Poper 2nd Gear January 20, 2008 Share January 20, 2008 Hi bro/sis, Got an Ariston built-in oven that's not been used for 4 years.. Recently, I use it to toast some nuts and set temp at 100 degrees. It was ok for 30 minutes and suddenly short-circuit the house.. From then on, it will short-circuit everytime I turn it on. (1) Any idea what could have caused it? (2) Any recommendation for a table-top Grill-oven (for simple use, hardly bake)? Thanks! ↡ Advertisement Link to post Share on other sites More sharing options...
Suhong Neutral Newbie January 20, 2008 Share January 20, 2008 U nvr use it for 4 yrs thats why short circuit occur!!!!! u got to change something... if i m not wrong the fuse nxt time turn it on for a while every once a month Link to post Share on other sites More sharing options...
Apollo 1st Gear January 20, 2008 Share January 20, 2008 the other day feller said liaoz. live short to neutral.. cable loose = trip live short to earth... trip cable problem Link to post Share on other sites More sharing options...
Peqasus 1st Gear January 20, 2008 Share January 20, 2008 it could be moisture trapped. do let your oven trip for 3-4 times to dry the moisture up. happens to me evry yr during cny when my mum tries to bake her cookies. jus take care to unplug all electrical appliances. Link to post Share on other sites More sharing options...
Hamburger Hypersonic January 20, 2008 Share January 20, 2008 probably a leak in ur heating element which in turns short to e earth.Meaning?mean can throw away liao.But do open up to see any loose live or neutral wire tat may cause a short circuit. Link to post Share on other sites More sharing options...
Apollo 1st Gear January 20, 2008 Share January 20, 2008 okok... i'll look for adult size XXL diaper for it. Link to post Share on other sites More sharing options...
Comfy 1st Gear January 20, 2008 Share January 20, 2008 u never say where to buy cheap diapers... Link to post Share on other sites More sharing options...
Comfy 1st Gear January 20, 2008 Share January 20, 2008 what i can say is seek professional help. any wrong move might burn your house or hurting yourself lor... Link to post Share on other sites More sharing options...
Genie47 1st Gear January 20, 2008 Share January 20, 2008 If you didn't use your oven for a long period of time, moisture builds up and condenses on the circuitry. This causes the short. Get the handyman to come over and remove the old wires and give it new ones. Once you got an oven, you got to keep using it to burn off the moisture. Link to post Share on other sites More sharing options...
Genie47 1st Gear January 20, 2008 Share January 20, 2008 You do that 3-4 time trip and your breaker will literally melt. DO NOT DO THIS! Link to post Share on other sites More sharing options...
Beaver 2nd Gear January 20, 2008 Share January 20, 2008 Same thing happened to my dryer. One time it shortcircuit my house and thereafter also short curcuit the whole house everytime I turn it on. I got the repairman to fit it and they said is the wear and tear of the wire. Change the wire and everything ok liao. Call the agent to come and see. Link to post Share on other sites More sharing options...
Apollo 1st Gear January 20, 2008 Share January 20, 2008 siang ka pager? Link to post Share on other sites More sharing options...
Beaver 2nd Gear January 20, 2008 Share January 20, 2008 not me Link to post Share on other sites More sharing options...
Alpha78 6th Gear January 20, 2008 Share January 20, 2008 You call for agent, Apollo help you call Agent Smith. Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear January 20, 2008 Share January 20, 2008 http://www.mycarforum.com/forum/gforum.cgi...20trip;#2173388 Brudder, Discussed before but was a deep fryer. should be the same lah. BE CAREFUL PLEASE! Link to post Share on other sites More sharing options...
Shinshino Neutral Newbie January 20, 2008 Share January 20, 2008 If you didn't use your oven for a long period of time, moisture builds up and condenses on the circuitry. This causes the short. Get the handyman to come over and remove the old wires and give it new ones. Once you got an oven, you got to keep using it to burn off the moisture. Genie is right. When I got my new oven also same problem, trip the circult because of moisture. Still got warranty, so the service man took the oven back and heat away the moisture for me. If the trip is due to moisture, there is another way that my dad told me but is kind of dangerous. First, remove the earth wire, so it would not trip your circult box Turn on your oven at 180 deg C (higher than 100 deg shd do) and heat away the moisture with the oven door partly open for 20 mins or so. Connect the earth wire back and test. OR you can try putting some desiccant like hungry hippo in the oven. Just tot of this idea while typing. Tell us if it works :P As Genie has said, you need to switch your oven every now and then to keep the moisture out. I suggest once every fortnight or month, 20 mins. The serviceman recommend once a week but i find it waste of electricity. Link to post Share on other sites More sharing options...
Poper 2nd Gear January 20, 2008 Author Share January 20, 2008 Alamak.. didn't know oven got this kind of behavior Must use regularly if not cannot use?? Link to post Share on other sites More sharing options...
Genie47 1st Gear January 20, 2008 Share January 20, 2008 I regret getting electric oven Should have gotten a standalone gas cooker/oven station from Elba or La Germania. Got gas oven option. Great for cooking and good for suicides. ↡ Advertisement Link to post Share on other sites More sharing options...
MyResponder app to call SCDF
Help with STA report remarks
Vietnam - HCMC short visit
