Ngck 3rd Gear January 21, 2009 Share January 21, 2009 (edited) I'll see what the repair guys say. I won't be surprised if they will change the mobo just to solve the problem. most likely they will... the last time i got a similar problem with my existing setup, sometimes blue screen, sometimes cannot boot up, sometime boot 3 seconds auto shutdown, troubleshoot until i vomit blood i finally gave up and change mobo and card together.... thats the easiest way out.. change hardware.. sometimes it is just not worth the time to troubleshoot... we also dun have so many spare parts to test here and there lah i dun like to do modular upgrade as sometime you buy part A, in the end part A got problem damage Part B and C as well... plus the lousy feeling got new toy cannot play..... every 3-5 years i just change everything... for the last 15 years Edited January 21, 2009 by Ngck ↡ Advertisement Link to post Share on other sites More sharing options...
Guyver 1st Gear January 21, 2009 Share January 21, 2009 My friend's notebook kana this before also ... think he tried System Restore and it was ok liao. From what he told me ... it was due to something which he installed. Link to post Share on other sites More sharing options...
Brock 1st Gear January 23, 2009 Author Share January 23, 2009 most likely they will... the last time i got a similar problem with my existing setup, sometimes blue screen, sometimes cannot boot up, sometime boot 3 seconds auto shutdown, troubleshoot until i vomit blood i finally gave up and change mobo and card together.... thats the easiest way out.. change hardware.. sometimes it is just not worth the time to troubleshoot... we also dun have so many spare parts to test here and there lah i dun like to do modular upgrade as sometime you buy part A, in the end part A got problem damage Part B and C as well... plus the lousy feeling got new toy cannot play..... every 3-5 years i just change everything... for the last 15 years It's been Day 3 since I sent in. Initial assessment is that mobo definitely has problem. They are still checking my HDD. I've password protected my users in WinXP so I'm guessing they are just doing ordinary hardware physical disk check. Link to post Share on other sites More sharing options...
Ngck 3rd Gear January 23, 2009 Share January 23, 2009 they only need 2 mins to gain access to your admin account. Link to post Share on other sites More sharing options...
Brock 1st Gear January 23, 2009 Author Share January 23, 2009 they only need 2 mins to gain access to your admin account. Thanks for the info. And you're right. They managed to bypass it. Link to post Share on other sites More sharing options...
Brock 1st Gear January 23, 2009 Author Share January 23, 2009 (edited) To all that have replied: My PC is back. The problem is with the MSI P35 Neo3-FR motherboard. Although all caps looked fine, the exact problem could not be determined. A replacement motherboard, MSI P45 Neo 3, fixed the power on problem. However, the tech reported that I need to format my HDD as the system hangs just before the user logon screen. He also reported that it may have to do with the Palit 9800GT Sonic video card as he tried all drivers but unsuccessful. I denied them the permission to do so and took back the PC. After 1 hour of boot and reboot, especially safe mode, I found out the problem for the hanging: 1. AMI Bios that came with the stock motherboard is 1.4, which refused to accept 8800 series and above. A download and reflash of BIOS to 1.6 fixed it. 2. SM Bus Controller issue. Because of a change of motherboard (which previously used ICH9 as compared to the current ICH10), the bus controller drivers for the motherboard and PCI-E controller were not installed. A download and running of the SETUP program from Intel website fixed the hanging before user logon screen problem. I'm gonna call up the repair shop tech guy and explain to him the problem. $30 service fee some more. I'll see if I can get 1-1 warranty with Corbell for faulty motherboard. Warranty is 1-1 exchange for 1st 2 years and 3rd year repair. The mobo is only 1.1 year old. PC is breathing and functioning well again. The difficult part was trying to explain to my wife in English what went wrong and how I fixed it. I used terms like 'nervous system', 'brain version 1.0', 'upgrades', 'paralyzed', etc. Sheesh! Thanks one and all for your advice and support! Edited January 23, 2009 by Brock Link to post Share on other sites More sharing options...
Ngck 3rd Gear January 23, 2009 Share January 23, 2009 beware when they give you a replacement board. By right if within warranty, after replacing the board, new board will take over the existing warranty. make sure they update the serial number on the board and you check it physically yourself.. alot of self repair board floating around if yours is a old model (no offically covered if offically RMA) no need to explain to her lah.... waste time.. my answer is always "can use already" Link to post Share on other sites More sharing options...
