Putter Neutral Newbie May 4, 2006 Share May 4, 2006 (edited) Just wanted to share with you my experience of having the front left tyre burst (Bridgestone Turanza 205/55R16) while at ~100km/h along CTE this morning... Surprisingly enough, the car did not loose control when the tyre went burst. I only hear a sudden loud "blok blok..." sound. I quickly slow down and filter to the left lane, then to the road shoulder. Initially, I thought it is just a punctured tyre. To my horror, the tyre sidewall was suffering a large cracked line of about 6 inches. I could see the teared portion with wire exposed. I was in deep rushed to change up the tyre and forgot to take a picture of it. My mileage is closed to 48K. Though typically tyre replacemet usually start when close to 70K or so. Any comment on this? Really dunno why the sidewall will crack in such a way. It is pretty dangerous if there isn't any tell-tale sign. If at higher speed say ~140km/h along NS HW, that could be a disaster liao. Anyway, had the 4 tyres replaced to Maxxis MA-21, highly recommended by shop owner over the Bridgestone GR80 for wet floor gripping. Will let you guys know more about its performance at later time. In conclusion, I am pleasantly surprise that the car still remain controllability even though the front tyre burst when I was cruising at 100km/h. Edited May 4, 2006 by Superb ↡ Advertisement Link to post Share on other sites More sharing options...
Firstcall Clutched May 4, 2006 Share May 4, 2006 oh my...consider yourself lucky bro... take care! Link to post Share on other sites More sharing options...
Cyberet Neutral Newbie May 5, 2006 Share May 5, 2006 sidewall failure? have you figured out the cause? most of the time its due to either insufficient pressure, or hitting/rubbing the curb often. Link to post Share on other sites More sharing options...
Nine_eleven 2nd Gear May 5, 2006 Share May 5, 2006 glad ur safe! how old were ur old tires? manufactured long time ago? tire failure is very dangerous! Link to post Share on other sites More sharing options...
Soya Supersonic May 5, 2006 Share May 5, 2006 were the burst ones stock tyres? Link to post Share on other sites More sharing options...
Fortress Clutched May 5, 2006 Share May 5, 2006 Sorry to hear that and your experience, thank God you are alright. The car is well balance. Anyway, the little known about tyres is that they last shorter than what we expect, the pressure for Continental cars should be higher than Japanese, and BS are softer in compound and they do not last as long on Continental cars. I change my tyres by 30,000km or 2 years from manufactured date. Oh..a budge tyre will further deteriorate the failure faster. Link to post Share on other sites More sharing options...
Kiatmobile 1st Gear May 5, 2006 Share May 5, 2006 How long have you been using this tyre? When was your last change and did you notice the roundness(out of shape) on the tyres? Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 5, 2006 Share May 5, 2006 Bro, glad that you are alright My mileage is closed to 48K. Though typically tyre replacemet usually start when close to 70K or so. Any comment on this? Bro, my practice is change tyres at every 40,000Km or 2 years whichever comes first Link to post Share on other sites More sharing options...
Acemundo Supercharged May 5, 2006 Share May 5, 2006 70k seems like too long a mileage leh? most pple i know change around 35-50k..... Link to post Share on other sites More sharing options...
Sky8807 1st Gear May 5, 2006 Share May 5, 2006 (edited) i was wandering when was the last time u check your tyres pressure. Leak and very low tyre pressure can cause this incident. Edited May 5, 2006 by Sky8807 Link to post Share on other sites More sharing options...
Flight_skoda Neutral Newbie May 5, 2006 Share May 5, 2006 Oh my!!! Did you hit on any debris or stones on the road? I remembered my past encounter whilest driving a Presea along AYE and I hit a rolling wheel cover from the car in front. My front left tyre has had a crack/tear but did not leak. I managed to drive to the nearest Stamford Tyres to change. Link to post Share on other sites More sharing options...
Putter Neutral Newbie May 5, 2006 Author Share May 5, 2006 Thanks for all the replies. I pump the tyre pressure at 230. Is that considered too low for this car on 205/55 R16? It was a stalk tyre Bridgestone Turanza ER30. It is quiet but the gripping to wet floor is quite poor. I encountered a few times when the car body trying to move but the tyre skidded on the floor. BTW, how often do you rotate the tyres? Every 10k? Link to post Share on other sites More sharing options...
Putter Neutral Newbie May 5, 2006 Author Share May 5, 2006 No leh...pretty smooth cruizing on the right lane when it suddenly go "blok blok blok"... Link to post Share on other sites More sharing options...
Putter Neutral Newbie May 5, 2006 Author Share May 5, 2006 I check the pressure about once a month...but not sure if 230 is too low for my tyre. Link to post Share on other sites More sharing options...
Rafiano Neutral Newbie May 5, 2006 Share May 5, 2006 thats it..no Bridgestone for me... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear May 5, 2006 Share May 5, 2006 230 sounds quite ok for me although i pump 245 for my 17" Normally quiet tyres do not have good grips and grippy tyres are not quiet Tyre rotation should be done at every 10K Link to post Share on other sites More sharing options...
Poortraveller 1st Gear May 5, 2006 Share May 5, 2006 (edited) ur one farking lucky fellow i oso experience tyre burst in NSH abt 5yrs ago, was travelling ard 140kmh and the car lost control and hit the center divider and spin for a few round ... i was alright after the accident and manage to come out thru the passanger door as i cant open the driver side door ... the car was total loss Edited May 5, 2006 by Tenminste Link to post Share on other sites More sharing options...
Putter Neutral Newbie May 5, 2006 Author Share May 5, 2006 No la...like what feedback from the rest...I think I over stretch it liao though it is only about a year. Didn't know most people change tyre around 30-40K interval. ↡ Advertisement Link to post Share on other sites More sharing options...
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
Tyre puncture
Tyre puncture
Continental closing Alor Setar plant
