Vidz 6th Gear February 1, 2006 Share February 1, 2006 (edited) See attached , just plug into the cigarette lighter socket and the installation is completer. Just read from the LED to know the status of your battery and alternator How does that thing know if its the battery or the alternator since it is plugged into the socket only?? Edited February 1, 2006 by Vidz ↡ Advertisement Link to post Share on other sites More sharing options...
Teriyaki Neutral Newbie February 5, 2006 Share February 5, 2006 If $300 include all parts required and installation for Water temp, oil temp and vacuum meter. Then it is okie. How about 6 AutoGauge, plus installation @ $520? Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear February 6, 2006 Share February 6, 2006 6 ah? so far no experience in that... can't comment on the pricing. Link to post Share on other sites More sharing options...
Ivan6978 Neutral Newbie February 6, 2006 Share February 6, 2006 Just take a rough price guide that each autogauge cost $80..den add abit for installation. From here you see worth it anot. Link to post Share on other sites More sharing options...
Teriyaki Neutral Newbie February 6, 2006 Share February 6, 2006 Ok.. Anyway, who wants to find 1st hand Autogauge, I got lobang... I myself using, and I got 6 in my car. Link to post Share on other sites More sharing options...
Furrynadz 5th Gear February 6, 2006 Share February 6, 2006 where to buy Link to post Share on other sites More sharing options...
Dreamsz Neutral Newbie February 8, 2006 Share February 8, 2006 Eh, pardon me for my qns. But does all these thingy helps in FC/car power bo? Or its for checking purpose huh? Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear February 8, 2006 Share February 8, 2006 for cosmetic and monitoring of ur car... Link to post Share on other sites More sharing options...
Dreamsz Neutral Newbie February 8, 2006 Share February 8, 2006 Arigato millions. Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie February 8, 2006 Share February 8, 2006 A question, when u purchase the volt meter, is there any manual to teach how to read the volt meter ??? no. the volt meter does not come with any manual. i bought a digital one first, it just plug into the cig socket and you will see the readings lor. you can see the picture that bro yeobh posted, the readings are there. then i bought a volt gauge. same function lor. just that it's not digital. Link to post Share on other sites More sharing options...
FGY7022 Neutral Newbie February 8, 2006 Share February 8, 2006 Can I ask how do u know from the voltmeter that the alternator or the battery is faulty? i dun know actually. but then the reading is not normal lor. usually, it's 13.8-14.1 so that day. the reading drop to 11.something.... i knew there must be something wrong liao lor, and i still kiasu lor, have both the gauge and the digital one in the car, and both shows the same reading. so drive to the workshop to check lor.... while driving, was praying hard the battery dun go dead. when reach workshop, about 2km away, reading was 11. so mech check battery, check alternator... then find out the alternator not charging.... kaput liao. Link to post Share on other sites More sharing options...
Gadgeter 2nd Gear February 9, 2006 Share February 9, 2006 for me.. It's more for check purpose. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 18, 2006 Share February 18, 2006 For battery you can carry out two tests - 1)battery charge status & 2)cranking power test. For 1) start the engine and allow the battery to clear the surface charge and then switch off the engine. Take the voltage reading directly from the battery terminals. For 2) you hve to disable the engine ( don't allot it to start) - you cn do this by disconnecting the primary wire + to the coil. Place the voltmeter test leads to the terminals. Get a helper to crank the engine. Take not of the reading - should not drop below 9.6 volt. Below 9.6volt indicates yr battery just do not have the spare energy to crank start the engine. To test alternator for charging, place voltmeter leads on the battery terminals and run engine to 2,500 rpm. A good condition alternator should be able to produce at least 13.8volt. Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 18, 2006 Share February 18, 2006 The battery reading is taken when you switch on the ignition.The alternator reading is taken when the engine is running at 2,500rpm or more. Link to post Share on other sites More sharing options...
Ahhuat 1st Gear February 18, 2006 Share February 18, 2006 Thanks, found out a lot of other thingy also include volt meter. I'm pretty new to these gauges stuff. I realize it Link to post Share on other sites More sharing options...
Yr1985 1st Gear February 18, 2006 Author Share February 18, 2006 Where u did it bro? Link to post Share on other sites More sharing options...
Yeobh 4th Gear February 18, 2006 Share February 18, 2006 available in ebay & Yahoo online sale spore Link to post Share on other sites More sharing options...
Ahhuat 1st Gear February 18, 2006 Share February 18, 2006 RB20.. it's in toh guan.. but i know the guy and i think he gave me discount cos i teacher.. hehe... PM me if u want the contact number... ↡ Advertisement Link to post Share on other sites More sharing options...
