K2000 Neutral Newbie September 7, 2006 Share September 7, 2006 hmm...i confirm its fake, cause my friend bought it and try, really CMI ↡ Advertisement Link to post Share on other sites More sharing options...
K2000 Neutral Newbie September 7, 2006 Share September 7, 2006 maybe u want to check the sub serial number with JL audio to confirm Link to post Share on other sites More sharing options...
Ivan0507 Neutral Newbie September 7, 2006 Share September 7, 2006 i think the w3v2 they only put design by usa. Link to post Share on other sites More sharing options...
Ivan0507 Neutral Newbie September 7, 2006 Share September 7, 2006 yes,just try it out ,see what is the out come. Link to post Share on other sites More sharing options...
Webbyboy Clutched September 7, 2006 Author Share September 7, 2006 ya i checked with JL Audio, they said the serial number is 100% authentic, but then i gave the serial number on the box one. Link to post Share on other sites More sharing options...
Webbyboy Clutched September 7, 2006 Author Share September 7, 2006 from the same shop? Link to post Share on other sites More sharing options...
Slowpoke156 Neutral Newbie September 9, 2006 Share September 9, 2006 That is one of the biggest misunderstandings about car audio. Having high gain does not mean only that can optimise the power of the amp. I can run on low gan but if I drive it hard, I can still push the amp to the max. Gains are to help you match your inputs and outputs, not for you to limit the amount of power coming out of the amp. Link to post Share on other sites More sharing options...
Sarong1 1st Gear September 9, 2006 Share September 9, 2006 , agreed. Link to post Share on other sites More sharing options...
Webbyboy Clutched September 12, 2006 Author Share September 12, 2006 probably i gotta find someone with a 300W RMS sounds like and hear how would a 300W RMS sub sounds like ↡ Advertisement Link to post Share on other sites More sharing options...
Audio Shop Recommendation
US$50,000 turntables amp up tunes for affluent vinyl fans
Recommend audio installer
found an honest audio shop
Audio cut out during start-stop cranking.
Anyone playing with 2" full range speakers?
