Difference VTEC Sohc & Dohc
Llfr
woah so high ah. but meter only max 9k how? how to go 10-11 k.
btw if rev too high will it wear faster. normal cars will. but since v-tec are meant to be rev high and power reach the potential only at high rpm. will it harm?
what is the pro and con of high rpm rev-ing
the problem is without cams upgrade and tuning,rev so high also no use.
power might drop in the high end if the peak power is at 7000rpm..
and a stiffer set of valve springs are needed too.
yes that right, cos the stock b20 rod bolts n rods are weak, so usually its the 1st thing to go in order to build a high rev b20 [idea]
i was thinking remove the rear seats and give up the boots and put the engine behind.laugh.gif
Cannot la, later the car only resting on the rear wheels, front wheels in the air... [laugh]
I wonder if they can just skip the vtec thing and make the engine at permanent 'vtec' state.... would be a wonderful roar after engine start [laugh]
