Yattokame 4th Gear November 15, 2009 Share November 15, 2009 I am on the same size as you and have pumped to 37psi front and back, a little more than my previous 225/50 17 recommended pressure in the manual although the pressure you mentioned is for 235/45 18. However I realised most of the mid-range tyres of 245/40 18 in the market has load index around 91-95. Can't seem to find one with 98 (as recommended in manual), except Michelin Pilot Preceda. So I should go for 37psi front and back? but manual says staggered pressure. ↡ Advertisement Link to post Share on other sites More sharing options...
Ftco 2nd Gear November 15, 2009 Share November 15, 2009 So I should go for 37psi front and back? but manual says staggered pressure. I find putting different pressures for front and back somewhat troublesome so I normally put equal pressure. Can't go wrong following the receommendation in the manual or +-1-2 psi is ok. Link to post Share on other sites More sharing options...
Roberttan 5th Gear November 21, 2009 Share November 21, 2009 BUT for MPV you got to be very careful. this MPV could carry up to 9pax+ lagguage,so you got be very careful when you up size your tyre,1 more very important item to know is your sport rim,my advice is try not to go for those light weight rim,some of them are more suitabel for saloon car for example 9pax x 70kg is = 630kg + 70kg = 700kg plus your MPV weight 1600kg you better make sure your tyre and rim are strong enough to carry total weight of 2300kg (always remember to go for strong rim for MPV) that's why I always go for reputable Jap Brand or Euro Brand aftermarket rims. Most, if not all, Jap, Phi, Thai, My, Indo, China rims have a max load of 690kg per rim. For Conti, like OZ, they are 710kg per rim. I bought a used Enkei RP05 rims (this model not available here, have to indent) from an ex-Airtrex Turbo owner (hand carry back from Japan) and it has a max load of 690kg per rim. by putting the reputable brand is still not enough, is the matching of your car weight also by reading the load numbers on the rim you have to be careful of some have few numbers there and this depending on what pcd you are referring to So my MPV is almost 1900kg, excluding any passengers, with me on board it's 1980kg, confirmed as I always sell off my old newspaper + used cardboard (mum's is doing PD at home) direct to the paper recycle factory at Defu lane (7~8mins drive from my flat in Hougang Central). With 690kg x 4 = 2760kg. So I am left with 2760kg - 1900kg = 860kg of load for passenger + luggage. So luckily, for my MY driving trip of 4 adult + 4 kids + luggage is defintely lesser than 860kg I am the heaviest at 80kg, the rest of the adult - wife, maid, mum is around 50kg + -, 4 young kids are range from 10+ to 16+ kg Link to post Share on other sites More sharing options...
Forgot2bme Clutched January 18, 2010 Share January 18, 2010 Wow interesting. Ups for the informative article! 1 Link to post Share on other sites More sharing options...
Grix17 Clutched February 4, 2010 Share February 4, 2010 I pump 270 kPa for my 245/45R18 tyres even though they are extra load (XL) and though OE recommends 250 kPa for 215/60R17. Comfort is quite good on CSC3 for 260-270 kPa and good for FC too. When pressure drops to 250 kPa after 1 month without pumping air, car feels slightly sluggish (can tell with TPMS). Can anyone recommend how much extra to pump if I am NOT on extra load tyres? 2 Link to post Share on other sites More sharing options...
Ahjun Clutched March 28, 2010 Share March 28, 2010 i pump 290 kPa for my Aveo sedan 15" x 4.... 2 Link to post Share on other sites More sharing options...
Grix17 Clutched March 29, 2010 Share March 29, 2010 i pump 290 kPa for my Aveo sedan 15" x 4.... Sounds pretty high. Beware that overinflation leads to premature wear of the centre tread. I've discovered that on my tyres. Tread near shoulder has about 4-5 mm. Centre only about 2.5 to 3 mm. Need to balance rolling resistance with even wear of the tyres. Link to post Share on other sites More sharing options...
Mr_biscuit 3rd Gear March 30, 2010 Share March 30, 2010 (edited) i pump 290 kPa for my Aveo sedan 15" x 4.... 290kpa is super over-inflate your 15" wheels on Aveo. Safety is definitely compromised and do be extra careful especially on wet road conditions. Soon you'll realise your tyre wear is more towards the center. IMHO, 240kpa (Cold Tyre Pressure) is the max you can go. Edited March 30, 2010 by Mr_biscuit 1 Link to post Share on other sites More sharing options...
