Irene Neutral Newbie June 14, 2006 Share June 14, 2006 I realised due to my laziness, those bird sxxt are so difficult to remove. The harder i rub, the more damage. Those spot remover will help? ↡ Advertisement Link to post Share on other sites More sharing options...
Kanchelsk 2nd Gear June 14, 2006 Share June 14, 2006 did u wet a tissue n placed it on the bird sxxt? after 2mins u can easily wipe away... provided u got wax ur car la... Link to post Share on other sites More sharing options...
Apollo 1st Gear June 14, 2006 Share June 14, 2006 wet it with tissue and preferably with a neutral / high PH shampoo becos these dropping r acidic so tat should neutralize their effect. if white dropping easy to clean off. if United nation color one, chiam liaoz... keep watering it, eventually... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear June 14, 2006 Share June 14, 2006 I use the quick detailer and spray at the birdie bombs before using a wet tissue to remove it Don't ever rub hard on the birdie bombs cause it will result in more scratches on your paintwork Link to post Share on other sites More sharing options...
Mroonws Clutched June 14, 2006 Share June 14, 2006 Bird Droppings are like poisons. They will Bite into the paint leaving some stains that are very difficult to remove. Best wipe off Immediately after you sees it. Link to post Share on other sites More sharing options...
Irene Neutral Newbie June 14, 2006 Author Share June 14, 2006 Problem is i waited for few days before i decided to clean it. By the time no wet tissue or cleaner can work. Still left some patches of stain. How huh? I already damaged a little of my paint. Heartpain. Dun wish to further damage anything. Whitish coloured ones are easier to remove. What i meant is those dark coloured ones. Link to post Share on other sites More sharing options...
Kanchelsk 2nd Gear June 14, 2006 Share June 14, 2006 the stain can be polish away by wax... Link to post Share on other sites More sharing options...
Mroonws Clutched June 14, 2006 Share June 14, 2006 Guess it can't be heal or maybe it takes a few polish to remove it. For me, maybe its an old paint. It will be gone after a few washes and polish. Or maybe i forgot where it is or it can't be noticed already. Don't worry, it may be poisonous but its not cancer... Link to post Share on other sites More sharing options...
Shiwao Clutched June 14, 2006 Share June 14, 2006 if u kanna another round, touch wood!, use the kiddy tissues that can be found in some housebrands stores like aunty lucy, to wipe the stain off before it dries. but however if it has since dried up, fret not, go to the nearest washing station and ask the guy to blast it away and wash at the same time. damage? $6. But it's an overkill of you are only 1 or 2 bird crap. I sent my car for a rinse when my car was coated with bird stains one morning. if the stain persists, then, try to wax it out. I've tried either of the ways, works for me. Link to post Share on other sites More sharing options...
Mdvic Neutral Newbie June 14, 2006 Share June 14, 2006 Hi Irene, It took me 10 polishing of the wax b4 the stain went off 100%..... I'm just like you dont bother to wipe offf...... Now don't have to worry got engage car washer, so easier now. Link to post Share on other sites More sharing options...
Ncss Clutched June 14, 2006 Share June 14, 2006 Use ma ma lemon. Link to post Share on other sites More sharing options...
Irene Neutral Newbie June 14, 2006 Author Share June 14, 2006 My fren tried mama lemon. Ok leh but i dare not. Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear June 14, 2006 Share June 14, 2006 Sis, the stain can be removed by applying some polish using a microfibre cloth and rub it all over & over again This would need some elbow grease Link to post Share on other sites More sharing options...
Irene Neutral Newbie June 14, 2006 Author Share June 14, 2006 (edited) Just wondering... can i buy those cans of diluted acid to remove the scratches caused by the droppings. I know its not good for the paint but a little doesnt matter too much right? I think these are common probs.. but l'm just too lazy to do a search. I did use try to polish it away but the black stain seems to eat into the paint already. If i still use whatever cloth to rub on the surface, more damage will be done. Aiya... end of day, a few scratches wont die. l'll just leave it. Maybe l'll take some pics and post tomorrow. Edited June 14, 2006 by Irene Link to post Share on other sites More sharing options...
Kiatmobile 1st Gear June 14, 2006 Share June 14, 2006 I realised due to my laziness, those bird sxxt are so difficult to remove. The harder i rub, the more damage. Those spot remover will help? You know, i was like you when i got my car for the 7th day and this minar drop on my byonet. Not knowing, i wipe it and the more i do it, the more scratch i got. IMMEDIATELY STOP..... Then put more water and clean it but the scratch marks are there.... So from now, whenever i got these Bird*****, i wet it, make sure its soft then clean it off. But you'll still see the stain there laa.....after wiping it off..... Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear June 14, 2006 Share June 14, 2006 Sis, hope you are recovering from your injury Link to post Share on other sites More sharing options...
Poortraveller 1st Gear June 14, 2006 Share June 14, 2006 (edited) Problem is i waited for few days before i decided to clean it. By the time no wet tissue or cleaner can work. Still left some patches of stain. How huh? I already damaged a little of my paint. Heartpain. Dun wish to further damage anything. Whitish coloured ones are easier to remove. What i meant is those dark coloured ones. best solution to ur problem ... change car Edited June 14, 2006 by Tenminste Link to post Share on other sites More sharing options...
Blu_g Neutral Newbie June 14, 2006 Share June 14, 2006 I use the quick detailer and spray at the birdie bombs before using a wet tissue to remove it Don't ever rub hard on the birdie bombs cause it will result in more scratches on your paintwork Ya.. I rub too hard till got scratches. ↡ Advertisement Link to post Share on other sites More sharing options...
Favourite Japanese Songs from 1980-90s
Mandai Bird Paradise
Yusheng from Singapore, Malaysia or China
How to trace owner from vehicle registration number?
Black flakes from washing machine
No basis for employers to cut pay if flexi-work does not affect productivity: Gan Siow Huang
GSS 2021 join forces with Lazada
