Shull Turbocharged January 18, 2009 Share January 18, 2009 did you check whether any of your capacitors(non solid state) is bloated or what..? ↡ Advertisement Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear January 18, 2009 Share January 18, 2009 (edited) 1. No burnt smell or 'pop' or 'boom' sounds. 2. I suspected HDDs. Removed and tried every single one. Still got problem on the first boot. Re-cap of problem: Initial power on. Memory check OK. System freeze. Current workaround: Initial power on. Wait for 2 sec (estimate) Power off. Wait 1 sec. Power on. Memory check OK. USB devices found. HDD + optical drives found. OS load up ok. Sounds familiar, I had the same problem after I fixed up my new pc 6 mths ago. System froze after memory check, have to reboot a couple of times before OS load, sometimes reboot also cannot start pc. My colleague recommended that I reset BIOS settings to default and also changed my graphics card which was later found to be the culprit (something screwed up). Will consult him tomorrow regarding your problem. This guy build PCs for friends and relatives. Edited January 18, 2009 by Vroomtattat Link to post Share on other sites More sharing options...
Xmark 1st Gear January 18, 2009 Share January 18, 2009 Check your CPU temp. If more than 60 Link to post Share on other sites More sharing options...
Brock 1st Gear January 18, 2009 Author Share January 18, 2009 Check your CPU temp. If more than 60 Link to post Share on other sites More sharing options...
Brock 1st Gear January 18, 2009 Author Share January 18, 2009 Sounds familiar, I had the same problem after I fixed up my new pc 6 mths ago. System froze after memory check, have to reboot a couple of times before OS load, sometimes reboot also cannot start pc. My colleague recommended that I reset BIOS settings to default and also changed my graphics card which was later found to be the culprit (something screwed up). Will consult him tomorrow regarding your problem. This guy build PCs for friends and relatives. Thanks for the added help. I also DIY PC but now stuck. Link to post Share on other sites More sharing options...
Brock 1st Gear January 18, 2009 Author Share January 18, 2009 did you check whether any of your capacitors(non solid state) is bloated or what..? Everything looks fine internally leh... Already spent $155 on PSU which previous PSU was actually fine. Scared to plunk down $$$ for motherboard. Must consult MCFers! Link to post Share on other sites More sharing options...
David Clutched January 18, 2009 Share January 18, 2009 Any chance that your mobo conk out? What mobo are you using? Link to post Share on other sites More sharing options...
Brock 1st Gear January 18, 2009 Author Share January 18, 2009 Any chance that your mobo conk out? What mobo are you using? MSI P35 Neo3-F. BIOS is AMI v1.4. Latest. Link to post Share on other sites More sharing options...
Beehive3783 Twincharged January 18, 2009 Share January 18, 2009 MSI P35 Neo3-F. BIOS is AMI v1.4. Latest. Try running memtest on your rams. I suspect RAM problems. Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear January 18, 2009 Share January 18, 2009 Thanks for the added help. I also DIY PC but now stuck. No problem, DIY is good but sometimes do get stuck too! On the lighter side, did Ash's Pikachu short-circuit your mobo and stuff? LOL . . . sorry! Brock is a funny guy! Link to post Share on other sites More sharing options...
Vroomtattat 2nd Gear January 18, 2009 Share January 18, 2009 Try running memtest on your rams. I suspect RAM problems. Maybe try the old rams, this kind of thing is trial and error liao . . . part by part testing. Link to post Share on other sites More sharing options...
Shull Turbocharged January 18, 2009 Share January 18, 2009 Any chance that your mobo conk out? What mobo are you using? i also think high chance mobo conk out.. i also DIY all my coms at home..so far i think i DIY 20+ coms over the past 4yrs for my family and friends..the most common prob i see is system startup failure..either booting up stuck at BIOS..or CPU running, but no VGA signal out..and more often than not, the mobo is the culprit.. Link to post Share on other sites More sharing options...
