Turbonetics 2nd Gear October 6, 2008 Share October 6, 2008 hi,iam looking for aircon for my house and need to know more about it. we all know that the inverter aircon can help to save our electricity bill,but is it really efficient? i asked around and was told that if i only use the aircon at night for sleeping,inverter is not really necessary as it does not saves alot of electricity. i was told it is only efficient if i ON it for more than 12 hours. any expert can help me? the price difference between inverter and non-inverter is about $1k. should i save up the $1k? thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Dafansu Turbocharged October 6, 2008 Share October 6, 2008 most people go for inverter. get those with 5 tick ratings Link to post Share on other sites More sharing options...
Alanhhg Neutral Newbie October 6, 2008 Share October 6, 2008 price difference is great. Link to post Share on other sites More sharing options...
Detion 1st Gear October 6, 2008 Share October 6, 2008 (edited) invertor is for people who use the air con more intensively. However, you must also take note that invertor can reach higher BTU than non-invertor. If you intend to air con you whole house. You might want to get invertor air-con. Also look at the efficiency rating. The more ticks, the better it is. I suggest mitsubishi electric, toshiba or daikin air con. Just bought a toshiba non-invertor system 2. Found it to be good. Heard also that invertor air con need regular servicing if not its efficiency will fall at a much faster speed than non-invertor air con. Edited October 6, 2008 by Detion Link to post Share on other sites More sharing options...
Dafansu Turbocharged October 6, 2008 Share October 6, 2008 read here for some infor http://www.asiaone.com/News/AsiaOne+News/S...0422-61154.html http://app.nea.gov.sg/cms/htdocs/article.asp?pid=2844 http://singapore-aircon-selection.blogspot.com/ Link to post Share on other sites More sharing options...
Driven Neutral Newbie October 6, 2008 Share October 6, 2008 Right from the horses mouth ( boss of a aircon biz). Inverter only works and saves more for office or places that on the aircon non-stop. HDB houses, not so.....more like marketing gimmicks he said. Well, i trust him. Link to post Share on other sites More sharing options...
Ghostrider 3rd Gear October 6, 2008 Share October 6, 2008 The 1K can be easily save back from your utilities bills. I was using those old aircon (bought brand new in 96) and used for 10yrs... Switch to the new inverter aircon and my monthly bills (electric/water/gas) is down by almost 50% !! Not much diff in lifestyle usage. Aircon 5 room flat. Every night the aircon is switch on for 2 rooms from 10pm to morning 8am. Hall and study room seldom use...on average twice a month for the whole afternoon usually from 11am till 9pm. IMHO....get the inverter. Link to post Share on other sites More sharing options...
Nkps 1st Gear October 6, 2008 Share October 6, 2008 well, no need inverter lar... just buy the normal 'suck suck here, rub rub ther' can liao. Link to post Share on other sites More sharing options...
Damienic 5th Gear October 6, 2008 Share October 6, 2008 Use non stop then got save? wat if use for quite some hours in a day but is those start stop start stop type of usage? say from 2pm-5pm then stop. on from 7-9pm again...then finally from 11pm til next day 10am...will it help to save significantly? Link to post Share on other sites More sharing options...
Mivec9 1st Gear October 6, 2008 Share October 6, 2008 it actually depends on usage. i have a friend who is heavy duty user, she on her aircon practically overnight, everyday. Her bills less than mine while i only only like 2-3 times a week, only till 3-4am. Hers a inverter while mine is a normal type. Link to post Share on other sites More sharing options...
Freestylers09 5th Gear October 6, 2008 Share October 6, 2008 (edited) no need inverter..unless u on all ur all ur aircon everyday one.. inverter work in constant increasing load when the compressor kick in to full load normal aircon work in full load when compressor kick in and gradual decline back so if u use normal aircon temperature set at 24-25 which also "standard temperature" for office,compressor wont kick in as much as u set at 18-20 which our local temperature quite hard to acheive at home and maintain constantly througout the keypoint is dont let ur compressor always load in can liao... as recommendation,dun buy the elites brand also...alot problem i encountered in these 2 brands...sensor spoil la,compressor spoil la,blower spoil la when 1st came.Quality is not there anymore...production shifted to other countries Edited October 6, 2008 by Freestylers09 Link to post Share on other sites More sharing options...
