Foofam77 Neutral Newbie September 23, 2008 Share September 23, 2008 If i install the SCV box at my living room's TV point but not in my bedroom's, would my bedroom's TV reception of free-to-air channels, in particular channel U and channelnewsasia, be blurrish? anyone has such experience? thanks ↡ Advertisement Link to post Share on other sites More sharing options...
Apollo 1st Gear September 23, 2008 Share September 23, 2008 sud not be.. the scv box is just a code scrambler. signal clarity is based on the amplification fr the ground of ur building. if bedroom not good, can comprain, they hv to up the amplifier for u, after checking if the cable is ok. Link to post Share on other sites More sharing options...
Friedpiggy 2nd Gear September 23, 2008 Share September 23, 2008 so it is purely passive? By that i meant does the box respond to any interogation signals or does it send any signals out? You probably already know why i asked [lipsrsealed] Link to post Share on other sites More sharing options...
Maxus-MIFA9 Supersonic September 23, 2008 Share September 23, 2008 Will not affect any other rooms or TV points.... The SCV digital box is to de-code the signal to pick up those TV channels you paid for...... Link to post Share on other sites More sharing options...
Apollo 1st Gear September 23, 2008 Share September 23, 2008 it's just generally a receiver lah... but the amt of signal u r taking in can b monitored fr the remote position downstation, so they do know if u hv 1 or more code scrambler if u hv subscribed to their service it may b "ok" in saf rule but if u hv not, the fine i think is abt $10K Link to post Share on other sites More sharing options...
Ultramega 1st Gear September 23, 2008 Share September 23, 2008 (edited) That's provided the cable point in the room is built by Starhub. I know cos i have a similar problem - my Starhub broadband can't connect. When i call them, 1st question they asked was whether the cable point is built by them...i said no, they said they can't do anything. But it's fair la...not built by them cannot expect them to troubleshoot. Edited September 23, 2008 by Ultramega Link to post Share on other sites More sharing options...
Makinen85 1st Gear September 23, 2008 Share September 23, 2008 i have 2 scv at home....no problem for me..... Link to post Share on other sites More sharing options...
Apollo 1st Gear September 23, 2008 Share September 23, 2008 as long as it is HDB, it will definitely built by SCV contractors. as long as the new condo has SCV outlet when u move-in, most likely it is also built to approved by SCV. cannot dispute one. Link to post Share on other sites More sharing options...
Qpik Supercharged September 24, 2008 Share September 24, 2008 from yr statement, ultraMega must be staying in Jiak Hong Choo then he can buy a satelite dish liao & intercept simi bey gi Link to post Share on other sites More sharing options...
Wish1719 1st Gear September 24, 2008 Share September 24, 2008 me using HD box in the room and Digital in the hall, no such problem. anyway the question you asking, should not be affected. Link to post Share on other sites More sharing options...
Apollo 1st Gear September 24, 2008 Share September 24, 2008 new Jiak Hong Choo also subject to AssSeeBee approval. as long as subjected means they hv responsibilities to make good signal becos they charge $$ for test & commission. it is their baby. only those olden flats like mine, no commercial bare lew, they refused to upgrade then no AssSeeBee box. for some previous HDB upgrade, AssSeeBee only do 1 point. so he mebbe righto. can try to slingbox the signal though. or get the other IPTV lor. shop in middle road, dunno wat name. they also got both england and china channel. uses fone point also can. Link to post Share on other sites More sharing options...
Ultramega 1st Gear September 24, 2008 Share September 24, 2008 i am referring to those extra outlets. like my place, there's only 1 built free by SCV. the other outlets in the bedrooms, some are built by SCV (not free), some are built by renovation contractor. Link to post Share on other sites More sharing options...
Sparks Neutral Newbie September 24, 2008 Share September 24, 2008 If you have tv point in your room then it will be okay. My room do not have tv point, even the antenna I bought does not work. Link to post Share on other sites More sharing options...
Sony 1st Gear September 24, 2008 Share September 24, 2008 use those telescopic type... but try not to stick it out your window.. unless u wanted to see lightning.. in one of my room, i still use the free-to-air frequency.. still can get Tv3 and NTV7 from M'sia... Link to post Share on other sites More sharing options...
Apollo 1st Gear September 24, 2008 Share September 24, 2008 actually is beri easy one. u just open out the outlet can see is the screened cable type Belden RG6 coaxial or old model 2 wire type. belden one means no problem. Link to post Share on other sites More sharing options...
Sparks Neutral Newbie September 25, 2008 Share September 25, 2008 Hi, may I know what is the telescopic type? Any pictures? Link to post Share on other sites More sharing options...
Apollo 1st Gear September 25, 2008 Share September 25, 2008 (edited) want to receive TV3 no nid so troublesome one http://home.pacific.net.sg/~harish/tv3.html [/color] Edited September 25, 2008 by Apollo Link to post Share on other sites More sharing options...
Gearoil 1st Gear September 25, 2008 Share September 25, 2008 You can create as many points you like by splitting ( with SCV filter) into other points. Cables you can buy at Sim Lim Sq ( 3rd lvl) shop which sells all such accessories. You can connect and extend the cable used by SCV to more than 20 m, by simply fixing an adaptor to one end of the cable and attaching the other end to it. Simple lah...why pay SCV so much for another point(s)?....cable cheep cheep only....and you only have to expend some labour of your own nia! ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
No Down Payment Required, 100% Finance Available
How to feedback on hospital service?
Seen the new look on Sgcarmart's Used Car pages? Love it or hate it? We want to hear from you!
Marbella DashCam Users
Anyone have invested in SSB?
