Kelpie 2nd Gear February 15, 2008 Share February 15, 2008 1. Contemplating to install an ATF cooler. When looking around, the market price for each seems hovering around $220 or so with installation. 2. Any good brand and shop with good workmanship (need to takeout front bumper) to recommend me? For those of you who have fixed the ATF, did you use a steel hose or a rubber hose? Thank you very much. Regards, ↡ Advertisement Link to post Share on other sites More sharing options...
Yuan 6th Gear February 15, 2008 Share February 15, 2008 Hose I not so sure. I installed a Prema brand ATF cooler. Link to post Share on other sites More sharing options...
Multi 3rd Gear February 15, 2008 Share February 15, 2008 Here: http://sg.auctions.yahoo.com/sg/i::230714798 Good price,good workmanship. Link to post Share on other sites More sharing options...
Accordvtec 1st Gear February 15, 2008 Share February 15, 2008 i using Hayden installed @ Auto Dynamac 4 years ago... i think around $200+ Link to post Share on other sites More sharing options...
Windwind Neutral Newbie February 15, 2008 Share February 15, 2008 Are we allow to spray paint to add colors to this ATF cooler? Will the paint damage the ATF cooler? Thanks Link to post Share on other sites More sharing options...
Kelpie 2nd Gear February 16, 2008 Author Share February 16, 2008 Here: http://sg.auctions.yahoo.com/sg/i::230714798 Good price,good workmanship. Don't tell me it is the same shop that install the ATF in my previous car recommended by you? Scare they charge me extra for hose again. Regards, Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie February 16, 2008 Share February 16, 2008 shc forum are actually hosting groups buys for hayden ATF cooler. price hovering between 80 to 110 cash n carry. installation cost about 60 to 80. can save some $$ thou. Link to post Share on other sites More sharing options...
Kelpie 2nd Gear February 16, 2008 Author Share February 16, 2008 (edited) Ok, I found the inform there. Thank You. Regards, Edited February 16, 2008 by Kelpie Link to post Share on other sites More sharing options...
Multi 3rd Gear February 16, 2008 Share February 16, 2008 Now the price is inclusive of extra hose and top ups(free half litre). Link to post Share on other sites More sharing options...
Swiftevo Neutral Newbie June 7, 2010 Share June 7, 2010 ATF Cooler selling only 80 ONLY (cash and carry) plus free delivery. what benefit? ATF cooler helps to extend your transmission life span by cooling the ATF that has been heated up by the torque converter during stop-start traffic. This would prevent the ATF from turning into varnish, which is acidic, and sticky, which is why you see some ATF is brown in color and smells bad. Also when coming out of a traffic congestion, the car maintains its spirited character and is less likely to give that sluggish response. pm me if u r keen... will get back to u asap. Thanks. Link to post Share on other sites More sharing options...
Multi 3rd Gear June 7, 2010 Share June 7, 2010 ATF Cooler selling only 80 ONLY (cash and carry) plus free delivery. what benefit? ATF cooler helps to extend your transmission life span by cooling the ATF that has been heated up by the torque converter during stop-start traffic. This would prevent the ATF from turning into varnish, which is acidic, and sticky, which is why you see some ATF is brown in color and smells bad. Also when coming out of a traffic congestion, the car maintains its spirited character and is less likely to give that sluggish response. pm me if u r keen... will get back to u asap. Thanks. Please post your item at SGCARSTORE...thank you. Link to post Share on other sites More sharing options...
Kangadrool Supersonic June 7, 2010 Share June 7, 2010 Changing ATF more frequently is cheaper than installing cooler. Need not worry about leaks and voiding warranty too. Link to post Share on other sites More sharing options...
Mini-itx Clutched June 8, 2010 Share June 8, 2010 Changing ATF more frequently is cheaper than installing cooler. Need not worry about leaks and voiding warranty too. No, they are 2 different things. One cause of transmission failure is the heat generated during its operation. Thats why you want to cool it down by cooling the ATF thats circulating. Changing ATF frequently will not exactly make the transmission run cooler. Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear August 18, 2010 Share August 18, 2010 what is this atf cooler thingy? sounds interesting! Any bro got any experience with atf cooler to share? any good installers to recommend, preferably @ AV? TIA... Link to post Share on other sites More sharing options...
Yuan 6th Gear August 18, 2010 Share August 18, 2010 what is this atf cooler thingy? sounds interesting! Any bro got any experience with atf cooler to share? any good installers to recommend, preferably @ AV? TIA... It is to cool down your gearbox. More applicable for long distance and hard driving. Not so applicable. But it all depends cos we have a lot of start stop traffic conditions here. Brands that I know of are Hayden and Prema. I am using the Hayden brand. Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear August 19, 2010 Share August 19, 2010 It is to cool down your gearbox. More applicable for long distance and hard driving. Not so applicable. But it all depends cos we have a lot of start stop traffic conditions here. Brands that I know of are Hayden and Prema. I am using the Hayden brand. Hey brudder Yuan, Thanks! I'v searched and found more threads on this . . . interesting hor? May need to get one installed as I'm planning to run my car into it's 10th year Go baby go! Link to post Share on other sites More sharing options...
Yuan 6th Gear August 19, 2010 Share August 19, 2010 Hey brudder Yuan, Thanks! I'v searched and found more threads on this . . . interesting hor? May need to get one installed as I'm planning to run my car into it's 10th year Go baby go! Most important is the regular maintenance of the gearbox. The ATF Cooler is just an icing on the cake or added insurance to assure us drivers. Keep it a habit to change your ATF fluid at stipulated intervals set out in your car's service manual. Link to post Share on other sites More sharing options...
Choy_zy Neutral Newbie August 19, 2010 Share August 19, 2010 Hi, I recently replaced my radiator and found out that modern radiator already has ATF hoses going in and coming out for purpose of cooling, ATF cooler just split this function out......... so I took out my ATF cooler, it seem only add extra weight to the car......ahaha newbie ↡ Advertisement Link to post Share on other sites More sharing options...
EV Tyres
EV Tyres
Recommendation for private driving instructor near BBDC
Which brand of honey to buy?
Recommendation for Spectacles
Recommendation for gynaecologist
Any recommendation for Malaysia Data Plan
Audio Shop Recommendation
