Rodmansakura Neutral Newbie May 11, 2006 Share May 11, 2006 hi guys,,, need some advise here have been hearing some funning sound since last week whenever i shift gear,, 1-2-3-4-5 i wil hear a cracking sound from the engine as i accelerate after shifting... it last for a few seconds... is there any problem or is a warning to more severe prob???? i feed esso 95... yesterdae try esso 92... todae the cracking happen more often??? wat can be done??? ↡ Advertisement Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 11, 2006 Share May 11, 2006 wat engine oil u using... any new stuff u changed in ur ride? Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie May 12, 2006 Share May 12, 2006 Sounds like pinging to me. If I diagnosed correctly, you will only hear this "ball bearing rattling" noise when you are accelerating from low RPM. Once on the higher RPM, this noise will disappear. Have your advance timing checked. It should be way too advance. BTW, what car are you driving? Carb or EFI? Link to post Share on other sites More sharing options...
Kb27 Supersonic May 12, 2006 Share May 12, 2006 Have you changed manual transmission oil? It might help. Link to post Share on other sites More sharing options...
Rodmansakura Neutral Newbie May 12, 2006 Author Share May 12, 2006 mineral oil... coz my engine eat oil... so cannt use good oil Link to post Share on other sites More sharing options...
Rodmansakura Neutral Newbie May 12, 2006 Author Share May 12, 2006 wah.. u r rite... only hear this "ball bearing rattling" noise when you are accelerating from low RPM. Once on the higher RPM, this noise will disappear. it's a carb... Link to post Share on other sites More sharing options...
Rodmansakura Neutral Newbie May 12, 2006 Author Share May 12, 2006 haven change... btw.. wats tat for??? Link to post Share on other sites More sharing options...
Thug Clutched May 12, 2006 Share May 12, 2006 u sure its from engine? maybe its ur exhuast loose..hit side "wall" Link to post Share on other sites More sharing options...
Mivec9 1st Gear May 12, 2006 Share May 12, 2006 seems like leak oil or the oil seal cmi..so u shd do changing of timing belt..which include change the oil seal..can let the mech diagnose the sound u heard from engine.. Link to post Share on other sites More sharing options...
Kb27 Supersonic May 12, 2006 Share May 12, 2006 MTF (manual transmission fluid) should change after about 60k or so. This oil lubricates the gearbox. I just thought it is a cheaper way to find out if it will solve the problem. Besides, it should be changed anyway. Link to post Share on other sites More sharing options...
Cordia_gsr Neutral Newbie May 12, 2006 Share May 12, 2006 Yes, your timing is way too advance. Retard the timing degree and you should be doing fine. That's the reason why you find more pinging as you down the octane from 95 to 92. Alternatively, you may want to try 98. You will hear no if not less pinging. Pinging is very unhealthy. Prolong it will cause engine damages. Link to post Share on other sites More sharing options...
Rodmansakura Neutral Newbie May 12, 2006 Author Share May 12, 2006 cant be... my exhaust is intact and not loose Link to post Share on other sites More sharing options...
Rodmansakura Neutral Newbie May 12, 2006 Author Share May 12, 2006 like tat mus go see doctor liao... tink pump back 95 first... Link to post Share on other sites More sharing options...
Rodmansakura Neutral Newbie May 12, 2006 Author Share May 12, 2006 oki,,, wil check wif the mech tml.. thanks Link to post Share on other sites More sharing options...
Fatfat Neutral Newbie May 12, 2006 Share May 12, 2006 hi wat car is ur ride? u also mentioned engine 'drink' oil? Link to post Share on other sites More sharing options...
Fatfat Neutral Newbie May 12, 2006 Share May 12, 2006 alamak stupid me, shd be starlet right? best to have it checked soonest. Good Luck. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear May 12, 2006 Share May 12, 2006 hi guys,,, need some advise here have been hearing some funning sound since last week whenever i shift gear,, 1-2-3-4-5 i wil hear a cracking sound from the engine as i accelerate after shifting... it last for a few seconds... is there any problem or is a warning to more severe prob???? i feed esso 95... yesterdae try esso 92... todae the cracking happen more often??? wat can be done??? is it ur gearbox problem??? Link to post Share on other sites More sharing options...
Starletgt Neutral Newbie May 12, 2006 Share May 12, 2006 wat engine oil u using... any new stuff u changed in ur ride? That is most probably engine pinging. Try to retard your timing. If you dun know I can do it for you FOC. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
SCHNELL Engine Oil 5W40
