Freshmaker Neutral Newbie August 30, 2007 Share August 30, 2007 hi people, what does this particular thing do? does it aid in performance of the car, and if so, how much? is it a customise job or a bolt on thing? roughly how much for one? thanks in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Mirrorimage 1st Gear August 30, 2007 Share August 30, 2007 wat car do you drive and how have you modded it? Link to post Share on other sites More sharing options...
Freshmaker Neutral Newbie August 30, 2007 Author Share August 30, 2007 mr-s. intake, exhaust mod only so far. might be going FI route in the near future. thanks. Link to post Share on other sites More sharing options...
Mirrorimage 1st Gear August 30, 2007 Share August 30, 2007 Roger that. Exhaust valve is a valve like a throttle body flap except that it is located somewhere at your exhaust after the extractor. As such, you can choose to be stealth and close th valve, resulting in a smaller exhaust output, or go all out straight thru with it fully opened. usually used on front mounted engines turbo charged or very very power NA cars. For the MRS, the route leading from extractor to exhaust is already very short. As suchm i will think it will not be as needed on a turbo MRS as compared to like a turboed EG6 ` Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear August 30, 2007 Share August 30, 2007 it is more suitable for turbo car. The exhaust will be very loud when the valve is open. There are manual and electronic type to control the valve. Link to post Share on other sites More sharing options...
Freshmaker Neutral Newbie August 30, 2007 Author Share August 30, 2007 thanks mirror and turbonetics... so meaning to say, if i fix on my na-car, it will only be louder, thats all? Link to post Share on other sites More sharing options...
Chrisw55 Neutral Newbie August 30, 2007 Share August 30, 2007 Yes louder and fixing up those are not cheap.I had my done close to a 1K on my E9 Link to post Share on other sites More sharing options...
Gary84 1st Gear August 30, 2007 Share August 30, 2007 bro now u dun need so much to get the power valve liao...As cheap as below 300 also can get...Close to 1K is probably the price a year ago...And i agree its damn loud, my fren had 1 on his LGT....deafening when high rev... Link to post Share on other sites More sharing options...
Gary84 1st Gear August 30, 2007 Share August 30, 2007 bro go put 1 on urs la...ahahaha go into tunnel u on liao sure pple look at u one... Link to post Share on other sites More sharing options...
Chromas 1st Gear August 30, 2007 Share August 30, 2007 No, the valve is meant to make it more quiet by restricting your current exhaust flow. Currently, with your exhaust mod, I believe it's totally open. With the valve, you're adding the ability to control the opening size, thus the size can only go smaller (more silent) and not bigger. Link to post Share on other sites More sharing options...
Dwoon 1st Gear August 31, 2007 Share August 31, 2007 Errr... I think the exhaust valve vents directly to the environment. it bypasses the cat back totally. Not the type which limits the flow through, to the end of the muffler. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear August 31, 2007 Share August 31, 2007 thanks mirror and turbonetics... so meaning to say, if i fix on my na-car, it will only be louder, thats all? not only louder but it will lack low end power as well. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear August 31, 2007 Share August 31, 2007 you want to sell yours to me? Link to post Share on other sites More sharing options...
Turbine Neutral Newbie August 31, 2007 Share August 31, 2007 It sounds like a Rally car with all the poping and cracking sounds! =D~ Link to post Share on other sites More sharing options...
Freshmaker Neutral Newbie August 31, 2007 Author Share August 31, 2007 bro, what brands of ECV available? or must customise one? can the switch be on/off when the car is in motion? or can only be done when car is stationary? im referring to the manual control one not the electronically control one. thanks... Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 31, 2007 Share August 31, 2007 The fuction of the exhaust control valve is to increase the exhaust back pressure- too much will kill the engine, too little or no beck pressure, engine will not be able to rev up smoothly with the correct torque output. Link to post Share on other sites More sharing options...
Chromas 1st Gear August 31, 2007 Share August 31, 2007 Oh that one... erm, I think certain exhaust shops in the central north region can do it, right? Link to post Share on other sites More sharing options...
Gary84 1st Gear August 31, 2007 Share August 31, 2007 whahaha lolx... u mus be kidding.... when is the next MU sia? ↡ Advertisement Link to post Share on other sites More sharing options...
Carbon monoxide poisoning misdiagnosed as lymphoma
Valve stem washer?
Valve stem washer?
Advice on exhaust.
Advice on exhaust.
Ford invents retractable exhausts
Apple In the news
Apple In the news
China spends more on controlling its 1.4bn people than on defense