Watwheels Supersonic October 7, 2008 Share October 7, 2008 Diff between inverter & non-inverter: Inverter system: The compressor's rpm will speed up or slow down according to temperature. Once the room has reached desired temp. compressor's rpm will run at constant speed. Non-inverter system: The compressor run at full speed when switched on, when reached desired temp. compressor will stop. Temp. goes up, compressor on. In other words it goes on and off. Like car in city driving, consumes energy. So in car terms , inverter is like highway driving, non-inverter is like city driving. Easy to understand. Link to post Share on other sites More sharing options...
Yoongf 4th Gear October 7, 2008 Share October 7, 2008 Inverter temp control very stable. Temp range very tight. non inverter big range between cold and hot. Inverter is quieter, dun have kick in kick out sound. Inverter main benefit is a variable compressor speed. If room is cold enough, compressor simply slows down, and if need more cooling will speed up. Thus no starting current spike issue, which is the main source of high energy consumption. Non inverter is either full on or full off. when not cold, will on full blast, and when too cold will shut down. Incur high starting current. Inverter benefits is under partial load. If set at 18deg, both technology.. will be blasting full power, so no saving either way. But under partial load.. like using 1 unit only of a system 3, then.. the kick in kick out scenario will take place and savings achieved. Inverter has lower power requirement, and the BTU per watt is higher. so for flats with power limitation, inverter is best.. can give more bang from the limited power supply. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 7, 2008 Share October 7, 2008 If we are talking about a single split unit to one compressor, the difference in energy saving is insignificant whether it's inverter or not. If we are talking about a multiple(let's say 3way) split units to one compressor, the difference in energy saving is no doubt better if it's a inverter system. If u have 2~3 rooms running a/c at night, I think the inverter system will be more ideal. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear October 7, 2008 Author Share October 7, 2008 most people go for inverter. get those with 5 tick ratings got 10 ticks or not? i see the most is only 4 ticks leh. Link to post Share on other sites More sharing options...
Turbonetics 2nd Gear October 7, 2008 Author Share October 7, 2008 it actually depends on usage. i have a friend who is heavy duty user, she on her aircon practically overnight, everyday. Her bills less than mine while i only only like 2-3 times a week, only till 3-4am. Hers a inverter while mine is a normal type. maybe she use other electrical stuffs lesser than you? Link to post Share on other sites More sharing options...
Damienic 5th Gear October 7, 2008 Share October 7, 2008 no need inverter..unless u on all ur all ur aircon everyday one.. inverter work in constant increasing load when the compressor kick in to full load normal aircon work in full load when compressor kick in and gradual decline back so if u use normal aircon temperature set at 24-25 which also "standard temperature" for office,compressor wont kick in as much as u set at 18-20 which our local temperature quite hard to acheive at home and maintain constantly througout the keypoint is dont let ur compressor always load in can liao... as recommendation,dun buy the elites brand also...alot problem i encountered in these 2 brands...sensor spoil la,compressor spoil la,blower spoil la when 1st came.Quality is not there anymore...production shifted to other countries If only on 1 aircon in the house everyday for abt 10-11 hours and another 1 aircon for a few hours not everyday but once every 2-3 days, do you think the inverter will help? thanks Link to post Share on other sites More sharing options...
Blue2 1st Gear October 7, 2008 Share October 7, 2008 I would prefer Mitsubishi...think its more realiable... Side track abit...if not necessary to have aircon, fan will do as it will save u more $$$ ↡ Advertisement Link to post Share on other sites More sharing options...
All about smoking
All about smoking
Home Aircon
Home Aircon
Lets talk about fish!
Aircon Cabin Filter
Aircon Cabin Filter
Aircon oil renewal necessary?
All about springs and shocks(dampers)
Questions about Toyota Mark X
