Difference VTEC Sohc & Dohc
Llfr
I see. Sorry to have to rake up your past ..it must have hurt and left a deep scar on you. My condolences. I guess from the way you described you might be having a stage 1 v-tec... that means it opened once ... if you have had a stage 2 v-tec you might succeed .. cos you can open twice .... but honestly the VVT-i is also a good technology ... i am not sure how often it opens though .. must ask the G9 owners around here...
The opening of the intake valves and exhaust valves are governed by the degree of the cams.
Thus if you are SOHC, you are using one timing for both intake and exhaust.
Engineers found that to be rather limiting for performance thus DOHC, (two cams) were used.
Intake cam: This cam is used to control the opening and duration of the opening of the intake valves.
Exhaust cam: same as about but this time it is for the exhuast valves.
This way, tuners can set different degrees for the cams.
At high RPMs, the opening of both the intake and exhaust valves have some form of overlap, thus tuners can set the exhaust valves to close a little later, forming a srong vaccum in the combustion chamber, thus when the intake valve start to open, air is sucked in very strongly.
Performance is a relative term here. It doesn't mean a SOHC 1.6 has less performance than a DOHC 1.6. A well engineered SOHC 1.6 can also achieve similar if not better bhp, 0-100 and top speed than a DOHC 1.6.
Regards,
my previous ride was city vtec, but it ever was eaten by VVT-i corolla G9, shame to talkblush.gif
years ago, on highway I runned at about 110km/h on extreme right lane, a corolla G9 tailgated me a while, then shifted to left lane tried to overtake me, I floored my throtle (tot Vtec kicked in aready), but the corolla G9 still could overtake me and shifted back to extreme right lane in front of mebigcry.gif
Too bad, KM doesn't conduct lesson on how to use VTEC.
Regards,
sorry my bad about the mistake.
3stage vtec (vtec open twice) should be found in the 96 EK vti (SOHC vtec D-engine), purpose of 3stage vtec is actually suppose to be more fuel efficient instead of power.
the B-engine 2stage vtec (open once) is still the more powerful
Hi, my 3 stage EK VTI vtec(SOHC) is
Rev 1 - 3K
runs on 12 valve == fuel efficent
Rev 3-6K
open up to 16 valve == normal fuel intake
6 to redline
Cam lifted ( Vtec open) == Chiong mode
no problem, that time I was a new driver, not skillful enough,
I think I made some mistake when the G9 tried to overtake [smallcry]
1. I didn't shift down gear before stepping throtle, now I believe this is a major mistake [smallcry]
2. a bit late to find G9's attempt
3. might be the G9 was mod, it could speed up to 130-140km/h shortly [sly]
Hmmmm...... for vtec so far i know is only open once. the norm to open vtec should be 5500rpm for dohc and sohc unless yuo have vtec controller. as for vtec to open twice i dun tink so leh b15(sohc) and b16 all open once as for b18 think also open twice. for b20 i can feel the vtec come in 3500rpm and 5500rpm. i'm not sure whether i feel wrongly anot cos i m using a b20 c [:)] urrently.
my previous ride was city vtec, but it ever was eaten by VVT-i corolla G9...
why did my vtec not work
Was your city manual or auto?
sometimes, it is the gearing rather the engine bhp that determines the initial kick during WOT
That could be it... so VTEC kick is determined by RPM? but honestly kicking in a second time at above 6k rpm cant do much mah .. cos hit redline already .. also no where to kick already ...
I suspect that G9 has installed the Ninja Charger ... that one german technology
