Adhi Neutral Newbie October 23, 2007 Share October 23, 2007 Hi All i use prestone coolant the small yellow container with green liquid (not the one that already mix with water). it state there for max protection use 70%coolant and 30% water. i want to know what if i use 100% coolant with out adding water? ↡ Advertisement Link to post Share on other sites More sharing options...
Evilernie 4th Gear October 24, 2007 Share October 24, 2007 I'm now using the Billion Super Thermo LLC (as stated in the container) its pink in colour and doesn't require to add water but do check on the radiator once a while to top up I got it for about $78. I still got quite a fair bit of left over from the first fluid change. Link to post Share on other sites More sharing options...
Octopus 3rd Gear October 24, 2007 Share October 24, 2007 Similiar question here... http://theoildrop.server101.com/forums/sho...e=0#Post1013709 Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie November 2, 2007 Share November 2, 2007 Talkng abt cooling,I recently added a 2nd fan to the radiator,temp even whne jam also dun move an inch,damn solid,car temp drop by a bar,a bar.Now I've got 2 fans tekkan the radiator,taking away heat faster.U want cooler air-con,2nd fan lor. Link to post Share on other sites More sharing options...
Elriond Neutral Newbie November 2, 2007 Share November 2, 2007 how much does it cost to add a 2nd fan? btw, wat car is it? Link to post Share on other sites More sharing options...
Latio79 Clutched November 2, 2007 Share November 2, 2007 Does that mean we can top up water in the coolant which the petrol kiosk uncle always do.. Normally how long do we refill the coolant? able to wait till servicing period?? Link to post Share on other sites More sharing options...
Owen_fan 2nd Gear November 2, 2007 Share November 2, 2007 You should check the coolant level once a week top it up when it is below the min level. Link to post Share on other sites More sharing options...
Followthelaw Neutral Newbie November 2, 2007 Share November 2, 2007 It cost me rm 170,they do swee swee Link to post Share on other sites More sharing options...
Octopus 3rd Gear November 2, 2007 Share November 2, 2007 [reply] Talkng abt cooling,I recently added a 2nd fan to the radiator,temp even whne jam also dun move an inch,damn solid,car temp drop by a bar,a bar.Now I've got 2 fans tekkan the radiator,taking away heat faster.U want cooler air-con,2nd fan lor. I got 2 fan at the radiator already... I thought original comes with 2 fan? Link to post Share on other sites More sharing options...
Octopus 3rd Gear November 2, 2007 Share November 2, 2007 [reply] Does that mean we can top up water in the coolant which the petrol kiosk uncle always do.. Yes, can top up with water. [reply] Normally how long do we refill the coolant? able to wait till servicing period?? I hear every 20k km do a flush to replace with fresh coolant. Link to post Share on other sites More sharing options...
Genie47 1st Gear November 2, 2007 Share November 2, 2007 No need every 20k. Depends on your belt change interval. Save your cash. Water pump comes off, coolant comes off and replaced with fresh new coolant. It helps to keep it 50/50. Any leak is easily spotted as crusty deposit if it is 50/50. 30/50 antifreeze/water, you can smell it leaking but dunno where. No crusty deposit present usually. Link to post Share on other sites More sharing options...
Octopus 3rd Gear November 2, 2007 Share November 2, 2007 So every 100k km? I occassionally pour little bit coolant into radiator directly, just a few drops each time. Hope this will keep the coolant life longer. Link to post Share on other sites More sharing options...
Genie47 1st Gear November 2, 2007 Share November 2, 2007 No need. Just use water. You start with 50/50 and by the time it is the next belt change, it is still around 50/50. Link to post Share on other sites More sharing options...
Timmz Neutral Newbie November 3, 2007 Share November 3, 2007 "i want to know what if i use 100% coolant with out adding water? " instructions r on the bottle for a reason :) u can do what ever u like... but the manufacturer will tell u wen u complain I told u so.... No benifits , actually is deteremental, as coolant has lower heat transfer properties vs H20. Coolant is more a anti-freeze/ anti rust /lubricant property. but typically, your car will not explode when u try 100% coolant :) Link to post Share on other sites More sharing options...
Apollo 1st Gear November 3, 2007 Share November 3, 2007 Hi All i use prestone coolant the small yellow container with green liquid (not the one that already mix with water). it state there for max protection use 70%coolant and 30% water. i want to know what if i use 100% coolant with out adding water? Listen to Genie.. he's the guru on this. If you want top quality goto the marketplace folder, see the feller giving away 2 bottle of battery water. take from him, and pour into the radiator! Actually it is distilled water.... dun worry abt the battery water label. mini coolant for ur radiator and u will operate at optimal level. Link to post Share on other sites More sharing options...
Genie47 1st Gear November 3, 2007 Share November 3, 2007 (edited) It has to be coolant Coolant meaning with antifreeze Modern automotive engines contain cast iron replaceable cylinder liners that are subject to accelerated corrosion due to a process commonly known as liner pitting. Simply put, the vibrating surface of liners produces small air bubbles that implode, similar to what happens when you accidentally break a light bulb. The resultant shock wave produced by each of these imploding bubbles is 15 to 20 thousand PSI. In a system of pure water only where no inhibitors or glycol is used, the holes produced can penetrate all the way through in just 500 hours of operation. Coolant then enters into the combustion area above the piston and the piston hydraulics resulting in severe engine damage. Water Today Edited November 3, 2007 by Genie47 Link to post Share on other sites More sharing options...
Fels 4th Gear November 3, 2007 Share November 3, 2007 Just get the pre mixed coolant from the petrol kiosk. The most convenient way to top up your cooling system. Just open up your coolant reserve resevoir cap & pour in the premixed coolant to the correct volume as stated by your reservoir. Don't go and waste time to get watever mix yourself type and be troubled with mixing ratio. Whether you did it correctly or whether was your water contaminated, whether you used distilled water etc etc. As the coolant in your system sometimes bleeds off during extreme heat as coolant also expands, the reservoir serves as a reserve by replacing the coolant in the main circulating system. As time goes by your coolant will be bled and replaced till your reservoir is dry. So topping it up before that happens is necessary. Link to post Share on other sites More sharing options...
Boyboy 1st Gear November 4, 2007 Share November 4, 2007 i think komoco changed my coolant at 18k mileage.. now 40k mileage, have not touched the coolant since. level remains between L and H. so is it ok if i leave it til my timing belt change to do? thinking of adding RL water wetter in the meantime but not entirely sure if it's good. my driving style is quite aggressive sometimes ↡ Advertisement Link to post Share on other sites More sharing options...
Coolant question
Coolant question
Coolant level going down
Radiator Cap
Radiator Cap
Radiator slight crack
What is the purpose of coolant
Coolant overflowing from expansion tank
Anti-Freeze or Coolant?