Babyt 4th Gear March 30, 2010 Share March 30, 2010 290kpa???!!! dont u feel ur car is floating and ur steering wheel is damm light until like no ground feeling? 1 Link to post Share on other sites More sharing options...
Chiangauto Clutched April 2, 2010 Share April 2, 2010 Thanks for sharing.good thread must always on top. 1 Link to post Share on other sites More sharing options...
Rtxm Neutral Newbie April 10, 2010 Share April 10, 2010 First of all, the article does not imply a "relationship between air pressure and load index" but a difference in rating(which i'll explain). Secondly, both cases do not really apply to Singapore. Both cases are using P metric measuresment(denoted by the P in front of the size) which is not used in singapore, singapore uses Euro metric measurements. P metric measurement's load capacity is based on an engineering formula which takes into account their physical size (the volume of space for air inside the tire) and the amount of air pressure (how tightly the air molecules are compressed). Hence the use of SL(standard load) based on 35psi and XL(Extra load) based on 41psi, therefore a difference in pressure. The first case study which is a comparison between P225/55R17 95H and P255/35R20 93H. The 20inch tire has a incorrect load index therefore the author suggest using Pmetric XL rated tires to correct the problem. However there is no such division of SL and XL in Eurometric measurement(Singapore). Eurometric is theoretically a Pmetric with only SL rating, meaning maximum load tire pressure does not change at 35psi. Therefore the only variable here is load index. The second case study is a case of Pmetric or Eurometric tires being used on cars which require LTmetric rating(not used in singapore as well). The load index cannot be directly used. In simple terms, a load index of 100 for Pmetric and Eurometric is only a load index of 91 in LTmetric. Summary Tire pressure shld follow ur manufacturers recommendation(based on vehicle curb weight and load) irregardless of size as long as the load rating is correct(equal or greater then stock). 1 Link to post Share on other sites More sharing options...
Rtxm Neutral Newbie April 10, 2010 Share April 10, 2010 Jus to add to the summary. You can actually pump pressure proportionately lower if your new tire had a higher load index which i wouldnt recommend unless u know how to calculate. for a even more in depth read on P metric or Euro metric inflation http://marktg.toyotires.com/file/loadinflationtable.pdf Link to post Share on other sites More sharing options...
Autom Neutral Newbie April 19, 2010 Share April 19, 2010 Hi Im sorry to have this post here as i could not start a new post... Need lots of help from you guys here! Looking for tyre size 185 or 175/80/r14 about 100 pics per month... Is there any advice? Please call Allan H/P: 98310824 1 Link to post Share on other sites More sharing options...
DeathAngel Neutral Newbie May 3, 2010 Share May 3, 2010 great info :) 1 Link to post Share on other sites More sharing options...
Justwe Neutral Newbie June 10, 2010 Share June 10, 2010 hm nice & thanks for the info. time to check for my air pressure. 1 Link to post Share on other sites More sharing options...
Doraemarc Clutched September 15, 2010 Share September 15, 2010 hi so wat determines our tyre pressure? OEM recommendation, or tyre capabalities? if my tyre max is 51psi, wouldnt pumping 32psi consider under-inflate? there r some theory abt max-10% (source: Car Bibles), so if taking acc of dat theory, shld i go for 45psi? does it matter wat car i drive? 1 Link to post Share on other sites More sharing options...
Zztensor Neutral Newbie September 16, 2010 Share September 16, 2010 hi so wat determines our tyre pressure? OEM recommendation, or tyre capabalities? if my tyre max is 51psi, wouldnt pumping 32psi consider under-inflate? there r some theory abt max-10% (source: Car Bibles), so if taking acc of dat theory, shld i go for 45psi? does it matter wat car i drive? i think the "90% of max." or "80% of max." can be a gd rule of thumb. In ur case, it does sound a little underinflated....but if u feel tat the drive is ok (i.e. not floating, not sluggish, u ok with braking distance, decent control in wet conditions), then it's really up to u. 1 Link to post Share on other sites More sharing options...
Remin Neutral Newbie December 12, 2010 Share December 12, 2010 (edited) thx for the info :) Edited December 12, 2010 by Remin ↡ Advertisement 1 Link to post Share on other sites More sharing options...
The world’s most powerful passports
HSA recalls 3 brands of high blood pressure drugs
Tyres pressure for 225/45/R17
How useful is higher pressure radiator cap?
Load noise when car speed >80km/h
Carro Interesting Car Rental Scheme
Friend issued legal takedown 4 posting full article in forum
