Turbobrick Neutral Newbie January 6, 2002 Share January 6, 2002 Here's a cut up pic of the module, seems like irrepairable. ↡ Advertisement Link to post Share on other sites More sharing options...
Yongwd 1st Gear January 6, 2002 Share January 6, 2002 SMT circuit board. Soaked in water? Show me the board during next meetup, maybe I can help. [angelic] Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 6, 2002 Author Share January 6, 2002 Great! Thanks bro.......which meetup har? Link to post Share on other sites More sharing options...
Yongwd 1st Gear January 6, 2002 Share January 6, 2002 when i collect the H4 + CITGO from u! Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 8, 2002 Author Share January 8, 2002 I viewed the soldered pins that connects to the wire harness linking to the ECU and found some pins with cracked soldering points. (Tip from the BB). Check out the cracked pic view under a microscope I'll try to resolder the pins and try the module on overboost's brick Link to post Share on other sites More sharing options...
Overboost Clutched January 8, 2002 Share January 8, 2002 I think HEAT may have caused this. The "on-off" affair can be due to expansion/contraction as "850R wagon" pointed out on Sat. Gavin, most connectors/pins/etc can be found at Sim Lim Sq. If you have a sample, pass to me and I'll go find it. Rgds Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 8, 2002 Author Share January 8, 2002 I'll resolder them as the circuit board cannot be remove without damaging the transmittors for the ABS pulse. So I won't risk removing the board to replace the entire pin. I also noticed that the soldering lead used for the circuit is freaking soft like soap. I'll resolder every single pin just in case. Have to remove the "jelly" layer first. Link to post Share on other sites More sharing options...
Wagon Neutral Newbie January 8, 2002 Share January 8, 2002 Sounds reasonable re the contacts being broken when hot.The engine compartment is bloody hot for hours.Like I noticed before takes a 6 hrs or overnight cool down for ABS to work temporarily. ?modify with 12V CPU cooling fan or heat insulation. I need Ur help to reinsulate the now bare wires ( the insulation has mysteriously disintegrated) to the controller .The B's at our only dealership didnt do a thing abt it. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 8, 2002 Author Share January 8, 2002 I'll resolder all the pins and cross my fingers Drop by my place one of the nights and I help U with the insulation and light bulb change. Link to post Share on other sites More sharing options...
Yongwd 1st Gear January 8, 2002 Share January 8, 2002 aiya thats simple mike! Its call dry joint. Try not to solder the board with gun exceeding 25W else will damage the SMT components. You got problem soldering the ABS ctrl box let me know. I got ultra fine soldering tools meant to repair SMT boards and handphone circuit boards. I'll resolder all the pins and cross my fingers Drop by my place one of the nights and I help U with the insulation and light bulb change. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 8, 2002 Author Share January 8, 2002 Bro if U can help me better still! I quite shaky hand and my soldering iron is 40W type Gimme a buzz if U're free. Link to post Share on other sites More sharing options...
Yongwd 1st Gear January 8, 2002 Share January 8, 2002 Shaky hands? Use too much force ah? Guess u not that lao-peh-peh rite? :P Bro if U can help me better still! I quite shaky hand and my soldering iron is 40W type Gimme a buzz if U're free. Link to post Share on other sites More sharing options...
Turbobrick Neutral Newbie January 8, 2002 Author Share January 8, 2002 No lar, just lousy at holding small and fragile stuff ↡ Advertisement Link to post Share on other sites More sharing options...
Apple In the news
Apple In the news
How Much Do You Know About ABS?
China spends more on controlling its 1.4bn people than on defense
Car Remote Control Key - Any lobang
Automatic Whole Car Cover with Remote Control
Understanding Anti-lock Braking System (ABS)
Reinventing the Wheel - Tesla Edition
Lose control
Lose control
