Idling sensor and effect on AT
Toalson
Not sure what you call them, but there is a idle sensor which if faulty can have an effect on the AT. My car was recently diagnoise with that. And the mech told me, I was fortunately if not have to change another sensor for the AT.confused.gif
However, after the change discovered that idling not ideal cos can rise above the normal previously. And today the gears suddenly jerk when moving off. Got a fright.shocked.gif The most pressing issue is mechanic is missing prolly due to illiness. frown.gif Was suppose to have him check on the problem after the idle sensor was replaced cos he suspected the wires could be faulty as well. I hope the mech was not pulling a fast one as his business oso not too fantastic recently.
I am worried that car cant last the 10yrs..... smallcry.gif All things change after last servicing with change in EO to 30wt and renewal of ATF.
Any comments on mech's assumption? As may have to go to other mech if current is still missing. bigcry.gif
Huh??? What's an idling sensor? Located where? So you changed or did not change the sensor (whatever it is)
If you mean the MAF sensor (this controls the amount of fuel to supply based on the airfow),then perhaps. But it should not only affect idling..... loss of power, your CEL light will also come on if its dead.
Go get a 2nd opinion at another workshop.
If you ask me.... 1st thing check the ATF level lah.... if its too low, also will have jerks.
Sorie but think its the MAF sensor. ATF level checked and found to be ok.
Fortunately manage to contact the mech but his health is not looking good, but he will check for me once he's fit. Thanks.
wad car. how many yrs.
my previous sunny had this sensor problem. car died when moving off. after which car is v jerky.
once car died and couldn;t start at all. diagnosed to be duno wad sensor problem.
engine stalled when moving off. mine's an auto car.
after engine restart, car is v sluggish.
one faithful day it totally can;t start, towed to workshop and discover sensor faulty n starter failed due to overcrank.
but i forget wad sensor already. jus 2 of the sensor that failed. it failed during its 3yrs 8mths. 120k mileage.
It could be the IAC valve (Idle Air Control) that is giving problem or the contact to it that is tarnished and not having proper connection for electrical current to conduct.
Edited by Vtim
Nope, as mech is not fit for work. He's a freelance and will honour any issue if the sensor was to be faulty, thus decide to stick to him. Guess it there wont be issue if I carry on drive with is idleing issue rite?sweatdrop.gif
That's what i think as well. Guess have to cross my fingers that it would ceased while driving. Now hoping that mech is fit as car also need to be prep for inspection.
what you can do is, whenever you come to a complete stop, put on the handbrake or footbrake then at the sametime tap gently on the accelerator to hold on to the Rev to prevent stalling nod.gifnod.gifnod.gif
Mine's a Getz ending its 4th yr.
Wat happend has that to ur ride?
my tussy is 3yrs 8 mths... clocked 150k km...have the same problem as urs recently... the engine check light came out first... den it goes off on its own.. den weeks later it came back again, now with vibrations.... i took out my ecu fuse to reset it and now everyting is ok le....
