Murphys33 Neutral Newbie July 22, 2007 Share July 22, 2007 Hi, I am exploring using a pressure washer from karcher to wash cars. I understand that one can attach a foam lance to it so that it can dispense detergent. Would washing a car this way, without the use of any mitts be clean? Essentially, i use the high pressure spray nozzle to wash off dirt, then attach the foam / soap lance followed by another final spray down bia the pressure washer. Appreciate any thots from enthusiast who may have tried this technique. thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Boyboy 1st Gear July 22, 2007 Share July 22, 2007 u also intend to strip off ur wax/sealant thoroughly? assuming u detail ur car now n then.. Link to post Share on other sites More sharing options...
Murphys33 Neutral Newbie July 22, 2007 Author Share July 22, 2007 u mean using a pressure washer would strip off the wax? Groomworks typically use a prssure washer to wash cars. And i get the idea from there... they rinse and spray down car with pressure washer than run it over MF with car shampoo before using the pressure washer to give it a final wash before drying Link to post Share on other sites More sharing options...
Boyboy 1st Gear July 22, 2007 Share July 22, 2007 after that they will apply the whatever product right? thing is if u are washing in between waxing/sealants, i'd think u want to give it a gentle wash rather than a thorough wash which strips off everything u applied last time there are some pple who never wax their car, only wash it.. then i'd say pressure wash might be easier and faster or if u use it before detailing session, then washing everything off also nvm mah.. Link to post Share on other sites More sharing options...
Thrillman Neutral Newbie July 22, 2007 Share July 22, 2007 Understand that one of the petrol station use to have such power jet wash. Think its under Caltex. But my friend have tried it and find that it does not clean up as good as normal manual wash. Morever if your car have certain paint chipped, not sure if it would actually cause the paint to peel off under such pressure? What U think? Link to post Share on other sites More sharing options...
Chogokin 1st Gear July 22, 2007 Share July 22, 2007 (edited) If you sign up package with Groomworks and if they throw in free 12 car washes , they also nvr apply anything after wash. I dun think using any pressure will remove any coating . Jus my 1 cents worth ..... Edited July 22, 2007 by Chogokin Link to post Share on other sites More sharing options...
Coltagious Neutral Newbie July 22, 2007 Share July 22, 2007 (edited) Using pressure washer will not strip off ur sealant/wax unless u use it without any common sense. No offence bro There are many types of setting that you can use with a pressure washer, with different spray width and the amount of pressure to use. Also, how far the head of the spray is from the paint makes a whole lot of difference. Btw, i believe you will still need to use a wash mitt cos dirt that has dried on the paintwork will require some form of "scrubbing" to be removed. Most decent car shampoo is wax and sealant friendly, but not to the extend of being able to remove dirt without a medium. Edited July 22, 2007 by Coltagious Link to post Share on other sites More sharing options...
Zerstorer 2nd Gear July 22, 2007 Share July 22, 2007 (edited) I've been using a Black&Decker pressure spray for my carwash. However I just use it to blast off loose dirt particles before I rub it with my washing mitt and then use the spray again to rinse off. The detergent attachment is fun and you get foam over the car, but I don't think alone without any contact is sufficient to thoroughly remove dirt or sticky stains. It's pretty useful for blasting the alloy rims and getting the tyres squeaky clean. Edited July 22, 2007 by Zerstorer Link to post Share on other sites More sharing options...
Ivan96935sg Neutral Newbie July 22, 2007 Share July 22, 2007 Must stay in pte. to use pressure washer.....HDB not possible. Link to post Share on other sites More sharing options...
Sony 1st Gear July 22, 2007 Share July 22, 2007 Can to share how much you paid for the B&D pressure spray? is it a mess to hook it up and use it? Cheers Link to post Share on other sites More sharing options...
Zerstorer 2nd Gear July 23, 2007 Share July 23, 2007 The model is pw1400 and is now on offer at Homefix for $199, which seems to be quite a bargain considering the price of a comparable Karcher unit which delivers 120bar of pressure. Well hookup is pretty simple, just secure the quick attachment adapter on your hose and u can just clip it on instantly. Basically it is more effective than a normal garden hose and uses much less water. Link to post Share on other sites More sharing options...
Sony 1st Gear July 23, 2007 Share July 23, 2007 Thanks. will check it out. Seems easy to use. Link to post Share on other sites More sharing options...
Boyboy 1st Gear July 23, 2007 Share July 23, 2007 my common sense tells me if u want to use a LOW pressure washer, any garden hose with adjustable spray head will give good effect. we don't call that pressure washer quite obviously, "pressure washer" means high pressure. Link to post Share on other sites More sharing options...
Shaguar Neutral Newbie July 23, 2007 Share July 23, 2007 So how much is the karcher equivalent? Link to post Share on other sites More sharing options...
Try_conti 2nd Gear July 23, 2007 Share July 23, 2007 hdb car wash lot got no power plug to power those things ..... Link to post Share on other sites More sharing options...
Murphys33 Neutral Newbie July 23, 2007 Author Share July 23, 2007 Does the B&D pressure washer come with a detergent tank? or can you attach a foam gun attachment to the unit? The karcher moddel that has 120 bar pressure costs $498. the model is the K4.98 Alubest plus. This one comes with a detergent tank but no foam lance. Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear July 24, 2007 Share July 24, 2007 keep this discussion going bros. me also want to know if pressure hosing with soaping can be used easily. Link to post Share on other sites More sharing options...
Zerstorer 2nd Gear July 24, 2007 Share July 24, 2007 The B&D unit comes with 3 lances, one vario-spread lance, one rotating "dirtblaster" lance and the 3rd one comes with the detergent bottle attached. However, it doesn't seem to get very foamy...or perhaps its the shampoo I use. ↡ Advertisement Link to post Share on other sites More sharing options...
Optimum No Rinse Wash & Shine
How are you using the SkillsFuture?
New Age Polish --> Chevrolet Portfolio
Using blower to dry car
Washwerkz
Washwerkz
Car wash company under probe after water in Kembangan canal turns red
Car wash at JB
Car wash at JB
HSA recalls 3 brands of high blood pressure drugs
