Steven Neutral Newbie May 12, 2008 Share May 12, 2008 Came across this local website. Should be talking about the same thing, right? www.itune-vs.com/bbForum/viewtopic.php?t=191 ↡ Advertisement Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 12, 2008 Share May 12, 2008 Somthing like it..... yes. If I'm correct, the AQUAMIST comes with a controller... I didn't see this in this home made version though. Maybe its further down the pages... didn't go through all, just the 1st page. Link to post Share on other sites More sharing options...
Mustank Hypersonic May 12, 2008 Share May 12, 2008 (edited) i got a 3.5 litre wiper fuild tank which can be used as the water supply you got install this stuff before? i mean the intercooler spray Edited May 12, 2008 by Mustank Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 12, 2008 Share May 12, 2008 Nope... didn't get round to it.... I don't have anymore space in the engine comp to install the water tank. If use the wiper fluid tank, then you cannot add the detergent into it. Besides, at 3.5 ltrs, it'll be used up very fast (every 2 to 3 days gotta top up)...... unless you have it manually triggered instead of set to boost levels. In fact, any tank which can house the water pump will do..... if yours is a sedan, can use the Sti 12 ltr tank which can hook up behind your rear passenger seat. Its flat in design so that your boot space is not affected. Link to post Share on other sites More sharing options...
Mustank Hypersonic May 12, 2008 Share May 12, 2008 mine is musso pig karp it comes with turbo and a intercooler thinking of itchy backside put this one if it is not too expensive Link to post Share on other sites More sharing options...
Perrier 1st Gear May 12, 2008 Share May 12, 2008 http://blizzard.rwic.und.edu/~nordlie/wate...background.html http://www.motherearthnews.com/Green-Homes...n-Wizardry.aspx http://users.frii.com/maphill/wi.html http://water.lovehorsepower.com/FAQ.htm http://blizzard.rwic.und.edu/~nordlie/water_injection/ Link to post Share on other sites More sharing options...
Dwoon 1st Gear May 12, 2008 Share May 12, 2008 (edited) There a current sale from a forummer. Quoted: =================================================================== Orig sti Water tank, sensor for boost, and IC spraybutton = 250 neg ==================================================================== Selling as a set : Spec C 12L water tank, comes with tank, pump, nozzle, switches. Feel free to use my hoses if they can still be used after removing from my car. A must for serious trackies/street monkeys. Pls offer. subarucat 93698412 An older post : ============================================================================ hi selling a Pivot water spray controller at $130 the controller itself only sms me 96347667 ============================================================================= Edited May 12, 2008 by Dwoon Link to post Share on other sites More sharing options...
Mustank Hypersonic May 12, 2008 Share May 12, 2008 thank you will check it out Link to post Share on other sites More sharing options...
Rb26dett Clutched May 12, 2008 Share May 12, 2008 ah icic.i think i get what you mean.the one they are referring to is something like coolingmist systems rite? that uses methanol injection. Link to post Share on other sites More sharing options...
Rb26dett Clutched May 12, 2008 Share May 12, 2008 the spec c water tank is good stuff.i use to use it and its installed in the boot trunk area section directly behind the back seats. Link to post Share on other sites More sharing options...
Normal_aspirated Clutched January 3, 2009 Share January 3, 2009 how about this only car in Japan running on water as fuel ?........................oil tycoons not gonna be happy. Checkout here: Water Car in Japan ↡ Advertisement Link to post Share on other sites More sharing options...
Anyone watches MMA?
Anyone watches MMA?
Green fingers anyone?
Anyone try Cathay Pacific before?
