Ooosh 1st Gear November 28, 2012 Share November 28, 2012 If it is a whistle sound during cold start then it means that your belts need to be changed or the belt tension is too loose If it is a rattling or tick tick sound, it is the pulley disc bearing goen case liao. Take to a workshop, take out the pulley disc and shake it, if got sound means the bearing faulty ↡ Advertisement Link to post Share on other sites More sharing options...
W124 Clutched November 28, 2012 Share November 28, 2012 Use mineral oil (thicker oil) - 10-50W for your engine. rule of thumbs, any mileage above 100K should change to mineral oil Using a thicker oil eg w50 grade will deaden the sound but doesn't mean it has solved the problem If you suspect the knocking sound is caused by wear and tear of moving components, you should try certech ceramic gel to rebuild the components back to pre-wear and tear shape and tolerances Link to post Share on other sites More sharing options...
Tangrol Neutral Newbie November 30, 2012 Share November 30, 2012 thanks 4 all the replies... Think the sound comes from a belt next to the alternator. Will bring it a ws for checking.. Btw my car is a latio.. Any idea how much will the damage $$ be? Thanks Link to post Share on other sites More sharing options...
Tangrol Neutral Newbie December 4, 2012 Share December 4, 2012 Thanks... ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Car air-con
Car air-con
Budget 2025 - February 2025.
