oomph Neutral Newbie May 12, 2007 Share May 12, 2007 For a friend, jap MPV fitted with 18" Rims - FRONT Camber Left -0:43' Camber right 0:10' Cross camber -0:53' Caster Left --- Caster Right --- cross caster --- Toe Left -0.2mm Toe right -o.3mm Total toe -0.5mm REAR Camber Left -0:59' Camber right 0:58' Cross camber -0:00' Caster Left --- Caster Right --- cross caster --- Toe Left -0.0mm Toe right 0.4mm THRUST ANGLE -0:01' All Comments appreciated. ↡ Advertisement Link to post Share on other sites More sharing options...
Sony 1st Gear May 12, 2007 Share May 12, 2007 The only comment I have is to leave such things to the professional Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 12, 2007 Share May 12, 2007 My understanding is that those computerised wheel alignment machine already has most (all?) of the car model's wheel alignment specifications built into their programme...as long as the technician choose the correct model and adjust accordingly, it should be ok. Different car model have slightly different specification, so difficult to compare... Link to post Share on other sites More sharing options...
Huggable Clutched May 12, 2007 Share May 12, 2007 The last time I did the wheel alignment, there are 2 sets of data. One is the manufacturer's specifications on the toe/camber/caster values. The other, of course, is the car's current values. According to the mechanic, they'll try as best they can to adjust to the manufacturer's values. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 12, 2007 Share May 12, 2007 Whether these sets of readings are correct and will help in steering control and reduce tyre wears is very hard to tell as I believe the ride wheels had been upgrade therefore the standard spec is of not much use. The best way is to do a dynamic test , that is to drive the car over a side slip tester. If the reading is within the -+5m/km then I would say wear will not suffer any uneven wear. And also it is save to drive as the car will be able to keep almost straight ahead without any force required to steer the wheel. Link to post Share on other sites More sharing options...
oomph Neutral Newbie May 15, 2007 Author Share May 15, 2007 at the very least - do the readings look SAFE ? or is there any need for any other adjustments e.g. camber joints, control arms etc ? Link to post Share on other sites More sharing options...
Loosecannon Neutral Newbie May 15, 2007 Share May 15, 2007 i think you better go for a alignment . very strange , cause both right front/back got positive camber , which will eat the outside tyre. on left turns will be bad also because there is less negative camber for grip , thus understeer . normally on street sedan , it is about max -2 degree camber front . Link to post Share on other sites More sharing options...
oomph Neutral Newbie May 17, 2007 Author Share May 17, 2007 hmm... these readings were taken at Y** B*** after paying service fees for installation of shocks - which included installation AND alignment. does this mean that readings are unacceptable and alignment not done properly ? The car is not lowered but is on 18" rims. Link to post Share on other sites More sharing options...
Loosecannon Neutral Newbie May 17, 2007 Share May 17, 2007 here a article on various aspect on alignment . http://www.turnfast.com/tech_handling/hand...ningtable.shtml you can try kenny alignment shop , hph: 90921015 . ↡ Advertisement Link to post Share on other sites More sharing options...
Need Advice on Self Storage
MyResponder app to call SCDF