Darkness Neutral Newbie January 23, 2009 Share January 23, 2009 (edited) dude u sure the gfx need MINIMUM 450w? that is way too high. 9600GT should work well normally even with a 450W PSU with 2 HDD + 2 optical drive anyway ur case is confirm not psu prob. Cause the power supply is rather decent for ur system even at 450+W. If u had freezes etc during heavy duty graphics usage ie. gaming or video processing then can suspect psu. Best option is to remove the gfx. Use the on board display adapter. On successful boot go to device manger > uninstall/disable the Pallit gfx drivers etc if any and scan for h/w changes. turn off pc. insert new card and boot up and see wat happens. if still got issue use back the old gfx and see if it works. (just to rule out MoBo damage). Highly suspect its ur PCI-E component of the MoBo got damages. Edited January 23, 2009 by Darkness Link to post Share on other sites More sharing options...
Brock 1st Gear January 23, 2009 Author Share January 23, 2009 dude u sure the gfx need MINIMUM 450w? that is way too high. 9600GT should work well normally even with a 450W PSU with 2 HDD + 2 optical drive anyway ur case is confirm not psu prob. Cause the power supply is rather decent for ur system even at 450+W. If u had freezes etc during heavy duty graphics usage ie. gaming or video processing then can suspect psu. Best option is to remove the gfx. Use the on board display adapter. On successful boot go to device manger > uninstall/disable the Pallit gfx drivers etc if any and scan for h/w changes. turn off pc. insert new card and boot up and see wat happens. if still got issue use back the old gfx and see if it works. (just to rule out MoBo damage). Highly suspect its ur PCI-E component of the MoBo got damages. Errr...the problem has be resolved. You may want to read through the entire thread and postings. BTW, box says minimum 450w. A check with most 9800GT manufacturers also state same power requirements. Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear January 23, 2009 Share January 23, 2009 Errr...the problem has be resolved. You may want to read through the entire thread and postings. BTW, box says minimum 450w. A check with most 9800GT manufacturers also state same power requirements. Ho say liao, can play Counterstrike . . . . . Link to post Share on other sites More sharing options...
Brock 1st Gear January 23, 2009 Author Share January 23, 2009 Ho say liao, can play Counterstrike . . . . . Team Fortress 2 lagi fun! Link to post Share on other sites More sharing options...
Shull Turbocharged January 23, 2009 Share January 23, 2009 bro, good to hear that you've solved your problem.. btw, anyone playing GTAVI? Link to post Share on other sites More sharing options...
David Clutched January 23, 2009 Share January 23, 2009 You could ask your wife to give you a repair rebate. Link to post Share on other sites More sharing options...
Brock 1st Gear January 23, 2009 Author Share January 23, 2009 bro, good to hear that you've solved your problem.. btw, anyone playing GTAVI? I'm thinking of getting it but I heard TONS of issues with it, especially processor problems. Most people highly recommend Quad Cores to run it smoothly. I am afraid of risking close to $70 to play a slideshow game. Link to post Share on other sites More sharing options...
Brock 1st Gear January 23, 2009 Author Share January 23, 2009 You could ask your wife to give you a repair rebate. Haha! I'm just glad she gives me time to play! I always tell her "At least I don't go disco, pub, golf, kopi tiam, Geylang! I just have a relationship with my PC!" Link to post Share on other sites More sharing options...
Christan Turbocharged January 4, 2011 Share January 4, 2011 Have a problem too with PC recently. All along function properly until recently. At first when press the start-up button, the light will flash a while stop then reflash again for 1-2mins bf boot up normal. Later the light will flash stop reflash again but no boot up. Took out memory card to clean the shiny edges with tissue. Load back card and able to boot up normal. Have done this a few times. was wondering do I need to change PC or just change memory card or any other hardware parts? PC already 3.5yo Link to post Share on other sites More sharing options...
Chewbacca 1st Gear January 4, 2011 Share January 4, 2011 Didn't read through everything. Upgraded bios for your MOBO? Link to post Share on other sites More sharing options...
Chewbacca 1st Gear January 4, 2011 Share January 4, 2011 Didn't read through everything. Upgraded bios for your MOBO? ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Discussion on Gout problem
HDB season parking renewal problem
Singapore Problem Gambling
