Thug Clutched September 19, 2007 Share September 19, 2007 To Mirrorimage & Mcff_1980, why not stop all shootings at each other? Been awhile since I check MCF and saw this Vtec thread, felt so happy cause still got pple so interested in it. But for the last few pages mostly about fellow honda lover shooting at each other. Kua liao mah sia suay..... ↡ Advertisement Link to post Share on other sites More sharing options...
Dynaway 1st Gear September 19, 2007 Share September 19, 2007 different thing... depending on wat u going to do to the cylinder head... but IMHO, raising the CR thru Skimpping would be the cheapest way of increasing ur performance. as for porting, u need to know wat setup u r after..... bigger is not always better for porting...so is polishing, does not mean super shiny surface = better flow Link to post Share on other sites More sharing options...
Thug Clutched September 19, 2007 Share September 19, 2007 Meaning if we dun intend to put in bigger piston...its redundant to port the cylinders? Link to post Share on other sites More sharing options...
Thug Clutched September 19, 2007 Share September 19, 2007 STEAM ! Very nice kit though...^^ Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear September 19, 2007 Share September 19, 2007 my answer is similar to Dynaway. skimming and port and polish are different thing but both are done to the cylinder head. skimming helps to increase the compression ratio while port and polish helps for more air flow. but if you asked me,i would say port and polish gives more gain compare to skimming the head. but skimming shold be cheaper. but the best is do both together. correct me if iam wrong,iam still learning. don't flame me. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear September 19, 2007 Share September 19, 2007 in another way,putting in bigger pistons helps to increase the compression ratio so skimming is not needed. skimming is a cheap way to increase compression ratio but there are some cons to it. putting in bigger pistons has got nothing to do with port and polish. port and polish are more useful if you change to high cam(s). again,iam just trying.correct me if iam wrong. Link to post Share on other sites More sharing options...
Dynaway 1st Gear September 19, 2007 Share September 19, 2007 porting is only working on the cylinder head.. nothing to do with the engine block running with bigger piston is wat commonly known as over-bore engine block like i said in my earlier post, it depends on wat kind of setup u r aiming for.... there are different kinds of mods tat can be done.... Link to post Share on other sites More sharing options...
Dynaway 1st Gear September 19, 2007 Share September 19, 2007 i have to dis-agree.... bigger diameter piston may not necessary give u higher CR... it depends on the Piston crown design.. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear September 19, 2007 Share September 19, 2007 so will bigger diameter pistons increase the engine's capacity? Link to post Share on other sites More sharing options...
Dynaway 1st Gear September 19, 2007 Share September 19, 2007 tat is definitely.... either way to increase ur engine cap is by enlarging the diameter or changing the conrod Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear September 19, 2007 Share September 19, 2007 (edited) so con-rod must be shorter or longer in increase the capacity? and will crankshaft helps too? Edited September 19, 2007 by Turbonetics Link to post Share on other sites More sharing options...
Dynaway 1st Gear September 19, 2007 Share September 19, 2007 stroker kit would more likely to require replacement of both conrod n crankshaft. Link to post Share on other sites More sharing options...
Thug Clutched September 19, 2007 Share September 19, 2007 my answer is similar to Dynaway. skimming and port and polish are different thing but both are done to the cylinder head. skimming helps to increase the compression ratio while port and polish helps for more air flow. but if you asked me,i would say port and polish gives more gain compare to skimming the head. but skimming shold be cheaper. but the best is do both together. correct me if iam wrong,iam still learning. don't flame me. I see...now i truly got it straight and understand liao. I did skimming and the high end indeed improved alot. However, i need to pump in better ron petrol...currently working on Caltex platinium...jin expensive arrr Link to post Share on other sites More sharing options...
Thug Clutched September 19, 2007 Share September 19, 2007 porting is only working on the cylinder head.. nothing to do with the engine block running with bigger piston is wat commonly known as over-bore engine block like i said in my earlier post, it depends on wat kind of setup u r aiming for.... there are different kinds of mods tat can be done.... So may I ask a noob question..lol whats the major different in stock cams with those after market stage 1-3 cams? Am very interested in knowing the different in these things. NOT going to mod my current ride anymore. As I've spent too much liao...shall collect enough data and information for next ride's project..keke Link to post Share on other sites More sharing options...
Dynaway 1st Gear September 19, 2007 Share September 19, 2007 skimping the head would raise ur CR.... this will increase the thermal efficiency of the engine.. if u notice, the water temp will be higher than the normal CR cond.. raising CR would mean u need a a better quality fuel of higher octane in order to prevent knocking...... either this or dun set ur ignition timing too advance... Link to post Share on other sites More sharing options...
Dynaway 1st Gear September 19, 2007 Share September 19, 2007 (edited) aftermarket cams... depending on the profile/duration/valve lifts and maker of the cam selection of cams, more importantly u need to know wat u want to setup the engine for... usually those stage-1 cam would be more for road use with abit more power increased stage-2 likely to be a road-rally cam, this may require a higher idling speed, peak power may be shifted backward stage-3 more likely to be a full race cam (some ppl call Wild Cam, 3/4 Cam) where ppl drive most of the time in the red line region.... full thrott condition in circuit, not feasible for street use... this will more likely require ECU tuning and changing of valve springs most of the time, the maker of the cam will put down some notes on the different stage cam, characteristic, duration etc.... when u change cam, u need to have other parts change in order to compliments all the additional air tat is going into the engine. my suggestion is to stay stock for road-going car.... stay away from cams unless u know wat u r looking at. Edited September 19, 2007 by Dynaway Link to post Share on other sites More sharing options...
Mirrorimage 1st Gear September 19, 2007 Share September 19, 2007 ha... isnt it amazing ppl up north come down here to do up their car, while ppl here go up there to have theirs done.. i'm not interested in engaging porting service... i'll be doing the works myself.... i jus need the service for an airflow & air velocity measurement... i believe all are hand ported/polish... i dun think anyone has the access to extrude horning here. Yups all are hand polished. I mean i dun believe in hand polishing without a flow bench to check the results...those that just hand port and polish and just bolt things back on...so each intake and exhaust is like "about" the same. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear September 20, 2007 Share September 20, 2007 higher cams give longer duration and higher lift to the valves. so when it give longer duration,the valves are open longer which allows more air to goes in. and when it give higher lift,the valves will lift higher and also allow more air into the engine. different stages of cams have different duration and lift.all these are at the expense of high idling. and you need to decide which cams you want to use then port the cylinder head to suit the cams for your set-up. ↡ Advertisement Link to post Share on other sites More sharing options...
2020 5th Generation Honda City
Income tax Evasion
Income tax Evasion
This is the REAL VTEC! VTEC IS THE BEST! 真正的 VTEC!
Whats's the difference between rubbing compound and polishing compound?
What is the difference between Honda civic FD1 & FD2
Nets cards - what's the difference
Carburetor (or Carburettor if UK) servicing, what a difference!
