Casey Neutral Newbie September 22, 2006 Share September 22, 2006 (edited) Does adjusting the temperature of aircon affects FC? Meaning higher temp = compressor kicks in less often (as its always in a on/off cycle) = lesser engine load = lower FC. Edited September 22, 2006 by Casey ↡ Advertisement Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear September 22, 2006 Share September 22, 2006 (edited) Seems like it is so according to some posts which i have read from the forums Edited September 22, 2006 by Mzrmazda3 Link to post Share on other sites More sharing options...
Quantum 5th Gear September 22, 2006 Share September 22, 2006 I am not aware much FC difference when aircon on or off[dizzy] Link to post Share on other sites More sharing options...
Sunray Neutral Newbie September 22, 2006 Share September 22, 2006 I think higher a/c temp means giving lesser load to the comp. Thus the comp will draw lesser load from the engine. Therefore, FC should be lower. Link to post Share on other sites More sharing options...
Casey Neutral Newbie September 22, 2006 Author Share September 22, 2006 (edited) is it true...as in technically??? does the compresor goes on and off?? and is really the effect on the engine load so considerable tat it affects the FC of the car??? this is wat i want to find out, not theory-wise. Edited September 22, 2006 by Casey Link to post Share on other sites More sharing options...
Optionr Neutral Newbie September 22, 2006 Share September 22, 2006 You try driving 1 week without turning on your air-con and see if your FC improves anot. For my Jazz, FC definitely much better when I switch off my air con!!! Link to post Share on other sites More sharing options...
Gilgamesh Neutral Newbie September 22, 2006 Share September 22, 2006 Its is confirmed for my car by own testing. Keeping my driving pattern, route taken and the brand and grade of petrol pumped the same, if I drive wif 80% or more of the time with A/C on, the FC is ~9.5 to 10.5km/L. If I drive wif around 20~30% of the time wif A/C on, the FC is 11.5 to 12.7 km/L. The best I achieved wif A/C off 90% of the time is ard 13.5km/L. Link to post Share on other sites More sharing options...
Tkseah Turbocharged September 22, 2006 Share September 22, 2006 Erm.. I believe Casey is asking whether got diff when setting A/C to very cold and setting it to not so cold. Not between having A/C on or off. Link to post Share on other sites More sharing options...
Burgerdog Neutral Newbie September 22, 2006 Share September 22, 2006 (edited) This is taken from one.motoring: Close window while driving Don't drive at higher speeds with windows wide open. It increases the aerodynamic drag on the highway and lowers fuel economy. Minimize the Use of Car Air-con Operating an air-conditioner in hot weather can increase fuel consumption by more than 20% in city driving. Therefore park in the shade to keep car cool and reduce the need for air-conditioner or use the vent setting as much as possible to minimize the use of air conditioning. The thing is, if you off your air con, then you'll have to open the windows. If your windows are open, it causes drag, which increases FC. So how? And with the weather here, how high can you set the aircon temp? If it comes to a point where there's not much effect, then might as well not on it. Edited September 22, 2006 by Burgerdog Link to post Share on other sites More sharing options...
Mzrmazda3 6th Gear September 22, 2006 Share September 22, 2006 (edited) That's why not much people can tahan without winding down the windows and not using aircon for say 45 mins on a morning say 8.00am during a normal weather day I have tried this before (No aircon & No winding down of windows for 45 mins) and yes FC improved by 1-2km/l but you'll reach office in sweat Edited September 22, 2006 by Mzrmazda3 Link to post Share on other sites More sharing options...
Burgerdog Neutral Newbie September 22, 2006 Share September 22, 2006 Wah!!! You also can leh!!! 45 mins without aircon and wound-down windows... Was wondering if the windows visors can aid in cutting down the drag if you wind down just before exceeding the visors. Anyone here with visors can share? Link to post Share on other sites More sharing options...
Gabriel 1st Gear September 22, 2006 Share September 22, 2006 i onli noe 1 thing... no a/c ....better pick up... good for cheonging traffic light to traffic light Link to post Share on other sites More sharing options...
Gilgamesh Neutral Newbie September 22, 2006 Share September 22, 2006 actually wanted to ask him to check out his a/c temp ctrl mechanism b4 answering this but dropped the idea coz not specialist in car a/c - only studied building a/c in University but not car a/c and dunno if both works the same way (most prob lah but I think the mech bros in this forum is more qualified to answer this) Anyway, if it is controlled by thermostat, it will definitely help since the compressor will shut off when the required temp is reached and hence reducing the load on the engine. My car a/c compressor is those "always on" type and it mixes cold air from the compressor and hot air heated by the hot water from the radiator to regulate temp so the only way for me to test the affect of FC by the a/c is to switch it off. Link to post Share on other sites More sharing options...
Gilgamesh Neutral Newbie September 22, 2006 Share September 22, 2006 i onli noe 1 thing...no a/c ....better pick up... good for cheonging traffic light to traffic light Yup!!! The a/c on off button is the Turbo button for my car. Really comes in handy when someone jio u for a traffic light drag race... Ever beaten a few 1.6L Beng's cars wif my puny 1.4L engine with Turbo switched on. Link to post Share on other sites More sharing options...
Gilgamesh Neutral Newbie September 22, 2006 Share September 22, 2006 This is taken from one.motoring: Close window while driving Don't drive at higher speeds with windows wide open. It increases the aerodynamic drag on the highway and lowers fuel economy. Minimize the Use of Car Air-con Operating an air-conditioner in hot weather can increase fuel consumption by more than 20% in city driving. Therefore park in the shade to keep car cool and reduce the need for air-conditioner or use the vent setting as much as possible to minimize the use of air conditioning. The thing is, if you off your air con, then you'll have to open the windows. If your windows are open, it causes drag, which increases FC. So how? And with the weather here, how high can you set the aircon temp? If it comes to a point where there's not much effect, then might as well not on it. Don't worry bro, the drag effect will only be significant when u r driving at 90km/h and above. U can reduce it by opening only 1 window so as to create a positive pressure in your cabin relative to the external gushing air. By doing so, the air will not gush into your cabin even if u r driving at fast speed. Link to post Share on other sites More sharing options...
Dumb 4th Gear September 22, 2006 Share September 22, 2006 I am not aware much FC difference when aircon on or off[dizzy] I am certain A/C on will surely affect FC. How? I dunno. But whether A/C temp high or low will affect FC or not, I dunno. I can only guess it would as the engine has to work harder. Link to post Share on other sites More sharing options...
Gabriel 1st Gear September 22, 2006 Share September 22, 2006 same here... and beat those wannabes as well Link to post Share on other sites More sharing options...
Zyrofillica 1st Gear September 22, 2006 Share September 22, 2006 okok now tt we are clear about the aircon. What about the radio and the fan blower? do these 2 take as much away from the engine as the compressor would? (usually my fan settings is lowest but my ICE is at max volume ) ↡ Advertisement Link to post Share on other sites More sharing options...
Home Aircon
Home Aircon
Aircon Cabin Filter
Aircon Cabin Filter
Aircon oil renewal necessary?
Where to mod fuel needle?
Car air-con
Car air-con