Dynaway 1st Gear January 18, 2009 Share January 18, 2009 could be a conflict between the harddisk... i had similar problems...... some HDD jus cant be set as Slave mode to work with DVD/CD drive as MASTER. isolate ur HDD n CD/DVD drives... one by one... see if it helps Originally posted on Hardwarezone Forums but with very little help. First time powering up the PC after some time (10min or more) would leave the system frozen after successful memory check. Power down and power up again would usually cause the system to boot normally. Sometimes, it doesn't. Once it boots up normally, any RESTART from WinXP would boot up fine. I recently upgraded my video card from a XFX 8600GTS 256mb to a Palit 9800GT 512mb Sonic. The new card requires a minimum of 450W and a rating of 24a. My old PSU was a Coolermaster Extreme Power 550W. 12v1 + 12v2 = 16a + 16a = 32a Distributor tech tested my card fine. Said it is PSU not supplying enough power. Went down to another shop and described the situation. Also said it's not enough power. But when I said it was running 550W, they were surprised that it could not run as they assemble theirs with 550w working as well. Itchy finger, bought a new PSU: Aerocool Modular 650w. 12v1 + 12v2 + 12v3 + 12v4 = 18a + 18a + 18a + 18a = 72a. Installed it. Still same problem. Checked RAM. All 4 gig is fine. Noticed something. Upon 1st time powering up, all drives NOT detected. System freeze after successful RAM check. Only 2nd time onwards power on, drives are detected and system boots normally. WinXP SP3 C: is a PATA to SATA 160g D: is PATA 40g Lycosa keyboard with MS Mouse Sound is onboard chip Seriously need help here. Link to post Share on other sites More sharing options...
David Clutched January 18, 2009 Share January 18, 2009 MSI P35 Neo3-F. BIOS is AMI v1.4. Latest. Just about 3 weeks back, I have a bootup problem after I tried to install a TV tuner card. It was working in the afternoon but at night it fail to boot up. I DIY my PC, so the next working day, I took my P35 Neo-2 mobo to Corbell. It was determined that the ram slot on the mobo got problem. Luckily it was less than a year so I got a replacement same day. Link to post Share on other sites More sharing options...
Ngck 3rd Gear January 18, 2009 Share January 18, 2009 Everything looks fine internally leh... Already spent $155 on PSU which previous PSU was actually fine. Scared to plunk down $$$ for motherboard. Must consult MCFers! bro, since you problem not so straight forward, you might want to do minimum config leave only psu, mobo, 1 ram and hdd then try again. leave the rest out. got new hdd to try to reinstall even better Link to post Share on other sites More sharing options...
Ultramega 1st Gear January 18, 2009 Share January 18, 2009 here we go ... The new card requires a minimum of 450W and a rating of 24a. Itchy finger, bought a new PSU: Aerocool Modular 650w. 12v1 + 12v2 + 12v3 + 12v4 = 18a + 18a + 18a + 18a = 72a. Can i say that each channel of your PSU supplies only 18A ? Can check your mobo gfx card slot supplies ?? A. Notice that your gfx needs 24A, does the total of your mobo supply + psu connector = 24A. try to play arnd in your BIOs to see if there is any setting for delay Hdd powerup. just a suggestion mice I think likewise. Although total power of 650w is sufficient, but each channel of only 18A does not meet the requirements of the graphics card, which is 24A. This 24A is most likely the power required to cold boot the card (ie, from totally off to on) and includes surge. When u restart the PC, the card is already powered up so no surge, that's why restarting from Windows is normal. TS, maybe you can check the specs of the other components originally in your system to see if any other cards require 24A. If there is, then i could be wrong..haha. (but there is also a possibility that the specs of the old card is inaccurate). If no other cards require 24A, then problem could really be insufficient power as the shops say. Try to borrow a power supply (not buy) with 24A channel output to test out. At the most bring your whole PC down to the shop. If i'm wrong then sorry hor! Link to post Share on other sites More sharing options...
Mivec9 1st Gear January 18, 2009 Share January 18, 2009 Everything looks fine internally leh... Already spent $155 on PSU which previous PSU was actually fine. Scared to plunk down $$$ for motherboard. Must consult MCFers! Yo Brock, If u r able go safe mode, see if u can go start->run and type eventvwr to view the system tab and see any particular hardware that is failing. My PC had some issues too and keeps rebooting..in the end found bad sector in my HDD - installed OS in D: drive instead C: drive - resolved. Keep us updated! Link to post Share on other sites More sharing options...
Babyckh 5th Gear January 18, 2009 Share January 18, 2009 I recently upgraded my video card from a XFX 8600GTS 256mb to a Palit 9800GT 512mb Sonic. You mentioned that you upgraded from XFX to a Palit? Besides this graphic card, did you upgrade other components? Try to use the XFX again to see if XP boot up again. If it can boot up with no issue, you can narrow down to your new graphic card. Thereafter, get another PC and install this card to it. If that PC can boot up with no issue, probably it is your Asus motherboard's PCI-E bus problem. ↡ Advertisement Link to post Share on other sites More sharing options...
Feedback
Feedback
Dealer re-sell problem car
Discussion on Gout problem
HDB season parking renewal problem
Singapore Problem Gambling
