can't be the class A anymore. Maybe AB and B. So in the market in fact only AB or B. Class A is those company used as marketing purpose. Hybrid Tube = input tube ,Output mosfet. In fact same prices with those market normal amp. Again. It depend on the circuit diagram design. Full Tube= sound warm, what it ex in the market. Because designer have to put effort on the cooling design and power stablelizer. D class = what american ppls like to use for sub.Bcos it used a little bit of current/power supply but produced the big power ( RMS ) output. The prices on amplifier is measure by the amp circuit design. Mean the amp must be able to transfer the signal from the input stage to the output staget of the amp with the min signal lost and with consistantly. And... too many !!! Best amplifer for sub ( SQ ) will be the normall class AB or.. no D. Too much things. Better listen by your own ear. = ) Link to post Share on other sites More sharing options...
Headshok 1st Gear March 5, 2006 Share March 5, 2006 (edited) y u "tut" me until so jiat lat.. wah lau.. hahaha..i never say anything abt quality from the price wat.. just state my observation on the pricin on various types of amp lor. but nice explanation. aiyah. i putting it in common layman terms mah. and its quite true (from what i've seen), tube is indeed more expensive as compared to normal Class ABs ard. how can u say i easily get conned? class A, most ard quite ex. class AB, common ard,price vary from cheap to ex. Hybrid tube: more ex liao, like butler and rammaudio (according to bosebani, he got for 3K), thus i tink tats expensive. class D, for sub, price vary lor.. aiyah, best to listen with own ears lor.. Edited March 5, 2006 by Headshok Link to post Share on other sites More sharing options...
Bosebani Neutral Newbie March 5, 2006 Share March 5, 2006 >>class A= expensive class A/B=normal prices hybrid tube= even more expensive tube=out of this world pricing >> bro, There are easily many class A/B amps that are more expensive than HYbrid Tube or Tube and vice versa. Since you are sellng ICE online, sure you know which are those, rite? Link to post Share on other sites More sharing options...
Headshok 1st Gear March 5, 2006 Share March 5, 2006 (edited) hahhaa.. i noe.. class AB got big price range .. heheh..from $60 planet audio to $7k Thesis (or is it $8k) but tube is mostly quite ex as compared to most of the AB out there wat.. heheh.. heheh.. did i get the price of ur rammaudio correct?i remember it was ard that price that u stated.. Edited March 5, 2006 by Headshok Link to post Share on other sites More sharing options...
Bosebani Neutral Newbie March 5, 2006 Share March 5, 2006 You wrong again la, Thesis who selling $7-8k??? Link to post Share on other sites More sharing options...
Evan015 Neutral Newbie March 5, 2006 Author Share March 5, 2006 wat do you mean by input tube and output mosfet? Can elaborate? so there's realy no hard and fast rule tat states wat tyoe of amp is suitable for component or sub or used to achieve SQ or SPL, rite? if there is, so to achieve SQ or SPL, which class of amp should we use? So, for circuit diagram design, wat are the kind of diagram or design tat amps are based on? and wat are the differences for these designs? I apologise if i am asking too much.. but was just curious? coz reading on website, some of the terms tat they use, really can't understand, easier to refer layman's term to professional lingo.. Link to post Share on other sites More sharing options...
Headshok 1st Gear March 5, 2006 Share March 5, 2006 that time i ask the integra with it leh.. he said around that figure. but its a chio amp.. Link to post Share on other sites More sharing options...
Headshok 1st Gear March 5, 2006 Share March 5, 2006 SPL, class D, pure undistorted power. more efficient, amp wont burn up, can run at lower impedence .. heheh Link to post Share on other sites More sharing options...
Evan015 Neutral Newbie March 5, 2006 Author Share March 5, 2006 so if i wana go SQ? which type will be the better choice? Link to post Share on other sites More sharing options...
Headshok 1st Gear March 5, 2006 Share March 5, 2006 as wat Xconfused said, AB also can, but personally, i'll still go for a class D as it wont generate so much heat Link to post Share on other sites More sharing options...
Evan015 Neutral Newbie March 5, 2006 Author Share March 5, 2006 so basically class d is quite suitable for all lah, as it won't heat-up so much and its more effficient than the As, Bs and ABs. of coz still subjected to diff brands lah, diff diagram design lah , diff settings or tuning lah, diff needs and diff critical ears.. tio bo? tat time u quoted for me the PG amp, i think u were refering to the Octane R 8.0:1, rite? how much diff will the Octane R 15.0:1 be? in terms of damage and performance? PM me? thanks Link to post Share on other sites More sharing options...
Evan015 Neutral Newbie March 5, 2006 Author Share March 5, 2006 thanks for the link bro! made me understand quite abit more! Link to post Share on other sites More sharing options...
Bosebani Neutral Newbie March 5, 2006 Share March 5, 2006 bro, in the latest SPL! magazine by Twnll , there is a interesting article about Class D amplifier and it's purpose/benefits. Check it out ↡ Advertisement Link to post Share on other sites More sharing options...
2016 Mercedes E-class (W213)
Mercedes G Class
Mercedes G Class
Mercedes Coupe E class Coupe C124 (1987 to 1996)
Mercedes C class W204 (Facelift) Reliability
How to tell if someone is high or low class?
Good-Class Bungalow in the sky
