Minicop Neutral Newbie September 16, 2007 Share September 16, 2007 Very tough. U can try tooth paste. I know it restore the yellow switch back to white not sure on cupboard. toothpaste ah.. hmmm.. i din try that though.. maybe just give it a shot.. some told me to use boiling vinegar to remove.. Bioling Vinegar good for metal. Wood ok but after that you need to repaint the wood protective paint. For hard plastic is OK. Not sure on Cabinet. It is the soft plastic outer shell type? ↡ Advertisement Link to post Share on other sites More sharing options...
Chocobelle Neutral Newbie September 16, 2007 Share September 16, 2007 Err..wat's that? my cheena oni half past 6 leh Link to post Share on other sites More sharing options...
Southpark2000 Neutral Newbie September 16, 2007 Share September 16, 2007 Hi, Can i check what kind of cleaning agents are available in the market to restore the whiteness of cabinets turned yellow? i tried to look for 1, but it din work. some experience uncles told me that it cannot be removed anymore.. i have to change my cabinets totally.. anyone know? Thanx In Advance!! Autoglym Super Resin Polish....try on a small inconspicuous corner 1st.... Like polishing car.... ....psssst.....in the event you are thinking I am pulling yr leg...i am not Link to post Share on other sites More sharing options...
Freestylers09 5th Gear September 16, 2007 Share September 16, 2007 means apply what u learn Link to post Share on other sites More sharing options...
Typhoonz 4th Gear September 17, 2007 Share September 17, 2007 Are the cabinets exposed constantly to sunlight? Should be right? Link to post Share on other sites More sharing options...
Picantorian Neutral Newbie September 17, 2007 Author Share September 17, 2007 i tried using Degreaser.. but it din help.. will the Autoglym restore the whiteness? i think worst to worst, is to change all the cabinets.. Link to post Share on other sites More sharing options...
Picantorian Neutral Newbie September 17, 2007 Author Share September 17, 2007 the kitchen at my place is not really exposed to sunlight lei.. maybe very minimal. if that is the case, then how is it, my table top does not change colour and still as white? Link to post Share on other sites More sharing options...
Mivec9 1st Gear September 17, 2007 Share September 17, 2007 sorry to tell u that...i dun think there is ...my previous one had smell and i had hard time removing some of the stains...in the end changed the whole cabinet. my new one is white Link to post Share on other sites More sharing options...
Mivec9 1st Gear September 17, 2007 Share September 17, 2007 Use JIF lor... If cannot then you either live with it or change... I assume the cabinets are quite old? tried.. it does not work.. the cabinets are only 5years old.. the cabinets i took over also 5 years....frankly if u can live with it...i think still ok..if not, ask renovator change the cover..hee Link to post Share on other sites More sharing options...
Typhoonz 4th Gear September 17, 2007 Share September 17, 2007 Huh? Strange leh... You cook a lot? Link to post Share on other sites More sharing options...
Dwoon 1st Gear September 17, 2007 Share September 17, 2007 You can get a carpenter to change the "skin" of the cabinet. Its not a cheap thing to do, but if the cabinet structure is still good..... why not???? Give it a fresh new look. Most of the cabinets are made of ply wood and the is laminated with wood veneer. Link to post Share on other sites More sharing options...
Apollo 1st Gear September 17, 2007 Share September 17, 2007 simple. thermal decomposition of surface due to radiant heat fr the stove or endothermic reaction of the structure which absorb heat in the day and release it when the heat source (sun) has receded. another possibility is the chemical reaction to the adhesive which affect the base composition of the laminate. Link to post Share on other sites More sharing options...
Southpark2000 Neutral Newbie September 17, 2007 Share September 17, 2007 [reply] i tried using Degreaser.. but it din help.. will the Autoglym restore the whiteness? i think worst to worst, is to change all the cabinets.. Errrm.....well if the next best option is to change the cabinet - then no harm / no loss trying.... Can use Autoglym on car too..... Not tried on any cabinet but i used AG SRP on a yellowed three-pin multi-plug adapter and brought it back to its orginal whiteness.... Link to post Share on other sites More sharing options...
Picantorian Neutral Newbie September 17, 2007 Author Share September 17, 2007 sorry to tell u that...i dun think there is ...my previous one had smell and i had hard time removing some of the stains...in the end changed the whole cabinet. my new one is white mine no smell.. feels clean.. just that the colour is irritating me.. change to white again.. then later same thing will happen right.. Link to post Share on other sites More sharing options...
Picantorian Neutral Newbie September 17, 2007 Author Share September 17, 2007 got cook everyday lor.. Link to post Share on other sites More sharing options...
Picantorian Neutral Newbie September 17, 2007 Author Share September 17, 2007 i did suggest that.. but because my cabinets is not of a flat surface, he said it cannot be done. only machine can achieve thar kind of design and is old technology.. he suggested that i change it instead.. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear September 17, 2007 Share September 17, 2007 Maybe it's due to the grease and smoke? Link to post Share on other sites More sharing options...
Picantorian Neutral Newbie September 17, 2007 Author Share September 17, 2007 chimology.. ↡ Advertisement Link to post Share on other sites More sharing options...
Car carpet cleaning
Car carpet cleaning
Roomba - Vacuum Cleaning Robot (VCR)
Interior Cleaning
Interior Cleaning
What's Your Come Home SOP during COVID?
DIY cleaning throttle body
Throttle body cleaning
Property tips, observations, and actual experiences
Property Agents' commission
