Genie47 1st Gear January 27, 2008 Author Share January 27, 2008 How many dispensers? Very crucial. If only one. F*** them! In JB, you need 2 islands with 4 dispensers to really keep the Q moving. Else it is going to be a slow inching hour just to fill your CNG cylinder! ↡ Advertisement Link to post Share on other sites More sharing options...
Phelan 1st Gear January 27, 2008 Share January 27, 2008 From the brief view that i got while driving pass slowly, its only one dispenser with two hoses in front. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 27, 2008 Author Share January 27, 2008 Nabeh! One with two hoses only good for ulu places like Jln Gangsa in the middle of Pasir Gudang Industrial Estate next to the Johor Port. KNN! SPC Talk big only. They think traffic will not be high. Wait until all the PI cars start Qing up and the taxi drivers will start to KPKB. Link to post Share on other sites More sharing options...
Phelan 1st Gear January 27, 2008 Share January 27, 2008 Well, looking at the station, since there is no big cyclinders anywhere in view, i presume that the cng dispenser will be supplied directly through their gas pipeline. SHould be able to acheive good dispensing pressure if that is the case. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 27, 2008 Author Share January 27, 2008 You still need a compressor to dispense. Link to post Share on other sites More sharing options...
Luvknowmore Neutral Newbie January 27, 2008 Share January 27, 2008 Hi Genie, It seems that there are lot of residue in my tank. I pumped only 9.9kg of gas when the indicator appeared red and my tank is 66L type. Maybe I should talk to Melcher whether we can improve on this. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 27, 2008 Author Share January 27, 2008 (edited) Wait a minute. You pumped in gas while the indicator is red? That means there is still gas in it. When I use my gas, it completely fizzes out as in not enough gas in it to have a pressure reading. The car automatically switches to petrol. Don't worry. You got some more gas in it even at red. Nice thing about a bifuel car is that you can run out of gas and the system switches over to petrol. Just try for once use the CNG until the car switches over to petrol. When you pump the gas, it should be more than a measely 9.9kg. Edited January 27, 2008 by Genie47 Link to post Share on other sites More sharing options...
Luvknowmore Neutral Newbie January 27, 2008 Share January 27, 2008 Hi Genie, I have been travelling without gas for 3 days before the pumping in JI. The system switches to petrol everytime. So I can confirm that the system "think" I have no gas. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 27, 2008 Author Share January 27, 2008 Check with Melchers. Link to post Share on other sites More sharing options...
Casey Neutral Newbie January 27, 2008 Share January 27, 2008 (edited) genie, is the mandai station less than 10mins from cck central? take kje? Can we do conversion in johor? Edited January 27, 2008 by Casey Link to post Share on other sites More sharing options...
Genie47 1st Gear January 27, 2008 Author Share January 27, 2008 Take KJE exit Woodlands Rd. Turn to Mandai Rd. Or take KJE into BKE, exit Mandai Rd, U-turn to it. Or dont' take KJE. Go straight to Woodlands Rd then turn to Mandai Rd. Link to post Share on other sites More sharing options...
Casey Neutral Newbie January 27, 2008 Share January 27, 2008 thanks genie, very helpful Link to post Share on other sites More sharing options...
Gilbertaue Neutral Newbie January 28, 2008 Share January 28, 2008 You can do conversion in JB, but you cannot register the conversion with LTA - and that is a problem. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 28, 2008 Author Share January 28, 2008 Got information why there is no compressor or big cylinders in view. The system they are using is the Microbox from Gallileo. It is an all-in-one. The compressor, storage and everything all in one. That is why there is one dispenser island with two dispensers. Still I think SPC is damn kuku to rent out that space to SembGas. Yes, it is rented space to SembGas to do the CNG business. When it opens, confirm got taxi driver KPKB. Link to post Share on other sites More sharing options...
Dirtrider_ak Neutral Newbie January 28, 2008 Share January 28, 2008 (edited) I need them to open 1 at Toa Payoh SPC man. I don't care if it is 1 island. Since now here got ERP gantry open 1 here in the heartland! Genie mine is doing 19.5KM per KG ..... And the ecu seems to have improved .... got power except in very hot days with aircon full blast....the engine seems to stalled if u clutch in ... other days ok ... power wise hmmm improving .... Edited January 28, 2008 by Dirtrider_ak Link to post Share on other sites More sharing options...
Genie47 1st Gear January 28, 2008 Author Share January 28, 2008 Open one must still tap to some gas pipeline leh. Good to hear it is doing well. Link to post Share on other sites More sharing options...
Dirtrider_ak Neutral Newbie January 29, 2008 Share January 29, 2008 (edited) Looks like heartland have to wait ... see how. Where did you get your thermostat housing the metal version? the plastic thingy looks like not gonna hold due to the heat and was replaced with new ones because of heat and pressure. It also show signs of coolant residue not confirmed yet. My radiator cap have tiny crack on the inside pressure valve and also was replaced. The cooling system seems to be heating up when on CNG and causing a failure to the plastics. Still monitoring and hope for the best. My engine oil temp hit 130~145 deg C without aircon. With aircon it maintains somewhere 105 deg c constant. Funny part is that the temp hardly move up but i know the coolant is hot. Maybe next change engine oil will go for the 40 weight instead of 30 weight oil for precaution sake. Will update more. Edited January 29, 2008 by Dirtrider_ak Link to post Share on other sites More sharing options...
Genie47 1st Gear January 29, 2008 Author Share January 29, 2008 Get from RDY. 2nd floor AMK Autopoint. It's the metallic thermostat housing. ↡ Advertisement Link to post Share on other sites More sharing options...
Android conversion.
Android conversion.
Conversion of Car Leasing insurance (R11) to Z10/11(Uber/Gra
HELP! Audio file conversion --> PSP format
License conversion question
Conversion of normal car to OPC
How does conversion of OPC to normal plate works?
FD1, FD2 and FD3 Leather Seats (FD1 Conversion)
RMVB Video conversion
